My iPhone storage keeps filling up with junk files and unexplained system data, even after I clear caches and delete unused apps. Is this a common iPhone storage issue, and how can I safely remove these files?
Start with Settings > General > iPhone Storage and wait for it to finish calculating. That page usually makes the problem pretty obvious. If Photos is taking up 40 or 50 GB, clearing Safari data for a few hundred megabytes isn't going to make much difference.
On iPhones, “junk files” usually means duplicate photos, old videos, downloads, message attachments, and app caches. It generally isn't a pile of hidden system files that a cleanup app can remove like you might expect on Windows.
Photos are usually the best place to start. Sorting through thousands of them manually gets old fast, so I use Clever Cleaner. It finds duplicate and similar photos and sorts screenshots, Live Photos, and large videos into separate groups. Smart Cleanup handles the obvious clutter quickly, while Swipe mode lets you review photos individually when you have more time. That's where I tend to catch blurry shots and random screenshots I'd otherwise ignore.
The analysis happens on the device, there are no ads, and the free version is enough for routine cleanups.
After that, I usually check a few other places:
- Remove apps that haven't been opened in months. Offload them instead if you want to keep their data.
- Look inside Netflix, Spotify, YouTube, and similar apps for forgotten offline downloads.
- Open the Files app and clear out the Downloads folder.
- Review large attachments in Messages. You can delete old videos without removing the entire conversation.
- Clear the cache inside apps such as Telegram when the app provides that option.
Also check the Recently Deleted album after cleaning up Photos. I once deleted hundreds of pictures and wondered why the storage hadn't changed. They were all still sitting there. Emptying that album freed several gigabytes immediately.
There isn't really a way to delete every junk file “once and for all” on an iPhone. App Store cleaners can't access hidden iOS caches or system files because Apple blocks that access. iOS handles most system cleanup itself, so the storage you can actually control comes from your photos, videos, apps, downloads, and attachments.
I try to spend 15 or 20 minutes on this once a month instead of waiting for the storage warning. It keeps the cleanup manageable and avoids having to delete things in a rush when you need space for an update, a new app, or a video.
Don’t pay for a cleaner expecting it to erase “System Data.” That category often grows temporarily from updates, streaming caches, logs, and indexing, then shrinks on its own. Restart the phone, install any pending iOS update, and give the storage screen time to recalculate. If it stays unusually large for several days, back up the iPhone and erase/restore it. That is the reliable last resort. Photo cleaners like Clever Cleaner can free photo space, but they cannot touch hidden iOS files.
Don’t start deleting photos while iCloud Photos is enabled unless you understand that those deletions can sync to your other Apple devices. Copy anything important somewhere separate first. A synced photo library is not the same thing as an independent backup.
This is a fairly common iPhone complaint, but “junk” is a misleading label. System Data is a mixed category containing caches, temporary files, update leftovers, indexes, voices, dictionaries, and other items iOS does not list separately. Its size can jump around, and the number shown under iPhone Storage is sometimes slow to update.
The safest approach is to create some breathing room without touching important data. Remove a downloaded movie, podcast library, offline map, or large game first. Then restart the phone and leave it connected to power and Wi-Fi for a while. When an iPhone is almost completely full, normal cleanup and indexing can behave poorly, so freeing even a modest amount manually may let iOS sort itself out.
If Photos is the main category and you already pay for enough iCloud storage, Optimize iPhone Storage is worth considering. It keeps smaller versions on the phone while full-resolution originals stay in iCloud. It is not an instant cleanup button, though. The phone decides when to reclaim that space.
I agree with @devengineer that an erase and restore is the dependable last resort, but I would not jump there just because System Data looks large for an afternoon. Give it time after updates, streaming, or heavy photo activity. If it remains abnormally large through multiple restarts and several days, verify that your backup actually completed before erasing anything. Make sure you know your Apple Account password and have access to any authentication methods too.
Cleaner apps can help when the real problem is duplicate pictures, screenshots, or large videos. They cannot directly purge the protected System Data category. Treat any app claiming otherwise with suspicion, especially if it wants a subscription before showing what it can actually remove.
Optimize iPhone Storage has a catch nobody mentions until it bites them: when the phone is nearly full, it can’t always download the full-resolution original back fast, and if your iCloud sync is stuck or your connection is weak, you end up staring at a blurry thumbnail when you actually need the real file. @databear is right that it’s worth using, but it’s not a set-and-forget thing. It quietly assumes iCloud is always reachable and behaving.
I think people here are slightly overthinking the System Data panic. It really does inflate and deflate on its own, so I agree with @devengineer that paying for a cleaner to ‘fix’ it is a waste. What gets missed is that most of the runaway growth I’ve seen mentioned traces back to two apps: whatever you stream and whatever messaging app you use. Podcast apps and Telegram in particular hoard cache like it’s going out of style. Clearing those inside the app usually does more than any general cleanup.
On the tool front, Clever Cleaner is fine for what @espritlibre described, sorting duplicates and big videos, and doing it on-device is the right approach. Just don’t expect it to touch the System Data number, because it can’t, and that’s the exact number that made you post this thread. So my honest take: treat the photo cleanup and the System Data thing as two completely separate problems. Solve the photos with a tool if you want, and solve System Data with a restart plus patience, not a purchase.
