SD Card Recovery On Mac, Is There A Way To Restore Files?
I accidentally lost photos and video files from my SD card while using my Mac, and I’m trying to figure out if there’s a safe way to restore them before they’re overwritten. I really need help with SD card recovery on Mac, including what recovery software or steps actually work for deleted or formatted files.
I’ve had to recover SD cards on a Mac a few times, and the route you take depends on what went wrong.
If you deleted files, your odds are often decent. A quick format is also recoverable in a lot of cases, since it usually wipes the file table first and leaves the underlying data sitting there for a while. A full format plus more use after the fact is where things start falling apart. New photos, copied files, app data, all of it eats into the old sectors. Hardware trouble is a separate mess. If the card keeps dropping off, runs hot, won’t mount, or macOS sees it inconsistently, software tools often won’t get you far.
The biggest screwup I keep seeing is people using the card after the loss. I did this once with a 32GB card from a camera, took maybe 20 more shots, and some older images were gone for good. On small cards, you run out of safe space fast.
On Mac, I’d start with Disk Drill. I’ve tried a bunch of recovery apps over time, including UFS Explorer and R-Studio. Disk Drill usually lands in the sweet spot for me. Easier to work with than the heavier tools, but still good at pulling files out of rough situations.
What I do looks like this:
  1. Plug the SD card into your Mac with a card reader
  2. Launch Disk Drill and pick the SD card from the list
  3. Start a full scan
  4. Wait until the scan finishes, don’t stop early
  5. Preview what it found
  6. Recover the files to a different drive, or to your Mac’s internal SSD
One part I keep coming back to is the preview feature. It saves time. Disk Drill handles a lot of camera file types well, including RAW formats, and it tends to do better with messy video files than some lighter apps I tested. If a photo opens cleanly in preview, or a video lets you scrub through without glitching, I’d take that as a good sign the recovery worked.
I also wouldn’t dump out 5,000 files in one shot. Grab a small batch first. Open the images. Check the videos. See if filenames are intact, see if the files are broken, see what’s usable. I learned this the annoyng way after waiting hours on a huge recovery job only to find half the clips were toast. Testing first gives you a better read on whether the scan found real data or junk.
First thing, stop using the SD card. Eject it. Put the lock switch on if your card has one. Every write cuts recovery odds.
I agree with @mikeappsreviewer on the main point, but I’d add one step before scanning. Make an image of the SD card first. Work from the image, not the original card. If the card starts throwing read errors, you want one stable copy to test with. On Mac, you can do this with Disk Utility or Terminal. If Disk Utility fails, the card might be degrading.
I also would not trust First Aid to “fix” the card before recovery. Sometimes it helps. Sometimes it rewrites file system data and makes recovery messier. I’ve seen people lose folder structure doing that. So I’d skip repairs until after you pull data off.
If you want an easy Mac option, Disk Drill is still one of the better picks for SD card recovery on Mac. Scan the card image if possible. Recover files to your Mac or an external drive, never back to the SD card. Start with your most important file types first, photos and video, then sort the rest later. Test a few recovered clips befor doing a huge export.
If the card disconnects, mounts off and on, or shows 0 bytes, software recovery gets shaky fast. At that point, a pro lab is the safer move.
For more solid SD card recovery software recommendations, this thread is worth a look:
best SanDisk and SD card recovery software options
Short version, yes, file restore on Mac is often possible if you stop use fast and don’t overwrite the card. Time matters a lot here, so dont keep poking at it.
Yes, there’s a way, but I’d do one thing a little differently than @mikeappsreviewer and @nachtschatten suggested. Imaging first is smart, sure, but if the card is behaving totally normal on your Mac, I usually check whether the missing files are just hidden in a weird folder structure before going straight into a long recovery session. Cameras and Macs sometimes leave a mess behind.
A few quick checks that don’t write much or anything meaningful:
  • look in Finder with hidden files visible: Command + Shift + .
  • check the DCIM folder and any LOST.DIR type folders
  • see if Image Capture or Photos can still detect thumbnails even if Finder looks empty
  • if you imported to the Mac at some point, also check the Photos library’s “Recently Deleted”
If the files are truly gone, then yeah, stop using the card and recover to another drive. Disk Drill is a solid Mac choice for SD card recovery because it’s easy to sort photos/videos by type and preview what’s actually usable. That part matters more than people think. A scan that finds 20,000 “files” is useless if half are corrupt garbage.
One thing I mildly disagree on: “full scan everything first” is not always the best use of time if you only care about JPEG, HEIC, MP4, MOV, or RAW files. On some cards, filtering hard by file type after scanning saves a lot of sanity. Less digital dumpster diving.
Also, if this was a microSD used in an Android, drone, or Switch, results can be worse because of fragmentation and the way video gets written in chunks. Photos usually come back easier than video. Thats just the annoying reality.
If you want extra reading on Mac recovery tools, this Reddit thread is decent:
best Mac file recovery software recommendations from Reddit
Short version: yes, SD card recovery on Mac is often possible, but every minute of continued use makes it worse.
