My hard drive suddenly stopped working after my computer froze, and now I can’t access important photos, documents, and work files. I’m trying to figure out the safest at-home data recovery method before I make things worse or lose everything for good. What should I do first, and are there any tools or steps that actually work?
I ran into this with an older external hard drive, and I messed up the first step. I kept using it like nothing happened. Bad call.
If files vanished, stop writing anything to the drive. No downloads, no moving folders onto it, no random testing. Deleted data often sits there until new data lands on top of it. Every write hurts your odds.
Before you install anything, check the boring stuff first. I’ve seen files turn up in places people forget about:
- Recycle Bin
- OneDrive or Google Drive sync folders
- File History backups
- Other external backup drives
- A different user profile on the same PC
If those checks come up empty, then I’d move to recovery software. For normal deletion, a quick format, or a damaged file system, I’d start with Disk Drill. I used it because the layout made sense fast, and it didn’t ask me to know a pile of disk terms before scanning. It handles deleted partitions, formatted volumes, and messed-up file systems better than I expected.
The process I stick to is plain:
- Plug in the drive and confirm your system still sees it
- Install the recovery app on a different drive, not the damaged one
- Run a full scan, skip the quick scan
- Preview files before restoring anything
- Pull the critical stuff first
- Save recovered files to another disk
That last step matters a lot. If you recover back onto the same HDD, you risk overwriting data you haven’t pulled yet. I learned this one the annoying way.
The preview feature is one reason I liked Disk Drill. If a photo opens cleanly in preview, or a video starts playing, I take that as a decent sign the file is usable. I usually test a handful of important files before dumping hundreds of GB out of the scan results. Saves time. Saves disapointment too.
If it misses too much, I wouldn’t stop there. Different tools pull different results. PhotoRec is free and pulls off some wild recoveries, but it’s rougher to use and filenames often come back as a mess. R-Studio and UFS Explorer are solid too, though they feel more aimed at people who already know their way around storage tools.
One more thing. If the drive is clicking, grinding, dropping offline, or vanishing from BIOS, I’d stop trying repeated scans at home. Software helps with logical damage. It does not fix failing hardware.
At that point, a recovery lab is the safer move, especially if the lost files are family photos, work docs, or anything you can’t replace. It costs a lot. Still, for some drives, that’s the last sane option.
If the PC froze first, I’d treat this like a failing drive, not a simple delete job. Small difference, big risk.
I agree with @mikeappsreviewer on one part. Stop using the drive. Where I differ is this. I would not start with a long full scan if the drive is making odd noises, disconnecting, or taking forever to read. Repeated scans put more stress on a weak HDD.
My order would be:
Check SMART health first with CrystalDiskInfo or smartctl.
If you see reallocated sectors, pending sectors, or read errors climbing, stop poking at the disk. -
If the drive still reads, make a clone or image first.
Use ddrescue on another drive with equal or larger size. Work from the clone, not the original. This is the safest home move for unstable disks. Most people skip this and regret it later. -
If the clone finishes, then use recovery software on the clone.
Disk Drill is fine for this part. It’s easier than a lot of old-school tools and works well for home users trying to recover data from a failed or old hard drive. If it finds your folder tree and previews files, that’s a solid sign. -
If the drive is not detected in BIOS or Disk Management, software won’t fix it.
That points more toward hardware or board failure. -
If it’s an external drive, try a different USB cable, port, and power supply first.
I’ve seen cheap enclosures die while the disk inside was still ok. You can remove the drive and connect it by SATA if you know what you’re doing.
For old hard drive data recovery at home, this vid is decent too:
watch this old hard drive data recovery walkthrough
Big rule, never restore recovered files back onto the same drive. That mistake burns people all the time. Sad but truee.
I mostly agree with @mikeappsreviewer and @sterrenkijker, but I’d add one thing people skip way too often: listen to the drive before you do anything fancy. If it spins up, clicks in a pattern, powers down, then repeats, stop. That is not a “try more software” situation. That is a “every extra minute might kill it more” situation.
Also, not every freeze means the drive itself died. Sometimes Windows just trashes the file system. In that case, a read-only check from another computer or a bootable USB can tell you a lot without booting from the bad disk again. I actually prefer this first because it avoids your normal OS doing background writes, indexing, temp files, all that dumb stuff.
If the drive shows up and stays stable, recover the irreplaceable files first, not the biggest folders. Photos, docs, project files. Leave movies and installers for later. Disk Drill is a solid option here because it’s easy to sort results and preview what’s actually recoverable. That said, I would not keep rescanning over and over hunting for one more folder. People get greedy and then the drive gets worse. Seen it happen. alot.
One more practical thing: if this is an external HDD, feel the enclosure. If it’s weirdly hot or buzzing, the USB-SATA bridge might be the real problem, not the disk platters. Cheap enclosures fail all the time.
For extra reading, this thread on best software for recovering deleted files and hard drive data is worth a look too.
So yeah, safest home method to me is:
- Stop using it
- Test detection from another system or boot USB
- If unstable, clone first
- If stable, use Disk Drill and save files elsewhere
- If it clicks or disappears, stop DIY stuff
That’s the line between “home recovery” and “you’re about to make it worse.”
