Need advice on using Tangem Crypto Wallet securely
I just started using the Tangem Crypto Wallet to store some of my coins and I’m unsure if I set everything up correctly. I’m worried about backup, recovery, and how safe it really is compared to other hardware wallets. Can anyone explain best practices, common risks, and what I should double-check so I don’t lose access to my funds or get hacked
Short version first. Tangem is ok if you care about simplicity and are fine trusting their card hardware and app. It is weaker if you care about open source, independent backups, or long term self custody with no vendor trust.
Here is how to check your setup and improve security.
  1. Understand how Tangem works
  • Your private keys live on the card’s secure element.
  • The app talks to the card and shows balances, signs tx, etc.
  • By default, your seed phrase is not shown, so you do not write a 12 or 24 word phrase.
  • That design removes user error with seed storage, but increases dependence on Tangem’s hardware and your physical cards.
  1. Backup and redundancy
    You need at least 2 cards activated for the same wallet. If you only set up 1 card, fix that now.
  • Open Tangem app.
  • Go to your wallet.
  • Check if it shows 2 or 3 cards linked.
  • If it shows only 1, go to settings and add backup cards, then store them in separate physical locations.
    If your phone dies, you get a new phone, install the app, tap with any card, your funds show again. The backup is the extra card, not a phrase.
  1. What if Tangem disappears
    Critical point. With default setup and no exported seed, you rely on those cards and the app continuing to work.
    There is an option to export seed phrase for some configurations. If you want strong self custody long term:
  • Create a new Tangem wallet.
  • Enable seed export for that wallet if available in settings.
  • Export the seed once, offline, far from cameras.
  • Write it on paper or, better, stamp on metal.
  • Store it in a safe place.
    Then you can later import that seed into other wallets like Sparrow, Electrum, MetaMask, etc if Tangem dies or cards fail.
  1. Physical security of the cards
    Treat each Tangem card like a hardware wallet plus PIN.
  • Set a strong access code in the app. No 1234 or birthday.
  • Store primary card at home, not in your daily wallet, if funds are large.
  • Store backup card somewhere else.
    If someone steals your unlocked phone and your card, they can drain you. If they only get the card without your access code and phone, risk drops but do not depend on that.
  1. Compare Tangem to Ledger, Trezor, Coldcard
    General tradeoffs.
  • Tangem
    Pros: simple, NFC, no USB, no seed phrase by default, waterproof, tamper proof card format.
    Cons: more vendor trust, seed export not always ideal, closed secure element, harder for independent verification.
  • Ledger
    Pros: wide support, clear recovery process with 12 or 24 word seed, battle tested.
    Cons: closed source firmware, previous marketing data leak.
  • Trezor
    Pros: open source, standard BIP39 seed, good for people who like transparency.
    Cons: not a secure element, so different threat model. Needs more care with physical access.
  • Coldcard
    Pros: strong for Bitcoin, airgapped, PSBT, multi sig friendly.
    Cons: UX more complex, BTC focused.
If you hold large amounts or plan to hold long term, you might want either:
  • Tangem as spending wallet.
  • A different hardware wallet or multi sig setup as your cold storage.
  1. Recovery test
    Do not wait for disaster to learn if recovery works. Do a small test.
  • Send a small amount of crypto to your Tangem wallet.
  • Delete the app from your phone.
  • Reinstall the app on the same phone or another phone.
  • Connect the card, enter access code, verify your funds show.
    If that fails, fix it now, not after you lose a phone.
  1. Threat model basics
    Think through what worries you most.
  • Phone malware
    Tangem helps, since keys stay on card, but if malware tricks you to sign a tx on the card, you lose funds. Always check tx details in the app.
  • Physical theft
    Use strong access code, careful card storage, do not brag about holdings.
  • Vendor issues
    If you do not export a seed or use something like multi sig, you accept some vendor dependency.
  1. Concrete action checklist
  • Ensure you have 2 or 3 cards linked to the same wallet.
  • Set or change access code to something strong.
  • Decide if you want seed export. If yes, create a new wallet, enable it, move funds there, back up seed offline.
  • Do a recovery test with a small amount.
  • Separate daily spending funds from long term stack, use different wallets if needed.
If you share what coins you hold, how long you plan to hold, and your tech comfort level, people here can suggest a more specific setup, like multi sig or pairing Tangem with something else.
I’ll come at this from a slightly different angle than @waldgeist and try to stress-test Tangem a bit.
You basically have three separate questions:
  1. Did you set it up “right”
  2. How to not get wrecked if something breaks
  3. How “safe” Tangem is vs classic hardware wallets
1. Setup sanity check (different things to verify)
On top of what was already said, I’d double check:
  • Card count vs wallet count
    Not just “2 or 3 cards linked,” but how you’re using them.
    • Ideally: 1 wallet, 2–3 cards bound to that same wallet.
    • Not ideal: 3 separate wallets, 1 card each. Looks safer, is actually worse for recovery.
  • Per‑coin addresses
    Open your Tangem app and check if you’re reusing addresses for BTC or if it supports new ones. For privacy and safety habits, you really want to understand:
    • One seed, many addresses
    • Try not to dump all life savings into 1 visible address if you care about privacy.
  • Firmware & app source
    Check if your cards are on the latest firmware. Also, realize you’re trusting a closed ecosystem here. That’s not “wrong,” but it means you’re trading transparency for convenience.
2. Backup & recovery, but with failure scenarios
Instead of just “add more cards,” think in concrete disasters:
Scenario A: Phone lost / destroyed
  • Tangem is fine here. New phone, install app, tap card, done.
  • Real risk: phone + card stolen together. Then your access code becomes your line of defense. If it’s weak, tangem or not, you’re in trouble.
Scenario B: One card dies or is physically destroyed
  • If you have a second card bound to the same wallet, you’re ok.
  • I’d actually test this like a fire drill: pretend one card is gone and never use it. Force yourself to operate with only the backup card for a week and see if anything feels off.
Scenario C: Tangem goes out of business / app disappears
Here I disagree slightly with the “Tangem is ok if you just accept vendor trust” approach. That might be fine for small stacks, but for serious long term savings, depending entirely on a single vendor and proprietary app is too much risk for my taste.
If your card and app require their infrastructure to function at all, you’re basically using a nice-looking custodial shell. So:
  • If seed export is available for your card model and region, I personally treat not using it as a temporary compromise, not a long term plan.
  • If Tangem ever restricts export or makes it harder, you are stuck.
I’d be very systematic:
  1. Check if seed export is supported for your wallet.
  2. If yes, spin up a new wallet with export enabled.
  3. Move funds there.
  4. Export seed exactly once, offline, store it like any serious cold storage (metal, safe, etc.).
If export is not available for your current cards, I would seriously cap how much value you store there.
3. Safety vs other hardware wallets
Not repeating the classic Ledger / Trezor / Coldcard comparisons, but add a few nuances:
  • Tangem threat profile
    • Strong vs “I drop my wallet in a puddle” and “I don’t want to learn seed phrases.”
    • Weaker vs “I want transparent, auditable open source and standard BIP39 I can import everywhere.”
    • Also weaker if you worry about a black-box secure element that you cannot independently verify.
  • “No seed phrase” is both good and bad
    • Good: no rookie mistakes like photos of seed, typing it into cloud notes, etc.
    • Bad: you are locked into one security story: Tangem’s story. With a classic hardware wallet, you can switch apps, wallets, or even move to multisig with the same seed.
  • Long-term self custody
    Hardware wallets age. Vendors change policies, update terms, get acquired, disappear.
    A standard BIP39 seed = portable.
    A closed card with no export = non portable.
    In 5–10 years, portability matters more than “NFC is convenient today.”
4. What I’d actually do in your shoes
Assuming you’re not trying to LARP as an opsec ninja but also not willing to be reckless:
  1. Decide how much you’re comfortable trusting Tangem as a black box.
    If you feel even a tiny bit uneasy, treat Tangem as a spending / medium-term wallet, not a forever vault.
  2. Cap your exposure.
    • Example rule: no more than X% of total net worth or Y USD on Tangem.
    • The rest: a more standard hardware wallet setup with a visible seed and optional multisig if you go deep.
  3. Split role:
    • Tangem: daily use, test network, smaller holdings, quick on-the-go NFC spending.
    • “Serious” wallet: Ledger/Trezor/Coldcard or multisig with a known seed you control independently.
  4. Practice signing and rejecting transactions.
    Malware risk is not that your keys leak, but that you sign the wrong tx. Learn to read the prompts in the Tangem app and verify what you are actually sending and where.
  5. Document your process for your future self.
    Write down (offline):
    • “If I die / lose memory, here’s how to access this wallet”
      Because Tangem’s seedless UX that feels “simple” for you today might be extremely confusing for someone who inherits your coins later.
5. Quick checklist just to see if you’re mostly safe
  • At least 2 cards bound to the same wallet
  • Strong access code, not reused from other stuff
  • Funds amount matches your risk tolerance for vendor dependence
  • You’ve done at least one full recovery test (fresh phone, no cached app data)
  • You know whether you have an exportable seed and where that backup lives, or you consciously accept that you don’t have one
If you share roughly:
  • how much (ballpark, like “3–4 figures / 5 figures”),
  • which coins,
  • how long you plan to hold,
    people can help you dial in whether Tangem alone is enough or if you should pair it with something more traditional.
Short answer: Tangem is “secure enough” for many use cases, but only if you accept vendor dependence and you size your risk accordingly. I would not treat it as a single point of failure for serious long term savings.
Since @himmelsjager and @waldgeist already covered setup and recovery drills in detail, I’ll focus on a different angle: how to use Tangem safely as part of a broader setup and where I slightly disagree with them.
1. Don’t let “no seed phrase” make you lazy
Both replies correctly say Tangem removes seed handling mistakes. I’d add a twist:
  • That convenience encourages people to dump everything into one Tangem wallet.
  • With Ledger, Trezor, Coldcard, the annoying seed ritual pushes you to think like a custodian.
  • With Tangem, the mental model becomes “tap card, number go up.” That is nice UX, but it can quietly turn into “all eggs, one opaque basket.”
Practical tweak:
  • Treat Tangem as a card account, not as “my only vault.”
  • Decide a hard ceiling:
    • Example: “No more than 10–20% of my total stack on Tangem. Rest on a standard BIP39 setup.”
That way, if Tangem as a product ever goes sideways, you have limited blast radius.
2. Where I’d push harder than the other answers
They are right that multiple cards and a recovery test are essential. I’d go a step further on two points:
A. Vendor lock in is not just about bankruptcy
It is not only “Tangem disappears.”
Other realistic risks:
  • Policy change: firmware/app update that limits seed export or certain functions.
  • Geopolitical / regulatory issues: app pulled from a regional store, sanctions, KYC pressure, etc.
  • Ecosystem stagnation: 7 years from now, your coins are worth 50x and the only way to use them is reviving some old APK on a rooted phone.
This is why I strongly prioritize standard keys (BIP39) and multiple compatible wallets for large holdings.
If your current Tangem setup does not give you a seed you can import into a “normal” wallet, that is a hard line for what I store there.
B. Don’t overestimate “secure element magic”
Secure elements are good, but not invincible. Tangem, Ledger and others are all in the same general family here.
Your real risk for most home users is still:
  • Signing the wrong transaction
  • Social engineering
  • Weak access code + both phone and card stolen
So instead of obsessing only over card hacking, I’d:
  • Train yourself to read recipient and amount carefully before every confirmation.
  • Avoid signing when you are rushed or distracted.
  • Never approve transactions from “support” chats or random DMs.
3. Pros & cons of Tangem in plain language
Since you mentioned comparing with other hardware wallets, here is a sharper summary that complements what is already said.
Pros of Tangem:
  • Very easy NFC UX, almost contactless card behavior.
  • No visible seed phrase by default, fewer classic beginner mistakes.
  • Physically robust card format, pocketable, waterproof.
  • Good for:
    • Small to medium holdings
    • Mobile centric use
    • People who absolutely refuse to deal with seed words
Cons of Tangem:
  • Vendor dependence if you do not have an exported seed.
  • Closed secure element and app stack, low transparency.
  • Long term portability weaker than standard BIP39 wallets.
  • Inheritance and “explain to non technical family” are less intuitive without a clear written seed.
I actually like Tangem as a “crypto debit card with extra steps” rather than as a forever vault.
4. How I’d structure a safe overall setup
Taking everything from you, @himmelsjager and @waldgeist together, you could do this:
  1. Tangem wallet:
    • 2 or 3 cards tied to the same wallet.
    • Strong access code.
    • Only keep the amount you are comfortable losing if the whole Tangem ecosystem turned hostile or failed.
    • Role: daily / weekly spending, medium term stash.
  2. Secondary hardware wallet (competitors):
    • Ledger, Trezor, Coldcard, etc.
    • Standard 12/24 word seed, written and stored securely (preferably metal).
    • Role: long term, higher value holdings.
    • This is where you do not accept permanent vendor lock in.
  3. Optional:
    • Split stack by time horizon:
      • Short term: Tangem
      • Long term: classical hardware wallet or even multisig
This is less exciting than “just one cool NFC card,” but much more robust.
5. When Tangem alone is actually fine
I’d say a solo Tangem setup is reasonable if:
  • Your total crypto is in the low 3–4 figures, or whatever level you could tolerate serious friction recovering.
  • You are mainly experimenting, not parking life savings.
  • You have at least 2 cards for the same wallet and you have successfully done a full recovery test on a fresh phone.
  • You accept that if Tangem or its ecosystem gets worse, your main exit path might involve seed export (if available) or some workaround, not a clean UX.
If your stack is already 5 figures or you hope it will get there, I would not rely purely on any single vendor product, Tangem included.
Bottom line: your Tangem Crypto Wallet can be a solid part of your setup, but treat it like one account in a bigger security plan, not the center of your universe. The earlier you draw that line and size your exposure, the less you will worry about whether you “set everything up correctly.”
