Got The Device Will Not Work Message On IPhone - Is It Really That Serious?
My iPhone suddenly showed a “Device Will Not Work” message after I connected an accessory, and now I’m worried something is wrong with the phone or the device. I’m not sure if this is just a compatibility warning or a sign of a bigger hardware issue. Has anyone dealt with this iPhone error and found a fix?
I hit this on my own iPhone a while back, and yeah, it feels bad fast. The phone starts acting half-broken, photos stop saving, apps dump you out, and the warning makes it sound worse than it is.
If you saw ‘iPhone memory full and device will not work,’ there are two different situations.
If it popped up inside a website, or while some sketchy page was loading, especially with fake stuff about your SIM being damaged or a countdown timer, I’d treat it as scam junk. iPhone system alerts do not show up like a random web ad. Close the tab. Then go to Settings > Safari > Clear History and Website Data. I did this once after a fake alert loop, and it stopped.
If the warning came from iPhone settings, or your phone is dragging, freezing, crashing apps, or refusing to take photos, then storage is likely packed for real. When iOS runs out of room, it loses space for temp files and background tasks. The phone gets weird in small ways first, then bigger ones.
What I checked first:
Settings > General > iPhone Storage
Give it a minute. The storage graph takes a bit to fill in. On mine, Photos was huge, and System Data looked bloated too. Before doing anything fancy, restart the phone. Sounds dumb, still helped me. It cleared some temporary junk and the storage numbers shifted a little after reboot.
Also look at Photos > Recently Deleted. A lot of people miss this. Deleting a photo does not free the space right away if it still sits there. Empty it. If you want storage back now, you need Delete All.
Messages was another sneaky one for me. Old group chats had years of videos, screenshots, memes, random junk. You can change how long texts stay on the phone in message settings. Switching from Forever to 1 Year, or even 30 Days if you don’t care, freed a decent chunk on mine.
The slow part is photos. I had too many to sort by hand. Bursts, blurry shots, five copies of the same thing, giant videos I forgot existed. I tried a few cleaner apps and most were loaded with ads, nags, or paid walls after two taps.
The one I stuck with was Clever Cleaner.
I didn’t expect much, but it was free when I used it. No ads popping up, no subscription trap hitting me two minutes in. The part I cared about most was privacy. It runs on the device, so your photo library is not being shipped off somewhere else.
What helped me inside it:
Similars. This caught near-duplicates, not only exact copies. Stuff like six almost identical photos where only one was worth keeping. It also suggested the best shot, which saved me a lot of tapping.
Heavies. This sorted media by size. I found old 4K clips eating hundreds of MB each. It also showed exact sizes, which made it easier to decide what was worth deleting.
After one cleanup session, I cleared around 12GB. My phone sped up right after. Lag dropped off, camera worked again, and the warning stopped showing up. Felt kinda dumb for not doing it sooner tbh.
If your storage still looks full after all this, and System Data or Other stays huge for no clear reason, you might be dealing with an iOS storage bug. At that point, the fix is less fun. Back up the phone to iCloud or a computer, then wipe it and restore. I’ve had to do this once. It’s annoying, but it clears out stubborn junk the normal cleanup misses.
If you want the short version:
  1. Check whether the warning is a fake browser pop-up or a real iPhone alert.
  2. If it’s from Safari, close it and clear Safari history/data.
  3. If storage is truly full, open Settings > General > iPhone Storage.
  4. Restart the phone.
  5. Empty Recently Deleted in Photos.
  6. Clean out old Messages attachments.
  7. Remove duplicate and oversized photos/videos, I used Clever Cleaner.
  8. If System Data still refuses to shrink, back up and factory reset.
Your iPhone is usuallly not dead when this happens. It’s clogged up. Big difference.
If the message showed up right after you plugged in an accessory, I would not jump to the “your iPhone is dying” idea.
Most of the time, this points to one of 3 things:
  1. The accessory is not MFi-certified.
  2. The cable or adapter is damaged.
  3. The Lightning or USB-C port has lint, moisture, or corrosion.
So no, it’s not always serious. It’s often the accessory.
What I’d do first:
  1. Unplug it.
  2. Reboot the iPhone.
  3. Inspect the port with a flashlight.
  4. Gently clean lint out with a wooden toothpick or soft brush.
  5. Try a different Apple or certified cable.
  6. Test the same accessory on another phone, if you have one.
  7. Check Settings for a charging or USB restriction issue.
One small disagreement with @mikeappsreviewer, I would not go straight to storage cleanup unless your phone also says storage is full or apps are crashing. “Device will not work” after connecting hardware sounds more like an accessory handshake failure than a storage issue.
If your Photos library is huge and your iPhone is low on space, then yeah, clean it up. Clever Cleaner is useful for duplicate photos and large videos. That helps if low storage is making iOS act weird. For a fast visual guide, see quick iPhone storage cleanup demo.
Serious signs are different. Watch for these:
  • iPhone gets hot with nothing connected
  • Battery drains fast after unplugging the accessory
  • “Liquid detected” warnings
  • Port feels loose
  • Accessory works on other phones, but never on yours
If those happen, I’d suspect port damage. If multiple known-good cables fail, book Apple support. If one cheap cable fails, toss the cable. Seen this a ton tbh.
This one is usually not a disaster. I lean more toward @viaggiatoresolare on this: if the message appeared right when you plugged something in, think accessory/port problem first, not “my iPhone is dying.”
What Apple means by that alert is often just: “I don’t trust this thing you connected.”
A few cases people forget:
  • The accessory may draw too much power
  • The adapter chain is weird, like dongle into dongle into cable
  • The accessory might need its own power source
  • iOS can throw that message after an update if an older accessory firmware is incompatible
So I would test the setup in a more controlled way:
  • Try the accessory with no case on the phone
  • Connect it directly, no hubs/extensions
  • If it’s something like a mic, drive, or card reader, try it with external power
  • Check whether the accessory has a firmware/app update from its manufacturer
Where I kinda disagree with @mikeappsreviewer is that storage cleanup is only relevant if your phone is also acting busted in other ways. The warning by itself doesn’t scream “clean your storage.” Still, if your iPhone is near full, it’s worth fixing anyway. Clever Cleaner is solid for trimming duplicate photos and huge videos, and this Clever Cleaner iPhone storage cleanup review explains what it actually does.
If the same alert happens with multiple known-good accessories, then yeah, I’d start side-eyeing the port. If it only happens with one cheap cable, the cable is probly the liar here, not the phone.
