How Do I Speed Up An Old IPad That Slows Down After A While?
My old iPad starts out okay after a restart, but after using it for a while it gets really slow, apps lag, and browsing becomes frustrating. I need help figuring out what’s causing the slowdown and what settings, storage cleanup, or fixes might improve my iPad’s performance.
Yeah, I ran into the same mess on an older iPad. Safari would stall, app switching would hang for a few seconds, and the whole thing felt worn out overnight. Mine used to feel fine too, so I get why this is irritating.
I wouldn’t jump to buying a new Pro yet. In my case, the slowdown came from piled-up background junk, crowded storage, and a few settings chewing through resources. I started with the simple fixes first, and some of them helped fast.
Start with the obvious stuff
I did a full restart first. Old advice, sure, but it helped more than I expected. A reboot clears temporary memory and stops stuck processes. I try to do it every few weeks now.
Then I checked Settings > General > Software Update. Even small iPadOS updates have fixed weird lag for me before, especially Safari hiccups and random hangs.
Settings I turned off first
These were the big ones on my iPad:
- Background App Refresh
Go to Settings > General > Background App Refresh and shut it off. This made a noticeable difference for me. A lot of apps keep pulling data in the background, and on older hardware you feel it.
- Reduce Motion
Settings > Accessibility > Motion > Reduce Motion. Animations get toned down, and the interface feels less sluggish.
- Reduce Transparency
Settings > Accessibility > Display & Text Size > Reduce Transparency. This cuts some of the blur effects. It looks plainer, but my iPad felt snappier after.
Safari cleanup mattered more than I thought
In Settings > Safari, I used Clear History and Website Data. Safari had gotten weirdly sticky over time, pages hanging and loading unevenly. Clearing it helped. I also closed a pile of tabs. If you’ve got dozens open, your iPad is paying for it in memory.
The part that fixed most of it, storage
This was the main problem on mine. Once storage got close to full, the freezing got worse. Around 90% used, the tablet started pausing in a way I could feel, especially when opening apps or typing in Safari.
Apple says you should keep some free space open, and from what I saw, older iPads need more breathing room than the bare minimum. I’d try to keep around 10 to 15% free if you want it to behave.
When storage is packed, iPadOS struggles with temp files and general housekeeping. On my device, this showed up as random 3 to 5 second freezes where the screen stopped taking input. I checked iPad Storage and found the usual junk, big videos, duplicate photos, burst shots, and bloated System Data.
I first tried cleaning it by hand. Bad idea. Took forever. Too many photos, too many clips, too much scrolling. Later I used Clever Cleaner, and it sped the process up a lot. What I liked was the lack of paywalls and constant ad spam.
The useful part for me was the Heavies section. It sorts media by file size, so I found giant videos fast and cleared a few GB right away. The Similars section grouped near-duplicate photos and random screenshots, which saved me from checking every image one by one. It also keeps processing on the device, so your photo library isn’t getting shipped off somewhere else. I freed about 5GB, and the freezing dropped off almost immediatly after.
One more thing, Mail
If you use Apple Mail and your inbox is huge, I’d look at fetch settings. Push mail kept my older iPad busy all day. Switching it to Manual Fetch cut down background activity. Less constant checking, less strain.
If none of this changes anything, the battery might be part of it. When the battery gets weak, performance can dip because the system is trying to avoid shutdowns. Still, I’d check storage and those settings first. For me, those were the real fixes.
Hope you squeeze a few more years out of it. I did.
If it starts fine after a reboot, then slows down later, I’d look at memory pressure first, not only storage. Older iPads with 2GB RAM choke after a few heavy sites, ad scripts, and app swaps. Safari is often the worst offender. One bad tab stack and the whole thing feels cooked.
A few things I’d do, beyond what @mikeappsreviewer listed:
  1. Turn off Safari tab hoarding.
    Settings > Safari > Close Tabs > After One Day.
    Old tabs eat RAM and reload constantly.
  2. Remove widget clutter.
    Home Screen widgets and Today View panels keep polling for data. Older iPads feel this. Trim them hard.
  3. Disable Siri suggestions.
    Settings > Siri & Search.
    Turn off Suggestions in Search and Look Up for apps you do not need. This cuts background indexing.
  4. Check battery health in a roundabout way.
    iPads hide it on many models, which is annoyng. If performance tanks while battery drops fast or the back gets warm, the battery is suspect. Old batteries sag under load. Apple or a repair shop can test it.
  5. Reset Safari without nuking the whole iPad.
    Clear website data, then disable experimental junk if any got toggled. Also use a content blocker. Fewer ads, less script load, less lag.
  6. Watch thermal throttling.
    If the iPad gets warm after 20 to 30 mins, speed drops. Remove a thick case while browsing or charging.
  7. Last resort, do a clean restore.
    Backup, erase, set up fresh, install only a few apps first. If speed returns for a week, one app or sync service is the problem.
I slightly disagree with turning off every visual feature first. Reduce Motion helps some people, but if the iPad is grinding after time passes, RAM, battery, heat, or storage is usally the main issue.
For storage cleanup, Clever Cleaner is worth a look if your Photos app is a mess. It’s a free iPhone and iPad cleanup app for removing duplicate photos, large videos, and similar images fast. This review covers it well, free iPhone storage cleanup app review for Clever Cleaner.
If you post your iPad model, iPadOS version, and free space left, people here can narrow it down fast.
I’d check one thing people skip: analytics logs and one rogue app. @mikeappsreviewer covered storage stuff, and @mike34 is probly right about RAM pressure, but if the iPad starts fine after reboot then degrades, sometimes an app is looping, crashing silently, or hammering sync.
Try this:
  • Settings > Privacy & Security > Analytics & Improvements > Analytics Data
    Look for the same app name showing up over and over. That’s a clue.
  • Settings > General > iPad Storage
    Tap apps and see which ones have huge “Documents & Data” sizes. Social apps, streaming apps, and browsers can get bloated.
  • Turn off app auto-downloads and automatic updates
    Older iPads can feel weirdly busy in the background even when you’re not doing much.
  • If you use Chrome/Firefox, test Safari only for a day
    Third-party browsers on older iPads can feel worse, not better.
  • Sign out of widgets-heavy apps like Pinterest, Facebook, news apps for a bit
    Some of them are sneaky resource hogs.
One place I sorta disagree with both of them: factory resetting too early is a pain. I’d do a “bad app hunt” first. Remove the 3 heaviest apps, use the iPad for a day, then add stuff back.
Also check free space after photos cleanup. If your library is a mess, Clever Cleaner is actually useful for trimming duplicates and big videos fast. This see how Clever Cleaner frees up iPad storage in seconds clip explains it better than a wall of text.
If the slowdown happens mostly while charging, that’s a diff clue too. Heat or battery aging, not just storage.
