Is There A Free Way To Recover Files From RAW Hard Drive?
My external hard drive suddenly shows up as RAW, and I can’t open any of my files. It has important photos and work documents, and I’m trying to find a free RAW hard drive recovery method before I risk formatting it or paying for software. What should I do to recover data from a RAW drive safely?
Yep, I’d hold off on formatting it. That Windows popup, 'You need to format the disk before you can use it', usually means Windows lost track of the file system. It does not always mean your files are gone. I’ve seen RAW drives where the data was still sitting there, untouched, and the mess was only in the partition or file system metadata.
First thing I’d check is the drive’s behavior, before doing anything else.
  1. If it shows up normally in Disk Management, stays connected, and sounds normal, I’d try software recovery first.
  2. If it clicks, drops offline, freezes the system, or appears and disappears, I’d stop there and send it to a recovery lab. DIY on a failing drive is how people turn a bad day into a dead drive.
If this looks like file system damage and not hardware failure, I’d do it in this order:
  1. Stop writing anything to the drive.
  2. Pull the important files off first.
  3. Open a sample of recovered files and check they aren’t corrupted.
  4. Only then try repairs or reformatting.
  5. If you still trust the drive, put the files back later.
I’d start with Disk Drill. What stood out for me is it doesn’t stick to one recovery method. When enough of the original file system survives, it tends to recover files with names and folders intact. When the metadata is trashed, it falls back to signature scanning and looks for known file types directly on the disk.
The steps are plain enough:
  1. Install Disk Drill somewhere else, never onto the RAW drive.
  2. Pick the RAW disk or partition.
  3. Click Search for Lost Data. On an external drive, use Universal Scan if it asks. I’d only touch Advanced Camera Recovery for footage from cameras, action cams, or drones.
  4. Let the scan finish. Don’t stop halfway unless the drive starts acting weird.
  5. Preview files before restoring them.
  6. Recover them to a different disk.
If you want free tools, I’d look at TestDisk and PhotoRec.
  1. TestDisk is the one I’d try when there’s a chance the partition table or boot sector is the main problem. Sometimes it brings the volume back without forcing you to recover everything file by file.
  2. PhotoRec ignores the broken file system and scans by file signature. It works well from what I’ve seen, but the tradeoff is ugly. You usually lose original filenames and folder layout, so cleanup after recovery gets annoying fast.
One thing people skip, and then regret, is making an image first. If the drive feels shaky but still reads, a byte-for-byte image gives you room to breathe. If a repair tool makes things worse, you still have the image. Scan the copy, not the original. I’ve done this once on a flaky USB drive and it saved me from repeating reads on failing hardware.
After the files are safe, then I’d think about fixing the RAW partition. If the drive used NTFS before, CHKDSK sometimes helps. I still would not run it before recovery, since it writes changes to the file system and I’ve seen it make later recovery harder. If CHKDSK does nothing useful, I’d move to TestDisk. If that still gets nowhere, I’d recreate the partition in Disk Management, do a quick format, and copy the recovered data back.
One extra thing for SSDs. Don’t let it sit for days or weeks if you care about the data. TRIM can wipe deleted blocks in the background over time. A RAW volume does not always trigger it right away, but I wouldn’t wait around to find out. Earlier recovery attempts usually go better, espeically if you stop using the drive the moment you notice the problem.
Yes. Free RAW drive file recovery exists, but your best move depends on whether the drive is stable.
I agree with most of what @mikeappsreviewer said, but I would not jump into repair tools early. TestDisk is great when it works, but on a drive with important photos and work docs, I’d focus on extraction first, not repair. Get the files out, then mess with the partition later.
My order would be:
  1. Check SMART health with CrystalDiskInfo.
    If health is bad, or the drive disconnects, stop. DIY gets risky fast.
  2. Make a clone or image if the drive reads.
    Use HDD Raw Copy Tool or ddrescue if you know Linux. A clone gives you a second shot if the first scan goes bad.
  3. Try free recovery first.
    Windows File Recovery is free from Microsoft, but it’s command line only and kinda annoying. Still, for docs, JPG, PNG, ZIP, PDF, it does a decent job on damaged file systems.
  4. If free tools miss too much, use Disk Drill.
    It’s easier to sort results and preview stuff. On RAW volumes, that saves time. Recover to another drive, not the same one.
  5. Ignore CHKDSK until after recovery.
    People love to run it. People also regret it.
If you want a plain-English guide for RAW hard drive data recovery and file rescue from a RAW external drive, this helps:
watch this RAW drive recovery walkthrough
One more thing. If this is an SSD in an external enclosure, don’t wait too long. If it’s an old HDD, you’ve got a bit more breathing room. Do not format it yet. That popup is bait, lol.
Don’t format it yet. RAW usually means Windows can’t read the file system, not that the files instantly vanished. I mostly agree with @mikeappsreviewer and @sternenwanderer on that part, but I’m a little more skeptical about trying any “fix” too soon.
What I’d add is this: check the enclosure/cable before assuming the disk itself is toast. I’ve seen external drives show as RAW just because the USB bridge was acting dumb. Try another USB cable, another port, and if possible another PC. If it suddenly mounts normally, problem solved without poking the file system.
Also, if the drive is readable at all, grab a few sectors with something like HDDSuperClone or ddrescue first. Even a partial clone is better than repeatedly hammering the original disk. Free method, less risk.
For software, TestDisk/PhotoRec are the classic freebies, but they can be clunky and kinda brutal to sort through. If you want something easier to navigate, Disk Drill is worth a look for RAW hard drive recovery, especially for previewing photos/docs before restoring. Just don’t install it onto the bad drive.
One thing I would not do is assign too much faith to CHKDSK. People treat it like magic. It isn’t. Sometimes it “fixes” things by tossing metadata in the trash lol.
If you want a simple overview of how Disk Drill handles deleted and lost files, this Disk Drill recovery walkthrough and review explains it pretty clearly.
Short version:
  1. Stop using the drive
  2. Test cable/enclosure
  3. Clone if possible
  4. Recover files to another disk
  5. Repair/reformat only after your stuff is safe
If the drive clicks, disappears, or gets super slow, stop DIY stuff. That’s where “free” can get expesnive real fast.
