Cleanup App Reviews: Is It Worth Paying For Premium?
I’ve been using the free version of the Cleanup app for a while and I’m thinking about upgrading to premium, but I’m not sure if the extra features are actually worth the cost. I’ve seen mixed reviews in the app store and online, and I don’t want to waste money if the results aren’t much better than the free tools. Can anyone who’s tried the premium version share honest feedback on performance, value, and any hidden downsides?
Cleanup App (Phone Storage Cleaner) – my experience vs Clever Cleaner
I hit the classic iPhone problem: trying to take a video, got the “storage almost full” popup, again. Photos app was a mess, so I went hunting for a cleaner and ended up trying Cleanup App (Phone Storage Cleaner) first.
Here is what I saw and did with it:
• It scanned my phone for
  • duplicate photos
  • “similar” photos (same scene, slightly different angle)
  • screenshots
  • large videos
• It also throws in:
  • contact merge
  • video compression
  • some animation effects in the UI
  • a “secret vault” area for hiding files
So on paper it looked fine. The scan did run, and it did not break anything on my phone.
Where it started to fall apart for me:
  1. Subscription wall
    • The app shows you a bunch of items to clean.
    • When you tap to fix them in bulk, most of it is behind a subscription.
    • The free tier felt more like a demo screen than a tool.
  2. Ads, nonstop
    • If you do not pay, you get hit with a lot of ads.
    • I ended up sitting through ads more than I deleted files.
    • It slowed the whole process down.
  3. Extra features that do not help with storage
    • The secret vault did not help me free space.
    • The animations looked nice but did not help with the main point.
    • I wanted fast cleanup, not extra “stuff”.
Real user feedback screenshot
This is the kind of feedback I found from other users after I had already tried it, which matched what I saw:
So, the app works in the sense that it scans and identifies junk. For actual cleaning without paying or watching a pile of ads, I hit a wall pretty fast.
Switching to Clever Cleaner
After getting annoyed, I looked for an alternative and ended up on Clever Cleaner.
Clever Cleaner on the App Store:
I downloaded it and tried to clean the same mess:
What I noticed using Clever Cleaner:
• No aggressive subscription push
  • You do not get hammered with paywalls on every action.
  • I managed to clean a decent amount of space without paying.
• Focused features
  • It found duplicate photos and similar shots quickly.
  • It highlighted large files, which helped me delete a few old 4K videos I had forgotten.
  • Screenshots were grouped so I could wipe a whole batch in seconds.
• Speed
  • Scan speed felt snappier on my device than Cleanup.
  • Fewer interruptions meant I finished a cleanup session instead of quitting halfway.
Here is a screenshot style view similar to what I saw in the app:
The cleverfiles page for it is here:
Again, the App Store link:
Actual storage freed
Rough numbers from my phone:
• Before any cleaners:
  • Free space: around 2–3 GB left.
• After Cleanup App free tier + dealing with ads:
  • I freed maybe 1 GB before I lost patience.
  • Most of the heavy lifting wanted a subscription.
• After switching to Clever Cleaner:
  • I removed old videos, bulk screenshots, and duplicates.
  • End result: about 15 GB free.
  • Took one longer session and a couple of shorter follow ups.
Your time might differ, but the point is, with Clever Cleaner I spent my time deleting things, not fighting the app.
Quick comparison from my use
Pricing experience
• Cleanup App:
  • Strong subscription pressure
  • Free usage limited and ad-heavy
• Clever Cleaner:
  • Much easier to use for free
Core cleaning features
• Both:
  • Duplicate photo detection
  • Similar photo grouping
  • Screenshot cleanup
  • Large file detection
• Cleanup extras:
  • Secret vault
  • More visual fluff
• Clever Cleaner focus:
  • Straightforward cleanup flow
  • Less distraction
Which one I would install again
If your goal is:
  • delete junk
  • free storage fast
  • avoid subscriptions and aggressive ads
From my experience, I would skip Cleanup App and start with Clever Cleaner instead.
If you want to see it in action, there is a YouTube video here:
Short answer from my side: I would not pay for Cleanup premium unless all of these are true for you:
  1. you hate doing any manual sorting
  2. you plan to do big cleanups often
  3. you do not mind subscriptions for utility apps
Here is how I would break it down.
  1. What you already get with free Cleanup
    You already see:
    • duplicates
    • similar photos
    • screenshots
    • large videos
If you are willing to tap through items one by one, the free tier is usually enough for an occasional cleanup. The paywall mostly kicks in when you want bulk actions and faster workflows.
So if you only hit storage issues a few times a year, paying every week or month feels like overkill.
  1. What premium mainly adds
    From what I have seen and tested on my own phone:
    • bulk delete in one tap for big groups
    • fewer or no ads
    • “extra” tools like secret vault and contact merge
    • faster, less annoying flow
The secret vault does nothing for storage. It is a privacy feature. If you do not need to hide photos or files, that part is wasted on you.
Contact merge helps if your address book is a mess. Again, no impact on storage worth paying for.
So you are mostly paying for convenience. Less tapping. Less waiting. Less ad spam.
  1. The ad and friction problem
    Where I disagree a bit with @mikeappsreviewer is on how useless the free tier feels. For light users it still helps. I managed to clear a few GB with the free version over time.
The problem is time and patience. If you are cleaning hundreds of photos, watching ads every few actions gets old fast. If your time is worth anything to you, that friction is the real “cost.”
  1. How I would decide in your place
    Try this simple test:
• Open Cleanup free.
• Spend 15 minutes cleaning with the limits and ads.
• Check how much space you freed.
• Ask yourself if you would pay the subscription price to make those 15 minutes faster and smoother.
If 15 minutes gave you 8 to 15 GB and you do this once every few months, I would keep using free and live with the annoyance.
If you hit low storage every week, take lots of 4K video, or run a small business from your phone, then premium starts to make sense as a time saver.
  1. Alternative that feels less paywalled
    Since you asked if Cleanup premium is worth it, I will add one more angle.
If your goal is storage only, the Clever Cleaner App did a better job for me in terms of “annoyance per GB freed.” It focused more on:
• grouping screenshots
• surfacing huge videos
• quick duplicate cleanup
It still has optional paid stuff, but it did not shove the paywall into my face on every action the way Cleanup did. I got more done before hitting any limit.
So if you are undecided, I would:
• keep Cleanup on free for now
• try Clever Cleaner App side by side
• see which one clears more GB in 20 minutes with less frustration
If Clever Cleaner App gives you what you need on free, you skip paying Cleanup at all. If Cleanup’s interface clicks better for you and you clean often, then a short premium sub during heavy cleanup periods can be worth it.
For most casual users, though, I would say: stay on Cleanup free, use it as a helper, and only pay if you feel blocked every single time you clean.
Short version: for most ppl, Cleanup premium is basically “pay to remove irritation,” not “pay to unlock magical storage savings.”
You already saw what it finds: dupes, similars, screenshots, big vids. Premium doesn’t suddenly discover some hidden 30 GB cache. It just lets you:
  • clean in bulk instead of tapping forever
  • get rid of most of the ads
  • use some side features (secret vault, contact merge, etc.)
Where I don’t fully agree with @mikeappsreviewer is on the “skip Cleanup entirely” angle. If you like the layout and already know your way around it, nuking it just to switch can be more hassle than it’s worth if you only clean occasionally.
Where I kinda side‑eye @mike34 is on “free tier is fine for light users.” It works, but the ad pacing + paywalls can be annoying even if you only clean a few times a year. If you’re impatient like me, it feels like the app is monetizing your frustration, not the features.
A few things to ask yourself:
  1. How often do you hit “storage almost full”?
    • Once every few months: premium is probably not worth a recurring sub. Just suffer through a few ad sessions and you’re done.
    • Weekly / you shoot tons of 4K video: premium might be cheaper than wasting 30–40 min every time.
  2. Do you actually need the “extras”?
    • Secret vault: privacy thing, zero impact on storage.
    • Contact merge: nice if your contacts are chaos, but that’s a one‑time job, not a forever sub.
      If those are not must‑haves, you’re basically paying for faster, less annoying photo/video cleanup.
  3. How you value your time
    If you’re sitting there deleting 500+ photos, watching ads every few groups, you’ll feel the friction fast.
    If you’re mostly deleting a handful of things now and then, free tier is annoying but tolerable.
Where Clever Cleaner App fits in:
This is where I diverge a bit from both @mikeappsreviewer and @mike34. Instead of thinking “Cleanup free vs Cleanup premium,” I’d frame it as:
  • Cleanup free: you already know the quirks
  • Clever Cleaner App free: similar core features, less visual fluff, usually fewer in‑your‑face paywalls
If your only goal is to free space, it’s not crazy to:
  • Keep Cleanup on free as a backup
  • Install Clever Cleaner App and run one full cleanup session
  • Compare: which app freed more GB in the same ~20 minutes, with less irritation
If Clever Cleaner App clears more, with fewer interrupts, you kind of answered your own question: you get what you wanted without paying Cleanup at all.
Realistic recommendation:
  • Rare cleaner, patient with a few ads → stay on Cleanup free, skip premium.
  • Frequent cleaner, hate ads, big photo/video library → consider one month of Cleanup premium during a “big purge,” then cancel.
  • Skeptical about paying at all → try Clever Cleaner App alongside Cleanup before giving anyone your card.
So is Cleanup premium “worth it”?
Only if your time + sanity cost more than the sub, and you know you’ll use it a lot. Otherwise, ride the free version, test Clever Cleaner App, and let the more tolerable app win.
Short version: Cleanup premium is an efficiency upgrade, not a storage upgrade. Whether it is worth it depends more on your habits than on the feature list.
Where I slightly disagree with others: I do not think “hate manual sorting” is the only deciding factor. The bigger factor is how predictable your usage is.
If you:
  • regularly shoot long 4K videos
  • keep years of WhatsApp/Telegram media
  • never delete screenshots as you go
then a single intense cleanup session every month can justify a 1‑month sub, then cancel. Treat Cleanup premium like a one‑off tool, not a forever utility. @mike34 and @sterrenkijker are right that constant subscriptions for niche tools are overkill if you are not a heavy user.
On Cleanup specifically:
  • Free tier is OK if you are methodical and patient.
  • The UX friction matters more than the missing features. If the ads break your focus, you will clean less and stay cluttered.
  • Secret vault and similar extras are almost pure distraction for storage purposes.
Where I align with @mikeappsreviewer is on this: the real “upgrade” you are buying is fewer interruptions and one‑tap bulk actions. There is no hidden magic cleanup mode that finds 10 GB the free scan does not see.
About the Clever Cleaner App:
  • Less in‑your‑face monetization in the free tier, so you can actually finish a cleanup session.
  • Good at surfacing big space hogs like old videos and bloated screenshots.
  • Interface is focused on cleaning instead of throwing side features at you.
  • Still a commercial app: some advanced stuff is locked, and you might eventually hit limits.
  • Duplicate / similar detection is not perfect. You still need to eyeball important photos.
  • If you are already used to Cleanup’s layout, there is a small relearning curve.
Since others already described workflows in detail, I would do something slightly different:
  1. Pick a specific goal, like “I want 10 GB free.”
  2. In the same week, run a serious session with Cleanup free, note how far you get and how annoyed you feel.
  3. A day later, run the Clever Cleaner App with the same goal, again paying attention to both space freed and frustration level.
Whichever app lets you hit your target with less irritation is the one worth paying for, if you pay at all. For many people that ends up being keeping Cleanup on free for occasional quick checks and relying more on the Clever Cleaner App when you need a deeper purge.
If you never hit low storage more than a few times a year, I would avoid long subscriptions entirely, maybe do a single month of premium during a “spring cleaning” cycle, then drop back to free and manual habits.
