Help! Need Free Data Recovery Software Suggestions
My external drive suddenly stopped opening after I unplugged it too quickly, and now a lot of my photos and work files are missing. I’m trying to recover the data without paying for expensive software, so I’d really appreciate recommendations for free data recovery tools that actually work and are safe to use.
I’ve gone through way too many file recovery apps, and most of them land in one of two buckets. Some are built for lab people and feel hostile the second you open them. Others look clean and friendly, then fall apart when the job gets messy. After trying them on real drives, not demo cases, Disk Drill is still the one I point most people to first.
What kept me using it was the mix of simple layout and decent recovery results. I didn’t need to poke through obscure menus to start a scan, and I didn’t feel boxed in by a toy interface either. It handled the usual bad situations I ran into, deleted files, formatted volumes, damaged USB drives, RAW partitions, SD cards, external disks, camera cards. Better than I expected, if I’m honest.
The preview feature saved me time more than once. On a lot of recovery tools, you scan, wait forever, recover a pile of junk, then sort out what opens and what is broken. Here, I was able to check photos, docs, and some video files before restoring them. If you’ve ever dealt with a card full of half-dead vacation pics, you know why this matters. There’s also a byte-for-byte backup option, which I used on a drive starting to act weird. I made an image first, scanned the image, left the original alone. Safer move. On Windows, it also gives you 100 MB free recovery.
A few other tools still deserve a mention, because some of them do better in narrower cases.
  1. UFS Explorer
    This one is for rough jobs. RAID, Linux file systems, NAS boxes, broken partitions, odd storage layouts. I used it once on a RAID set and it found structure other apps missed. The catch is obvious fast. It’s technical, dense, and easy to misread if you don’t already know what you’re looking at.
  2. GetDataBack
    Old app. Old look too. Still, I’ve seen it pull back folder trees and filenames on damaged NTFS and FAT drives better than newer stuff with prettier screens. I wouldn’t call it pleasant, but I wouldn’t ignore it either.
  3. Windows File Recovery
    Microsoft’s free option. No normal interface, all Command Prompt. I tried it on a simple deletion case and it did fine. For basic NTFS recovery, it’s worth a shot. For most people, I’d still pick Disk Drill first because it wastes less of your patience.
If your files are gone and you want any shot at getting them back, stop writing data to the drive now. Deleted files usually aren’t gone right away. The system marks the space as reusable, and from there every install, download, update, or copied file starts eating into your odds. I’ve seen people lose recoverable photos by continuing to use the same laptop for a few hours. Bad move.
Also, don’t install recovery software onto the drive you’re trying to save. I did see someone make this mistake once, and yeah, it made things worse. Put the software on another internal drive, an external SSD, or even a USB stick. Recover the files to a different location too. Same rule.
One more thing people miss. Recovery software helps with logical damage, deleted files, formatting, corruption, busted file systems. If the drive is clicking, grinding, dropping off at random, getting hot, or not showing in BIOS or Disk Management, stop. Don’t keep scanning it. Those are the kinds of signs I treat as hardware trouble, and extra stress can finish the drive off. At that point, a recovery lab is the safer route, even if the bill hurts.
If the issue is deletion, formatting, or file system corruption, your odds are still decent. You need to move carefully and avoid overwriting anything. That part matters more than which app you pick.
Stop using the drive. That matters more than the app.
Since you want free first, I’d try these in this order:
  1. TestDisk and PhotoRec
    Free. Open source. No polished UI.
    TestDisk is good if the partition got messed up after the unplug.
    PhotoRec is ugly, but it pulls files by signature and does not care much about the file system. Great for photos. Bad for keeping folder names.
  2. Recuva
    Old, simple, free.
    Best for accidental deletes on healthy drives.
    Less useful if the external drive now shows RAW or won’t mount right.
    Worth trying if you’re on Windows and okay with terminal stuff.
    It works better than people give it credit for on NTFS jobs. I disagree a bit with @mikeappsreviewer here. I would test this before spending time installing three GUI apps, if your case looks like plain file system damage.
  4. Disk Drill
    If the free tools miss stuff, Disk Drill is a solid next step. The preview is helpful, and for a shaky external drive, scanning an image is the safer play. Free recovery on Windows is limited, so keep taht in mind.
If Disk Management shows the drive size correctly, your odds are better.
If it clicks, drops out, or keeps reconnecting, stop messing with it.
Also, this is a good data recovery software roundup for external drives and missing files, plus a quick visual explainer here, watch this fast data recovery tools breakdown.
My short pick:
PhotoRec for free depth.
Recuva for easy undelete.
Disk Drill if you want the least headache.
First thing, I’d add one option neither @mikeappsreviewer nor @mike34 really leaned on much: DMDE. It has a free version, it’s ugly as sin, but for partition damage and “drive suddenly looks empty / won’t open right” cases, it can be weirdly effective. Not beginner-friendly, no. Effective, yeah. If your unplug turned the filesystem messy, DMDE can sometimes show the old folder structure when simpler tools just shrug.
I’ll mildly disagree with the “just start scanning with everything” vibe. If the external is still being detected with the right size, I’d actually check SMART health first with something free like CrystalDiskInfo before hammering it with long scans. If health looks bad, imaging the drive is smarter than repeatedly poking it. That’s where Disk Drill is nice, honestly, because its disk image workflow is less annoyng than a lot of the nerdier tools.
My free-first order would be:
  1. CrystalDiskInfo
    Check if the drive is dying.
  2. DMDE free
    Great for finding lost partitions / browsing recoverable files.
  3. Windows’ built-in chkdsk?
    Only if the drive is healthy and you accept the risk. I know some people love saying “never use it,” but on minor file system damage it can help. On the wrong case, it can also make a mess. So, cautious maybe.
  4. Disk Drill
    Best balance if free tools get too clunky and you want previews plus a cleaner workflow.
Also, if you want more real-world opinions, this thread has some solid Facebook community recommendations for data recovery software.
If the drive is clicking, disconnecting, or freezing File Explorer, stop messing with it. That’s where free software goes from “helpful” to “how I made it worse.”
Skip chkdsk at the start. I know @stellacadente called it a cautious maybe, but after a dirty unplug I’ve seen it “fix” the directory structure into a bigger mess.
What I’d add that the others didn’t really stress: if the drive still appears, clone it first with something like HDD Raw Copy Tool or ddrescue, then do recovery work on the clone. That matters more than debating Recuva vs PhotoRec.
For free, I’d look at:
  • DMDE for browsing and copying recoverable folders
  • R-Studio demo to see what’s actually there before paying for anything
  • Unstoppable Copier only if this is more “read errors” than true deletion
On Disk Drill, I’m with @mikeappsreviewer only halfway.
  • easy UI
  • previews are genuinely useful
  • image-based workflow is safer
  • decent at mixed photo/document recovery
  • free recovery limit on Windows is small
  • deep scans can return lots of renamed files
  • not my first pick if the drive is physically unstable
So my take versus @mike34, @stellacadente, and @mikeappsreviewer: don’t start with the recovery app list. Start by deciding whether the disk is healthy enough to read once, clone once, and only then scan with DMDE or Disk Drill. If the drive disconnects, clicks, or stalls Explorer, stop there.
