How To Recover Deleted Files From A USB Stick After Cleanup?
I cleaned up my USB stick and accidentally deleted important files I still need for work and personal documents. I already emptied what I could, and now I’m trying to figure out the best way to recover deleted files from a USB drive without making things worse. What recovery steps or software should I try first?
If your USB stick is making clicking noises, dropping off the system at random, or getting hot in your hand, stop there. Unplug it. Don’t keep testing stuff. Don’t run repair tools. Don’t use CHKDSK. I’ve seen people do this hoping for a quick fix, then end up with a worse mess because the drive kept degrading while Windows was 'fixing' it. At that point, a professional recovery shop is the safer move.
If the easy checks didn’t bring your files back, I’d assume one of two things. The file table is damaged, or the files are gone in the usual deleted-but-not-overwritten way. In both cases, recovery software is the practical next step.
You’ll run into the usual free suggestions, PhotoRec, TestDisk, Windows File Recovery. I tried those. They work, sort of, if you’re comfortable in a terminal and don’t mind cleanup after. The annoying part is PhotoRec especially. It recovers by file signature, so you often lose the original names and folder layout. You end up staring at a pile of files named stuff like f123456.jpg and spending your evening opening them one by one. It’s not fun. I did this once with a family photo dump and I still regret it a bit.
For people who want something easier to deal with, I’ve had better results with Disk Drill. It felt less risky, less messy, and a lot easier to work through when I was trying to pull data off a flaky USB drive.
Why I keep pointing people there:
  1. It lets you image the drive first. You make a byte-for-byte copy of the USB stick, then scan the copy instead of hammering the original device. If your flash drive is half-dead, this matters a lot.
  2. You get previews before recovery. Photos, videos, docs, you can inspect what it found before saving anything. Saves time. Saves guesswork too.
  3. It keeps things organized better. In my use, it did a better job preserving folder structure and identifying file types than the free command-line stuff. It also works with BitLocker-encrypted drives, which is nice if your USB had protection turned on.
One rule people mess up all the time, save recovered files to your computer’s internal drive, not back onto the same USB stick. If you write new data onto the damaged drive while trying to recover it, you risk overwriting the files you were trying to save in the first place. I know this sounds obvious, but tired people do tired things.
After you’ve copied out everything you need, wipe and reformat the USB drive if you still trust it. Me, I’d lean toward replacing it if it acted weird once already. Storage is cheap. Lost files aren’t.
Stop using the USB stick first. Every new write cuts your odds.
If this was a normal delete plus emptying trash, your files often still sit on the drive until new data overwrites them. So your next move is simple. Scan it from your PC and recover to a different drive. Not back to the USB. People mess this up allll the time.
I agree with part of what @mikeappsreviewer said, but I don’t think you need to jump straight into the more raw tools unless you like sorting through a pile of renamed files. For work docs and personal folders, I’d start with Disk Drill because it tends to keep filenames and folder paths better than signature-only recovery. For documents, that matters a lot.
My order would be:
  1. Plug the USB in read-only if your setup allows it.
  2. Run a scan with Disk Drill.
  3. Filter by Documents, PDF, XLSX, DOCX, JPG, whatever you need.
  4. Preview files first.
  5. Recover them to your computer or another external drive.
If the quick scan finds little, run the deep scan. On flash drives, deleted office docs often show up fine if the stick wasn’t reused after cleanup. If it was reused, recovery rates drop fast. That’s the ugly part.
One thing I would add. Check cloud sync and temp copies before spending hours scanning. Look in OneDrive, Google Drive, Recent Files, Office recovery, and Windows temp locations. I’ve seen people recover 90 percent from sync history and never need full recovery softwrae.
If you want a solid overview of the best data recovery software for 2026, this helps: best USB file recovery tools explained
If the USB starts disconnecting, freezing Explorer, or asking to format, stop and image it first. If it stays stable, scan it now, not tomorow.
First thing I’d do that neither @mikeappsreviewer nor @byteguru really leaned on enough: check whether the files were ever cut-and-pasted, not just stored on the USB. Windows sometimes leaves traces in Recent, Quick Access, Office recent lists, and even app-specific caches. If these were work docs, open Word or Excel and check recovered/unsaved docs before going full recovery mode. People skip that and waste an hour scanning for stuff that’s still sitting in a local temp folder.
Also, if the USB cleanup happened on Windows, look at File History, OneDrive version history, and any backup software you forgot you enabled. Boring answer, but honestly the fastest one when it works.
If that all comes up empty, then yeah, use recovery software. I slightly disagree with jumping into the deepest scan first. Start with a normal scan because deep signature scans can give you a mess of duplicates and half-broken files. If you want the least headache, Disk Drill is a solid pick for USB deleted file recovery since it’s easier to sort by file type, date, and previews than the more chaotic free stuff.
Important bit: recover to your computer, not back to the stick. Seriously. Don’t do the classic whoops twice.
If the USB is acting normal, scan now. If it’s disconnecting or asking to format, stop messing with it.
For more discussion around faulty flash media and file recovery options, this thread is pretty useful: best ways to recover files from a faulty USB drive.
