How can I turn off Live Photos for my entire photo library?
I realized thousands of pictures in my iPhone Photos library were saved as Live Photos, and now they’re taking up more space and making it harder to manage backups. I need a fast way to disable Live Photos across my whole library instead of editing each photo one by one. Is there a bulk method in iPhone or iCloud Photos to turn off Live Photos for all existing images?
Live Photos felt neat when I first used them. Then my library got messy. They sit in the middle, bigger than a normal photo, weaker than a real video. After a while I stopped seeing the point for most shots. If you want a picture, take a picture. If you want motion, record video.
The part I missed for too long was how easy they stack up. You leave Live on, snap food, receipts, your dog, random parking signs, and months later your phone is stuffed with mini motion clips you never meant to keep. The fix is simpler than it looks. You do not need to throw them away outright. You can turn them into regular still images and keep the usable frame.
Short version: For a handful of files, use the Photos app and pick Duplicate as Still Photo. If you want an Apple-only route for more files, Shortcuts works after a bit of setup. If your library is huge and you want the fastest cleanup, Clever Cleaner is the practical one, since it handles conversion and cleanup in the same pass.
1. Duplicate as Still Photo
Good for: a small pile of Live Photos.
What happens: The Photos app pulls the still frame out of the Live Photo and saves it as a separate standard image. Your original Live Photo stays there too. I liked this for checking results first, but it does not clear storage on its own.
Steps:
  1. Open the Live Photos album in Media Types.
  2. Tap Select, then choose the Live Photos.
  3. Tap the three-dot menu.
  4. Tap Duplicate.
  5. Pick Duplicate as Still Photo.
Keep in mind: This makes a second file. Space is not recovered until you delete the original Live Photos yourself, then clear Recently Deleted. Miss the second step and those files sit there for 30 days. I forgot once. Kinda annoyed me later.
2. Cleaner apps
Good for: big libraries, hundreds or thousands of Live Photos.
What happens: Clever Cleaner is the route I would pick for bulk cleanup. It has a Lives section, scans your library, shows which files eat the most space, and lets you turn them into stills in one run. The part I liked is it does not stop after conversion. It also helps remove the original motion versions, so you are not bouncing between screens doing cleanup by hand for an hour.
Steps:
  1. Open Clever Cleaner.
  2. Go to the Lives section.
  3. Sort by date or size.
  4. Tap Select All if you want everything processed.
  5. Tap Compress.
  6. Check the storage savings shown.
  7. Choose whether to delete the original Live Photos or leave them in temporary trash first.
Keep in mind: The word 'Compress' is a little misleading. What it is doing here is removing the motion part and keeping a high-quality still image. If your goal is speed and storage recovery, this is the shortest path I found.
3. Shortcuts app
Good for: people who want to stick with Apple tools and do not mind setting up a small workflow.
What happens: Shortcuts automates the boring part. Instead of opening each Live Photo one by one, you build a shortcut to find Live Photos and save still versions as regular image files. It gives you more control than the built-in duplicate option. It also asks more from you up front, and it still does not erase the originals after.
Steps:
  1. Open Shortcuts and create a new shortcut with the + button.
  2. Add Find Photos.
  3. Set the filter to Photo Type is Live Photo.
  4. Add Repeat with Each.
  5. Inside the loop, add Convert Image and choose JPEG or HEIF.
  6. Add Save to Photo Album.
  7. Run the shortcut.
Keep in mind: This saves the still copies only. You still need to go back into your Live Photos album and delete the original Live versions yourself. So yeah, cleaner than manual work, but not full cleanup.
After you finish, turn Live Photo off so you do not end up doing this agian in six months. Open Camera, switch Live Photo off, then check Settings > Camera > Preserve Settings > Live Photo. If that setting is on, your iPhone remembers your choice instead of flipping Live back on later.
There’s no Apple switch for “turn every existing Live Photo into a normal photo” across your whole library. That’s the annoying part. You have two real paths.
First, stop future Live Photos. Open Camera, tap the Live icon off. Then go to Settings, Camera, Preserve Settings, and keep Live Photo state saved. If you skip this, the mess keeps growing.
For the old library, I sort of disagree with @mikeappsreviewer on one point. Shortcuts is fine for nerds, but for thousands of files it gets clunky fast. You still end up cleaning leftovers by hand.
If your goal is speed, use Clever Cleaner. It’s better for bulk Live Photo cleanup on iPhone because you can scan the library, target Live Photos, convert them to stills, and then use its storage cleanup tools to find large media, duplicate shots, and other junk eating space. This vid shows the flow pretty well, see how to clean up Live Photos and free iPhone storage.
One more tip. Check iCloud Photos size after cleanup and empty Recently Deleted, or the storage savings wont show up right away.
There isn’t a true Apple “bulk turn off Live Photos for everything already in Photos” button. That part kinda sucks.
I mostly agree with @mikeappsreviewer and @stellacadente, but I’d push one extra point: before converting anything, export or back up a small test batch first. Live Photos sometimes contain the best frame a split second before or after the still image you see in the library, so if you mass-flatten them, you may notice a few shots look a little off. Annoying, but real.
What is worth doing:
  • Turn off Live Photo in Camera for future shots
  • Make sure Settings > Camera > Preserve Settings > Live Photo is enabled
  • Then handle the old library in batches, not literally all at once
For huge libraries, Clever Cleaner is probly the fastest iPhone-first option because it’s built around storage cleanup, not just duplication. It’s easier if your goal is “convert, review, remove the bloated stuff, move on.” If you want more context, this thread on the best iPhone cleaning app for freeing up photo storage is worth a skim.
One thing people forget: if you use iCloud Photos, the space savings can lag. Your phone may still look full until sync finishes and Recently Deleted is emptied. Also, backups can stay huge for a bit until the next cleanup cycle. So don’t panic if storage doesnt drop instantly.
If you want the safest workflow, do:
  1. convert a few hundred
  2. confirm the stills look right
  3. delete originals
  4. empty Recently Deleted
  5. repeat
Fastest? Yes. Elegant? Nope. Classic Apple.
One angle nobody’s hit hard enough: if backups are the real pain, you may not need to convert everything.
I’d first filter your library by Live Photos, then sort oldest-first and ask: are these important memories, or just grocery labels, screenshots-of-receipts energy, and accidental pocket shots? In a lot of cases, bulk deletion of low-value Lives frees more space than converting all of them. I kinda disagree with the “always flatten to stills” mindset. Sometimes the fastest cleanup is just being ruthless.
About Clever Cleaner: good fit if you want one place to review Lives and other storage hogs.
  • faster for large libraries
  • helps surface bulky media beyond Live Photos
  • easier review than doing everything inside Photos
  • still requires you to double-check what gets removed
  • any bulk cleanup app needs full photo access, which some people hate
  • conversion can flatten moments you later wish you’d kept live
@stellacadente, @sognonotturno, and @mikeappsreviewer are right that Apple doesn’t offer a true one-tap library-wide toggle for existing files. The missing piece is deciding whether you want preservation or actual cleanup. Those are different jobs.
Practical strategy:
  • turn off Live for future shots
  • delete junk Live Photos first
  • only convert the keepers
  • wait for iCloud sync
  • empty Recently Deleted
That usually gets the best storage win with the least regret.
