What SD card recovery software actually works?
I accidentally deleted photos and videos from my SD card, and now I’m trying to find reliable SD card recovery software that can actually get them back. The card was used in my camera, and these files are really important, so I need help choosing a safe recovery tool that works well and won’t cause more data loss.
I’ve had this happen, and yeah, the first second feels bad. You plug in the SD card, Windows or macOS throws a format message, or the folder opens empty and your photos are gone. If the card isn’t physically wrecked, I’d still try software before paying a recovery shop. I did, and it saved me a stupid amount of money.
You wanted tool picks, so here’s the short list I’d give someone who needs results instead of a giant software dump.
  1. Disk Drill
This is the one I’d start with for most cases. I used it on both Mac and Windows, and the layout didn’t fight me. The big thing is camera media. A lot of recovery apps do fine with simple files, then fall apart on RAW photo sets or big video files from action cams, drones, or mirrorless bodies. You end up with a file name, a file size, and a clip you can’t open. Useless.
Disk Drill handled those cases better for me because it has camera-focused recovery for fragmented footage. On cards used in GoPros and similar gear, files often get split up across the card. Some tools pull back pieces. This one did a better job rebuilding something playable.
You get a free scan and preview, which matters. I don’t buy recovery software blind. On Windows, there’s also a 100 MB free recovery limit, so you get a small real-world test before paying.
  1. CardRecovery
Windows only. Old interface. Kinda dated. Still, I’ve seen it work fine for plain photo and video recovery from memory cards.
If you want a simple step-by-step wizard and you care mostly about JPEGs, common RAW formats, and video clips, it’s worth a look. It’s narrower than the others. No docs, no PDFs, no broad file type hunting. Also, no free recovery tier from what I saw, only a preview scan before purchase.
  1. Recuva
This is the free one a lot of people try first on Windows. Fair enough. It’s easy, quick to install, and you get unlimited free recovery.
I’d keep expectations low if the card is damaged at the file system level. When an SD card shows up as RAW, acts corrupted, or came out of a camera full of large fragmented files, Recuva often misses the mark. For basic accidental deletion on a healthy card, sure. For messier cases, I’d move on fast.
If you’re going to try recovery, the process matters as much as the app.
  1. Stop using the card
This part is boring and it matters most. Deleted or formatted data usually sits there until new data lands on top of it. I’ve seen people keep shooting, then run recovery later and wonder why half the files are gone. They got overwritten. Once that happens, you’re done.
If your SD card has the little lock switch, slide it over now. It’s not magic, though it helps stop new writes.
  1. If the card is unstable, image it first
If the card disconnects, freezes File Explorer, throws read errors, or makes your system hang, don’t keep hammering it with repeated scans. I made this mistake once. Bad idea.
Make a byte-for-byte image first if your recovery app supports it. Disk Drill does. Then scan the image file instead of the card itself. This takes pressure off failing hardware and lowers the chance of the scan dying halfway through.
  1. Do not recover back onto the same SD card
I know this sounds obvious. People still do it. I almost did it the first time because I was tired and clicking too fast.
Save recovered files to your computer’s internal drive or another external drive. If you write recovered data back to the same card during recovery, you risk overwriting the files you’re still trying to pull off. Then you get to be mad twice.
My rough order would be this:
If the card had camera footage or RAW photos, start with Disk Drill.
If you’re on Windows and only care about standard media files, CardRecovery is still one of those old tools people forget about, though it works.
If you want free and the card seems mostly healthy, try Recuva first.
Use a decent card reader, not the flaky one from the bottom of a drawer. Plug the card in, scan it, and don’t rush clicks. I did recover stuff this way, and the main thing was staying off the card once I noticed the problem. That part made the differece.
I’d rank them a bit differently than @mikeappsreviewer.
For pure SD card photo and video recovery, PhotoRec still deserves a shot. It’s ugly, but it pulls files from damaged or reformatted cards better than a lot of polished apps. Downside, filenames and folders are often gone, so sorting the mess is a pain.
If you want something easier to use, Disk Drill is the one I’d put first for most people. Better previews. Better filtering. Better odds with camera files in my expereince. Ease matters when you’re stressed and trying not to click the wrong thing.
R-Studio is another one worth knowing. More technical. Better for cards with busted partitions or weird file system damage. If simpler tools fail, this is where I’d go before paying a lab.
My rough order:
  1. Disk Drill, best mix of results and usability.
  2. PhotoRec, best free deep recovery tool.
  3. R-Studio, best if the card looks corrupted.
  4. Recuva, only for simple deletions.
Also, if your camera used exFAT and shot large 4K clips, cheap tools often recover junk files or broken videos. That’s where better software earns its price.
For a quick visual guide, this SD card photo and video recovery tutorial is short and easy to follow.
If the card still mounts, stop testing random apps and start with one solid scan. Too many rescans on a dying card is how people make it worse.
If the files were just deleted and the card is still detected normally, I’d actually separate “what works” by scenario instead of looking for one magic app.
@mikeappsreviewer and @hoshikuzu already covered the usual picks, but I’d push one thing a little differently: Recuva is fine, but people recommend it way too often for camera cards. For DSLR, mirrorless, GoPro, drone, etc, I’ve seen it recover a lot of half-useful junk. Great for a USB stick, less impressive for serious SD card photo recovery.
My order would be:
  1. Disk Drill
    Best balance of easy UI, previews, and actual recovery quality for photos/videos. If you want the safest first shot without fumbling around, this is probly the one. Especially solid for SD card recovery on Mac and Windows.
  2. PhotoRec
    Still one of the strongest free options when the card is messed up bad. Ugly as sin, no folder structure, filenames usually trashed, but it can dig up files other tools miss.
  3. R-Studio
    Not beginner-friendly at all, but very good if the SD card has partition damage, RAW issues, or weird corruption.
One extra point nobody mentions enough: if your camera writes RAW+JPEG, some apps recover the JPEGs fine but choke on the RAW sidecars or larger video files. Check previews carefully before paying.
Also, this roundup on SD card recovery software that actually performed well in real tests is worth skimming if you want a quick compare list instead of installing five things blindly.
Short version: start with Disk Drill, use PhotoRec if you want free/deeper recovery, use R-Studio if the card looks truly borked. Don’t keep experimenting too much if the card is acting flaky, because that’s how recoverable turns into not recoverable real fast.
I mostly agree with @hoshikuzu and @sternenwanderer, but I’d push back a little on PhotoRec as a first move unless you’re already comfortable sorting recovered chaos. For important camera media, my first shot would still be Disk Drill.
Why Disk Drill first
  • Pros: very good previewing, usually handles photo/video file types from cameras better than bargain tools, simple enough that you’re less likely to make a bad click under stress, can work from a disk image.
  • Cons: not the cheapest option, deep scans can take a while, and on badly fragmented video it is still not magic.
Where I differ from @mikeappsreviewer a bit: I would not bother much with CardRecovery unless the case is very basic and Windows-only. It feels too narrow now.
My practical ranking:
  1. Disk Drill for the best all-around SD card recovery software experience.
  2. R-Studio if the card is showing partition/file system damage and you don’t mind a steeper learning curve.
  3. PhotoRec if you want free and you’re willing to deal with lost filenames/folders.
  4. Recuva only for simple delete mistakes on a healthy card.
One extra thing people skip: if your recovered videos come back but won’t play, that does not always mean the recovery failed. Camera files can be partially intact but need repair afterward. So judge by file size and previews, not just whether VLC opens everything instantly.
If the card is still detected normally, Disk Drill is the safest first recommendation in my book.
