I deleted some files from an external hard drive and thought they would be in the Recycle Bin, but I can’t find them now. I’m looking for the best way to recover deleted files from an external drive without overwriting anything or making recovery harder.
If you emptied the Recycle Bin and then realized an important file was in there, don’t assume it’s gone for good right away. Sometimes the file data is still sitting on the drive. Windows may have only marked that space as free, which means the file can still be recovered until something else gets written over it.
The first thing I’d do is check the Recycle Bin again, even if you think you already looked. Search by the file name, but also check the folder it came from. A file can seem “missing” if it was deleted inside a larger folder. If you find it, right-click it and choose Restore.
If the Recycle Bin is definitely empty, stop using that drive as much as possible. Don’t install anything on it, don’t download files, don’t copy new data to it, and avoid normal day-to-day use if you can. Any new write activity can land on top of the deleted file’s old space.
Before trying recovery software, check whether Windows already has a backup. Go to the folder where the file used to be, right-click it, and choose Restore previous versions. Pick a version from before the file was deleted, open it, and copy the file somewhere safe.
You can also check File History here:
Control Panel > System and Security > File History > Restore personal files
That lets you browse older backed-up copies of common folders like Desktop, Documents, and Pictures.
If you don’t have a backup, Disk Drill is one recovery tool you can try. It can scan for deleted files on Windows drives and works with common file systems like NTFS and FAT32.
Important part: install it on a different drive than the one you’re trying to recover from. If you install it on the same drive, the installation itself could overwrite the file you’re trying to get back.
Once it’s open, choose the drive that had the deleted file and click Search for lost data. Let the scan finish, then use the preview option to check what it found. If a file previews properly, that’s a good sign, but it still doesn’t guarantee the recovered copy will be perfect.
Choose the files you want, click Recover, and save them somewhere else. An external drive is ideal, but a separate internal drive is fine too. Just don’t recover them back onto the same drive you scanned.
Depending on the software’s current licensing rules, Windows users may be able to recover a limited amount of data without paying.
One last thing: SSDs are trickier. Most newer SSDs use TRIM, which can clear deleted blocks to keep the drive running well. After that happens, recovery may not be possible. If the file was on an SSD, stop using the computer quickly and check backups or recovery options right away.
Do not click “scan and fix,” format, or run CHKDSK on that external drive if Windows prompts you. That can make a recoverable deletion a lot messier, especially if the file system has any damage or the drive was unplugged badly.
External drives are a bit confusing because deleted files do not always show up in the main Recycle Bin the way people expect. Windows can create a hidden Recycle Bin folder on the external drive, but whether your files go there depends on how they were deleted, the drive type, Recycle Bin settings, file size, and sometimes the app used to delete them. If you used Shift+Delete, deleted from a command prompt, deleted inside some backup/photo apps, or the files were too large for the bin, they may have skipped it completely.
I agree with the advice to stop writing to the drive, but I’d go one step further: if the files matter, make an image/clone of the external drive first and scan the clone instead of the original. That’s safer than letting recovery software hammer on the only copy. If that sounds like too much work, then at least install Disk Drill or any other recovery tool on your internal drive, scan the external, and recover found files to a different disk. Do not save recovered files back to the same external drive, even if the software lets you.
The desktop Recycle Bin is not a guarantee that deleted files from a USB/external drive are safely sitting somewhere you can restore from. If Windows did bin them, they may be inside a hidden $RECYCLE.BIN folder on that same external drive, sometimes under a weird user SID folder, so turn on hidden/system files only to check, not to start dragging things around randomly. If they are not there, treat it as a normal deleted-file recovery job: stop using the drive, scan it from another disk, and recover to a different location. I’d be especially careful if the external drive is exFAT or was used between Windows and Mac, because deletion behavior can be less forgiving than people expect.
Do not plug that drive into every computer you own and keep browsing it to see if the files appear. Every mount, preview, thumbnail cache, or “repair” prompt is another chance for writes to happen, especially if Windows decides to create folders or indexing data on it.
A detail people miss: the Recycle Bin view is tied to the Windows user that deleted the files. If you deleted them while the drive was attached to another PC, or under a different Windows account, your current Recycle Bin may not show them even if they are still inside the drive’s hidden $RECYCLE.BIN folder. Same idea if the drive was used on a Mac, where trashed files may be under .Trashes instead. So check from the same computer/account where the deletion happened if you can.
If that turns up nothing, treat it as recovery, not “Recycle Bin recovery.” Don’t restore to the same external disk. Scan it from your internal drive and save recovered files somewhere else. Disk Drill is fine for a guided scan if you want a less technical option, but preview the files before recovering and don’t assume the folder names will all come back neatly. Deleted-file recovery often gives you a pile of found files, and sorting them can be the annoying part.
