Nikon Photo Recovery, What Software Has Worked For You?
I accidentally deleted photos from my Nikon camera’s memory card and I’m trying to recover them before they’re overwritten. I need recommendations for Nikon photo recovery software that actually works for deleted RAW and JPEG files on SD cards.
I had this happen on a Nikon, and the first thing I learned was boring but important. Stop using the SD card right away. No more shots. No video. Do not format it again. On most Nikon bodies, your photos sit on an SD card, so this isn’t some weird camera-only issue. It’s standard SD card recovery.
When you delete photos, the camera usually removes the file index first. The image data often stays there for a while until new files land on top of it. If the deletion was recent, your odds are often decent.
What I’d do first
Before installing anything, check whether the files already exist somewhere else. I’ve seen people spend an hour scanning a card, then remember they imported everything earlier. Look on your computer, external drives, old import folders, SnapBridge syncs, and any cloud backup you had turned on.
If there’s no backup, I’d start with recovery software. Disk Drill is one of the easier ones to use without fighting the interface. It reads Nikon photo formats like NEF, NRW, and JPEG. On Windows, it lets you recover up to 100 MB for free, which is enough for a small test run so you can see whether the card still holds anything useful.
Steps I’d follow
  1. Take the SD card out of the Nikon and plug it into your computer with a card reader.
  2. Install Disk Drill on your computer. Not on the SD card.
  3. Pick the SD card in the app, then click Search for lost data.
  4. Run Universal Scan. For deleted photos, this is usually the right starting point.
  5. Wait for the scan to finish, then preview what it finds. If the preview opens and looks normal, recovery tends to work.
  6. Save recovered files to your computer or another drive. Do not write them back to the same SD card.
If video files are missing too
Photos are one thing. Video is messier. Camera video files often break across the card in chunks, so a normal scan sometimes misses them or returns broken clips. If you lost videos too, I’d try Advanced Camera Recovery after the first scan. It’s meant for fragmented camera footage and sometimes pulls back files the standard pass skips.
If you want a free route
PhotoRec is still a good option if you don’t want to pay. I used it once on an old card and it found more than I expected, but the experience was rough. No preview. Filenames come back generic. Sorting the results feels like cleaning out a junk drawer. It works, though, if you have patience.
When I’d stop and not mess with it
If your computer doesn’t detect the SD card at all, or the card has physical damage, I wouldn’t keep poking at it. Same if it disconnects mid-read or asks to be formatted the second you insert it. At that point, a recovery shop usually has better odds than home tools.
So yes, deleted Nikon photos are often recoverable. I wouldn’t call it guaranteed. Still, if you quit using the card fast and scan it before new data overwrites the old stuff, you’ve got a real shot at getting the images back.
I’ve had better results with recovery apps that keep the original folder structure when possible, not only raw file carving. For Nikon stuff, NEF recovery gets messy fast if the card had lots of burst shots.
Disk Drill is worth trying first for Nikon photo recovery software, mostly because it handles NEF previews better than a lot of tools I tested. I don’t fully agree with @mikeappsreviewer on PhotoRec as a first free pick. It finds files, sure, but the no-preview workflow is a pain and you end up sorting hundereds of files by hand.
Two others I’ve used:
R-Studio, better if the card shows file system damage.
DMDE, ugly interface, strong results, cheap.
If you want a simple list:
  1. Disk Drill for deleted Nikon RAW and JPG.
  2. R-Studio if the card looks corrupted.
  3. DMDE if you want more control.
  4. PhotoRec if you have time and patience.
For search terms, think Nikon SD card photo recovery software for deleted NEF and JPEG files.
Also, this short clip is worth a look if you want a quick visual on recovery workflow, see a quick Nikon SD card recovery demo.
Big thing, recover to your computer, not back onto the card. Mess that up once and you learn fast.
I’d add one option the others didn’t really lean into: UFS Explorer. It’s not the prettiest thing on earth, but for cards that were deleted, half-corrupted, or came out of a camera after some weird write error, it’s been more reliable for me than PhotoRec. Less “dump 900 mystery files into a folder and pray,” more actual structure when the filesystem is still partly there.
I mostly agree with @mikeappsreviewer about stopping use of the card immediately, but I kinda disagree on going straight to the easiest app just because it’s easy. Ease is nice, sure. But if the photos matter a lot, I’d first make a byte-for-byte image of the SD card with something like USB Image Tool or even HDD Raw Copy Tool, then run recovery on the image, not the original card. That gives you a second shot if the first scan goes sideways. People skip this and then regret it later.
My order would be:
  1. Disk Drill if you want the fastest Nikon photo recovery software with decent preview support for NEF/JPEG.
  2. UFS Explorer if the card is acting odd or the first scan misses stuff.
  3. R-Studio if the partition/file system looks damaged.
  4. PhotoRec only if you’re OK with a messy result set.
One more thing people forget: some Nikon RAW files recover “successfully” but are partly corrupted, especially after burst shooting. So don’t just count files, actually open a few NEFs in NX Studio, Lightroom, or whatever you use. A recovered file isn’t always a usable file.
If you want a solid overview of SD card photo recovery tips for deleted Nikon files, that thread is worth skimming too.
Short version: Disk Drill is probably the best first try for deleted Nikon RAW photos, but if the images are really important, clone the card first. Tiny extra effort, way less risk. I learned that the annoyng way.
One small disagreement with @mikeappsreviewer and @techchizkid: I would not judge success by “files found” alone. With Nikon cards, especially NEF from burst shooting, the real test is whether the recovered RAW opens cleanly and shows the full frame without corruption.
My take:
  • Disk Drill is the best first pass if you want something fast and readable.
    • Pros: good preview support, easy filtering for NEF/JPG, simple workflow, decent at normal deletions.
    • Cons: free recovery is limited on Windows, deep scans can return duplicates, not my first choice for seriously damaged cards.
  • If the card mounts but looks weird, I lean toward UFS Explorer before PhotoRec. Better for partial filesystem recovery, less blind sorting afterward.
  • If the card is physically unstable, stop DIY and image it first, or hand it off.
I do agree with @cazadordeestrellas on one point: preserving folder structure matters more than people think. If your Nikon directory tree comes back intact, sorting the shoot later is way less painful.
So: Disk Drill first, but verify recovered NEFs in Nikon NX Studio before celebrating.
