My thumb drive suddenly stopped opening after I plugged it into my laptop, and now it says the USB drive is corrupted or needs to be formatted. It has important photos and work documents I never backed up, so I need safe ways to recover files from a corrupted USB flash drive without making things worse.
Start by figuring out what kind of failure you have
I’d slow down before throwing recovery apps at it. USB corruption shows up for a bunch of different reasons, and the fix depends on what failed.
These checks usually tell you where you stand:
- Does the drive show up in Disk Management?
- Does Windows report the right size?
- Is the file system listed as RAW?
- Does Windows ask you to format it?
- If you plug it into another PC, does it appear there?
- Does it disconnect on its own, lag hard, or act weirdly slow?
Those details matter more than people think. If the drive appears in Disk Management and the capacity looks right, I’d say your odds for home recovery are still decent. If it keeps dropping connection, stays invisible, runs hot, or the plug looks bent up, I’d start thinking hardware trouble.
Get the files off first
If the system still detects the USB, I’d stop trying to repair it and pull data first.
I learned this the annoying way. Corruption is often the mess you see, not the root issue. A drive starts failing underneath, then every repair attempt pokes it again. Sometimes you get lucky. Sometimes you make the next scan worse.
So yeah, first move is data extraction. Repairs come later.
What I’d use
I’d go with Disk Drill.
The part I like for damaged or corrupted USB sticks is simple. It does not depend only on the file system staying readable. Even when Windows refuses to open the drive, Disk Drill often still reads the device at a lower level and pieces files back together from raw data.
A few things stood out for me:
- It recognizes a big list of file types
- Folder structure tends to survive better than with a lot of other tools I tried
- You get previews before recovery, which saves time when the scan returns a pile of junk names
The part worth using first
For shaky USB drives, the Byte-to-Byte Backup feature is the main reason I’d bother.
Instead of scanning a drive while it’s in bad shape, you make a full sector-by-sector image first. Then you work from the image, not the flash drive itself.
That matters if the USB gets worse halfway through. You still have a saved copy of its current state. I’ve had removable drives die mid-process before, and it sucks. If you image first, at least you are not starting from zero again.
The order I’d follow
- Install Disk Drill on your PC
- Plug in the USB drive
- Open Disk Drill and pick Byte-to-Byte Backup
- Create a full image of the USB and save it to a different disk
- Mount or attach the image inside Disk Drill
- Scan the image
- Preview the files
- Recover the important stuff to another storage device
I would not save recovered files back onto the same USB. Sounds obvious, but people do it.
After your files are safe, then repair the USB
Only once the data is copied elsewhere would I start trying fixes on the drive itself.
Depending on what you saw earlier, I’d try one of these:
- Run CHKDSK
- Give the drive a new letter
- Reinstall USB drivers
- Run Windows Error Checking
- Do a full reformat
If the corruption came from a bad file system and the hardware is still okay, one of those might clean it up. If the drive keeps failing after a format, I wouldn’t trust it again.
When I’d stop and look at pro recovery
There’s a point where DIY stops making sense.
I’d think about a professional service if:
- The drive is not detected at all
- It shows physical damage
- The files matter for work, legal stuff, taxes, client data, anything like that
- It disconnects while you’re trying to copy or scan
When a USB keeps dropping offline during recovery, I usually treat it like a bad sign. Same with heat. Same with a loose connector. You might still squeeze data out of it, but each retry risks making the next one worse.
Don’t assume the drive is worth keeping
One last thing. I wouldn’t feel any loyalty to the USB after recovery.
If corruption showed up for no clear reason, comes back after formatting, or the drive starts acting flaky in normal use, I’d replace it. Flash drives wear out. Some do it slowly, some fall off a cliff. Once one starts lying to you, I’m done with it.
Do not format it yet. That prompt is Windows asking to wipe the file system map. If the files matter, stop plugging it in over and over too.
I agree with @mikeappsreviewer on one big point, recover first, fix later. Where I differ is CHKDSK. I would skip CHKDSK until after the files are safe. On damaged flash media, CHKDSK sometimes “fixes” the directory tree by deleting entries it thinks are broken. Great for the drive, bad for your photos.
What I’d do:
- Try a different USB port, preferably on the back of a desktop or a diff laptop.
- Check Disk Management. If the stick shows the correct size, your odds are better.
- If it appears as RAW or unallocated, use recovery software, not Windows repair tools.
- Recover files to your internal drive or another external drive, never back to the thumb drive.
Disk Drill is a solid pick here. I’d use it for scan plus preview first. If the drive stays connected long enough, pull the most important docs and photos before anything else. Prioritize by file type and date. Family photos first, work docs next, random downloads last.
If Windows sees 0 bytes, the drive vanishes, or it gets hot, stop DIY. That points more toward hardware failure.
Also, file recovery video on Instagram, short and easy to follow here:
USB drive data recovery steps in this quick Instagram video
After recovery, replace the stick. Corrupted once is enough for me tbh.
