I imported photos from my iPhone to my computer and tried deleting them from the iPhone, but they keep reappearing in Photos. I’m not sure if this is caused by iCloud Photos, syncing, or a failed import. I need help figuring out how to permanently delete imported iPhone photos without them coming back.
I ran into this more than once, and it gets old fast. You import photos off the iPhone, you think the job is done, then storage still looks packed. Same red bar, same bad mood.
If you want to clean it up on the phone first, open Photos, go to Albums, then scroll until you see Imports. That section usually holds the stuff you brought over or moved around recently. Deleting from there helps, but it does not finish the job. You still need to open Recently Deleted, which sits near the bottom of the albums list, and wipe it out by hand. iPhone keeps deleted photos there for around 30 to 40 days. Good safety feature, bad if you need space today.
One part tripped me up for longer than I want to admit. On Mac, the missing Delete after import option is often tied to iCloud Photos. When iCloud sync is on, Apple treats cloud sync as the main photo library, so the Mac Photos app stops showing that delete checkbox. I had to turn off iCloud Photos for a bit on the phone before the option showed up again.
If the Photos app on Mac starts acting weird, I skip it and use Image Capture. Old app, still there, still useful. Plug in the iPhone with USB, launch Image Capture, highlight the photos you already copied, then hit the delete button. It is a rougher tool, sure, but I found it more reliable when Photos refused to clear files from the device.
On Windows, I did the blunt version. Open the iPhone in Windows Explorer, go into the DCIM folder, and remove the files directly like you would from a flash drive. This works, though it feels a bit sketchy the first time. You need to be careful, because there is no easy undo sitting there waiting for you.
If deleted photos keep showing back up, I would look at iCloud Photos again. This is usually where the mess starts. If the phone is syncing while the computer is removing files, or the cloud library is stuck halfway through an update, the same photos can loop back onto the device. I saw this happen after deleting from my computer while the phone was still trying to pull the library back down.
The part people tend to notice last is performance. I blamed my battery once. Another time I blamed iOS. Nope. My storage was stuffed with leftover photos and video. When free space gets too low, the whole phone starts dragging. Apps open slow. Typing gets delayed. Even small things feel off. After I cleared space, the phone stopped acting ancient.
I tried doing the cleanup by hand. Burst shots, duplicate screenshots, ten copies of the same blurry cat pic. Waste of a weekend, if I’m honest. I ended up using Clever Cleaner, mostly because I was tired and wanted to see large files first. Most cleanup apps I tested were full of ads, nags, or some trial countdown. This one did not hit me with any of that.
The part I kept going back to was the Heavies tab. It sorts media by size, so the giant 4K clips jump out right away. There is also a Similars tab, which grouped near-duplicate shots well enough for me to clear a pile of repeated photos without staring at every thumbnail for hours. It also shows file sizes on screenshots, which sounds minor, though I found it useful when trimming hundreds of tiny junk images. From what I saw, processing stays on-device, which mattered to me because I did not want my library going through some unknown server.
After removing around 15GB, my phone quit stuttering. That was the whole fix. So if your import is done and storage still looks wrong, check Recently Deleted first. If the phone still feels bloated after that, go hunt down the large videos, duplicates, and screenshots you forgot were there. In my case, those leftovers were the real problem.
If photos keep coming back, I’d look at sync state first, not the delete step.
What often happens is this:
- You import to a computer.
- The import does not mark all items as transferred.
- iCloud Photos syncs the same library back to the phone.
- Photos app rebuilds thumbnails, so it looks like deleted stuff returned.
A few checks I’d do:
If you use iCloud Photos:
Go to Settings, your name, iCloud, Photos. See if Sync this iPhone is on. If it is on, deleting on the phone deletes from iCloud too. If you deleted from the computer copy only, your iPhone still sees the iCloud versions and pulls them back into view. This is why local import is not the same as removing from your Apple photo library.
Check whether those images are still on iCloud.com.
If they are there, the phone is doing what it was told to do.
Also check storage in Settings, General, iPhone Storage, Photos.
If the number does not drop after deletion, the library index may be stuck. A restart plus leaving the phone on Wi-Fi and power for 20 to 30 mins sometimes fixes the mismatch. Annoying, but true.
I sort of disagree with @mikeappsreviewer on deleting straight from DCIM as a first move. It works, but I’ve seen it leave weird gaps in the library database. I’d treat direct DCIM deletion as last resort, not first.
If your goal is cleanup after import, separate the tasks:
- Confirm import on the computer.
- Confirm photos are in iCloud or backed up elsewhere.
- Turn off syncing tempraorily if sync is re-adding them.
- Delete from the iPhone.
- Let Photos finish syncing before turning anything back on.
If your library is full of dupes, big videos, and old screenshots after all this, use Clever Cleaner to find the junk faster. Also worth reading real Clever Cleaner app reviews for iPhone photo cleanup if you want to see how people handle bloated photo libraries.
Short version, reappearing photos usually means sync, not failed deletion.
What I’d check next is whether these are actually synced photos vs local camera roll photos. That part gets missed a lot.
If the photos were originally synced onto the iPhone from a Mac or PC years ago, you usually can’t delete them one by one on the phone. They come back because the next sync puts them right back. Different issue from iCloud, same annoying result. In that case, connect the iPhone to the computer you used before and remove the synced photo albums from Finder or iTunes.
I partly agree with @mikeappsreviewer and @suenodelbosque about iCloud being the usual suspect, but not always. Sometimes the real problem is the phone never finished indexing after import, so Photos shows stale thumbnails like a haunted house. Check the photo count before and after a restart, then wait a bit on power and Wi-Fi.
Also look in:
Settings > Photos > Shared Library
If Shared Library is enabled, items can appear to “come back” because you’re viewing both personal and shared content. Same for Hidden album if stuff seems to vanish and reappear.
One more thing people forget:
Settings > [your name] > iCloud > Manage Account Storage > Photos
If iCloud is full, sync can stall and act weird.
If your goal is just freeing space fast, I would skip manual hunting and use Clever Cleaner for iPhone to spot giant videos, duplicates, and screenshots after you finish sorting out sync. It won’t fix iCloud logic, but it does help clean the leftovers that make storage look broken.
If you want a clearer step by step iPhone photo import and delete guide, that may help narrow down which part is failing. Probly worth checking before deleting anything else.
