Need help choosing a reliable crypto wallet tracker
I’m trying to find a reliable crypto wallet tracker to monitor multiple wallets and exchanges in one place, but the tools I’ve tried either miss transactions or don’t support some smaller chains I use. I need accurate, real-time balance tracking and clear history for tax reporting. What tools or setups are you using that actually work well, and what should I watch out for in terms of security and hidden costs?
I went through the same headache. Here is what ended up working for me with multi chain, multi CEX tracking.
  1. Step one. Decide your “source of truth”
    Use one of these as your main dashboard and plug everything into it:
  • DeBank
  • Zapper
  • CoinStats
  • Rotki
  • Zerion
My experience:
  • DeBank: Best for EVM chains. Tracks many small L2s and sidechains. Great for DeFi. Weak on CEXs.
  • Zapper: Good UI. Decent EVM support. Misses stuff on niche chains.
  • Zerion: Solid for portfolios. Focused on majors. Fewer obscure chains.
  • CoinStats: Strong CEX + majors. DeFi support ok. Smaller chains spotty.
  • Rotki: Local app, privacy focused, very accurate if you configure it, but more work.
If you care about:
  • Accuracy over convenience: Rotki
  • DeFi on EVM and some smaller L2s: DeBank plus manual checks
  • CEX + big chains in one place: CoinStats
  1. Track smaller chains
    Most trackers lag on small chains. I do this:
  • Use native explorers for each chain as backup
    Example:
    • Sol: Solscan, SolanaFM
    • Cosmos: Mintscan
    • Arbitrum, Optimism, Base: Etherscan forks
  • Add those wallets to DeBank or Zapper and check what they miss.
  • Keep a small spreadsheet with:
    • Date
    • Chain
    • TX hash
    • Amount
    • Type (trade, bridge, farm, etc.)
Boring, but it saves you later.
  1. CEX tracking
    APIs break a lot. What worked best:
  • Use API keys with read only access for:
    • Binance
    • Kraken
    • Coinbase
    • OKX
  • Plug those into CoinStats or Rotki.
  • Export CSV from each CEX monthly and store in a folder.
    When the tracker misreads something, cross check against CSV.
  1. Keeping it accurate
    Common issues and fixes:
  • Missing bridged assets
    Track the bridge TX hash and final token on the target chain.
    Some tools show “unknown token”. Still record the amount.
  • Airdrops and dust
    Many tools ignore tiny tokens. No big deal for PnL.
  • Staking and farming
    Some protocols use custom contracts. Track manually if:
    • Your rewards look off
    • APY in the tracker looks wrong
  1. Good combos that work well
  • DeBank + Rotki
    Use DeBank for fast daily view.
    Use Rotki for proper accounting and tax.
  • CoinStats + explorers
    Use CoinStats for “all in one”, then fill gaps with explorers and a sheet.
  1. Concrete suggestion for your use case
    Since you use smaller chains and need accuracy:
  • Start with DeBank as main view if you are heavy on EVM
    or CoinStats if you use many CEXs.
  • Add Rotki for serious tracking if your portfolio > mid four or five figures.
  • Keep a simple Google Sheet:
    Columns: Date, Chain, Wallet, TX hash, Type, Token, Amount, USD est.
After one or two weeks you will see which tracker misses the most.
Drop that one, keep the other combo.
If you list the exact chains you use, people here can point to specific tools that suport them better.
I’ll take a slightly different angle than @mikeappsreviewer here and focus more on how to choose instead of specific combos.
What you actually want sounds like:
  1. Multi chain coverage (including small / weird chains)
  2. Correct historical data (for PnL, tax, sanity)
  3. Something that does not break every time a CEX updates its API
A few points that might help:
1. Decide what matters more: “live view” vs “accounting”
Most “portfolio dashboards” are great for a pretty live snapshot but unreliable for proper records.
Most “tax/accounting” tools are ugly, slower, but much stricter on data.
If you care about accuracy first, look more at the “accounting-first” side: Koinly, Accointing, CoinTracking, CryptotaxCalculator, Rotki (which @mikeappsreviewer already mentioned).
If you care about live “what’s my net worth right now”, then Zapper / Debank / Zerion / CoinStats are fine as the surface layer.
My approach:
  • 1 main “pretty” dashboard for daily checks
  • 1 boring “accounting” backend that must be correct, even if the UI sucks
2. For smaller chains, stop expecting 1 tool to do everything
Most trackers are very opinionated: they focus on EVM + majors. If you are touching stuff like:
  • random Cosmos zones
  • niche L2s / sidechains
  • Solana, Sui, Aptos, etc.
    then the realistic way is:
  • Use native explorers and export or copy out data where possible
  • Prefer tools that let you import CSV or custom transactions
  • Avoid tools that are API only with no manual override, because you will get stuck when the API misses some protocol
Rotki and some web tools with custom transaction editing slightly win here. I actually disagree a bit with the idea that “spreadsheet is just backup.” For obscure chains, that sheet is the canonical source.
3. Test tools with a nasty sample, not your whole history
Take 10 to 20 transactions that are “hard mode” for trackers:
  • Bridging across chains
  • Liquidity pool in + out
  • Staking / restaking / weird airdrop claim
  • One smaller chain you actually use
Load those into any candidate tool and check:
  • Did it detect all tokens?
  • Did it assign the right type (trade vs transfer vs income)?
  • Does the balance match what explorers show?
If a tool fails that tiny test, do not trust it with the whole stack. Saves you hours of later cleanup.
4. Use “multiple sources of truth” but for different roles
Slight pushback on the single “source of truth” idea: in crypto, everything is flaky. APIs change, explorers change, protocols upgrade contracts. I treat it like this:
  • Chain explorer = technical ground truth
  • Accounting tool = financial truth (PnL, taxable events)
  • Dashboard app = UX truth (quick portfolio glance)
You reconcile them occasionally instead of pretending one app will always be perfect.
5. CEX problem: prefer tools that support file import history not just live APIs
You already know APIs miss stuff. When looking at tools, I’d check:
  • Do they let you upload CSVs from Binance / Coinbase / Kraken / etc. and keep that history, even if the API breaks?
  • Can you label transfers between CEX and wallet so they are not counted as trades?
If a tool only does “connect API and pray,” I’d skip it for serious tracking.
6. How to actually pick one now
Since you mentioned smaller chains and accuracy, I would do:
  • Pick 2 candidates from: Rotki, CoinTracking, Koinly, CryptotaxCalculator
  • Pick 1 nice dashboard from: Debank, Zapper, Zerion
  • Run that 10 to 20 “nasty sample” test on each
  • Keep whichever:
    • Matches explorer balances
    • Lets you fix errors manually
    • Exports your full data if you ever want to migrate
That last part is huge. If the app dies or starts charging insane fees, you want an export that another tool can read.
If you drop the exact chains you are using (e.g. “Arb, Base, Sol, some Cosmos chains, plus X/Y ZK chain”), people can usually point to very specific combinations that handle those better than the generic “one app to rule them all” stuff.
