I recently switched to an Android phone and I’m totally lost on how to access my voicemail. On my old phone there was a dedicated button, but on this one I can’t find anything that clearly says voicemail. I’m worried I might be missing important messages from work and family. Can someone walk me through the steps or let me know if I need to set something up with my carrier first?
On Android they kind of hide voicemail compared to old phones, so you’re not crazy. Here are the main ways to get to it.
Try long‑press on 1
• Open the Phone app.
• Go to the Dialpad (number pad icon).
• Press and hold the 1 key for a couple seconds.
• If voicemail is set up, it dials your voicemail number.
• If it says “voicemail not set up”, your carrier needs a quick setup. -
Check the voicemail icon in the Phone app
• Look at the bottom for “Voicemail” or an icon that looks like two circles with a line.
• On some phones it is under the “Recents” or “Call history” tab as a separate section.
• Tap it to see visual voicemail if your carrier supports it. -
Use the notification
• If someone already left a voicemail, pull down the notificaton shade.
• You often see “New voicemail” there.
• Tap it. That jumps straight into voicemail or the voicemail dialer. -
Check Phone settings
• Phone app → three dots menu top right → Settings.
• Look for “Voicemail”.
• There you see:
– Voicemail number (the number you dial, often already filled in).
– Visual voicemail toggle, if your carrier supports it.
• If the voicemail number is blank, call your carrier or search “[Your carrier] voicemail number” and enter it. -
Carrier specific quick dial codes
Rough guide in the US
• Verizon: press and hold 1, or dial *86.
• AT&T: press and hold 1, or dial your own phone number.
• T‑Mobile: press and hold 1, or dial 123.
• Google Fi: press and hold 1, or dial your own number.After it connects, follow the voice prompts. Usually it asks you to set a PIN and greeting.
If long‑press 1 does nothing
• Go to Phone → three dots → Settings → Voicemail → Voicemail number.
• Type the correct number from your carrier.
• Save.
• Try long‑press 1 again. -
Visual voicemail apps
Some carriers install their own voicemail app.
• Check your app drawer for “Voicemail”, “Visual Voicemail”, or a carrier‑branded app.
• Open it, accept permissions, and it should sync messages as a list you tap on. -
As a last step, reset Phone app
If stuff is buggy:
• Settings → Apps → Phone.
• Storage → Clear cache.
• Do NOT clear data unless your call history being reset is ok.
• Then try long‑press 1 again.
Once you find which method works, it stays consistent. Most Android users end up using either long‑press 1 or the Voicemail tab in the Phone app.
On Android, voicemail feels like a scavenger hunt, so you’re not imagining it.
@vrijheidsvogel already covered the usual stuff like long‑pressing 1 and poking around the Phone app, so I’ll skip repeating that and add a few extra angles that might help:
- Check if your carrier even has visual voicemail on your phone
Some Androids show no voicemail tab at all if your carrier doesn’t support visual voicemail on that specific model or plan. In that case, you’ll only ever get the old‑school “call in and listen” type.
Quick test:
- Open the Phone app
- Hit the three‑dot menu → Settings
- If there is no “Visual voicemail” option anywhere, your phone might only use call‑in voicemail with your carrier.
- Your voicemail might be in a separate app from the Phone app
Carriers love to hide voicemail in their own app and not tell anyone. Look in your apps list for stuff like:
- “Visual Voicemail”
- Your carrier’s name + “Voicemail” or “Phone”
Sometimes it’s disabled: - Settings → Apps → See all apps
- Scroll, find anything with “Voicemail” in the name
- If it’s disabled, enable it and open it from the app drawer.
- Try calling your own number from your phone
This works on a lot of carriers when long‑pressing 1 is broken or not configured:
- Open Phone
- Dial your own mobile number and call
- When it hits your voicemail greeting, hit the key it tells you (often
*or#) to access the mailbox - If you’ve never set it up, it should walk you through PIN + greeting
- If you’re not getting voicemail at all
If people say they left messages but you never see or hear anything, that’s a different issue:
- Turn off Wi‑Fi calling temporarily (Settings → Network → Wi‑Fi calling) and have someone call and leave a voicemail again
- Also check Call forwarding: Phone app → three dots → Settings → Calling accounts / Call settings → Call forwarding. If everything is forwarded to another number, voicemail may be bypassed.
- Use a third‑party voicemail service if your carrier’s setup sucks
If your carrier voicemail is a mess or you can’t get the visual stuff to show up, you can use something like:
- Google Voice (US only, mostly)
- Other voicemail replacement apps that give you a new visual voicemail inbox
These usually involve: - Installing the app
- Letting it “take over” voicemail by changing your conditional call forwarding (like “if busy, forward to this number”)
It sounds scary but is reversible in the app’s settings.
- Quick sanity check to see if it’s a “you” problem or a “phone” problem
Borrow another phone and call your number:
- Let it ring out and see if you hear a voicemail greeting at all
- If there’s no greeting and the call just drops: voicemail not provisioned on your line → call your carrier
- If there is a greeting but your phone never shows messages or notifications: likely a phone/app setup problem
If you’re worried you already missed important messages: once you figure out how to call your voicemail (even if it’s the ugly audio system), it will play every stored message in order, even the ones that didn’t pop up on your screen. So they’re usually not lost, just hiding like everything else on Android.
Two extra angles that often get missed with voicemail on Android:
1. Notifications & “silent” voicemail problem
Sometimes voicemail is actually working, but your phone is hiding all signs of it.
Check notification channels:
- Open Settings → Apps → Phone.
- Tap Notifications.
- Make sure things like Voicemail, Missed calls, or similar channels are:
- Enabled
- Not set to “Silent”
- Allowed to show on lock screen and status bar
On some skins (Samsung, Xiaomi, etc.) you have to open each individual notification category and turn on sound/vibration manually. This is why people think “voicemail is broken” while it is just muted.
Also check:
- Settings → Sound & vibration → Do Not Disturb
Make sure voicemail or “Calls from anyone” is not being blocked.
I slightly disagree with relying only on “open the Phone app and look for a voicemail icon” like many guides suggest. If the notification channel is off, you will never know messages are there even if the icon exists.
2. SIM or profile issue after switching phones
Since you just switched phones, there is a good chance the line itself is the problem, not Android.
Quick tests:
Test your SIM in another phone
- Put your SIM into any other phone (old Android, iPhone, spare device).
- Call your number from another line.
- Let it ring out and see if voicemail kicks in and if that other phone actually shows a voicemail indicator.
If voicemail behaves normally there, you know the issue is with the new phone’s setup, not the carrier.
Check if voicemail was deprovisioned
Sometimes when you change device or plan, the carrier silently removes voicemail from your profile.- Call your carrier support and ask them specifically:
- “Is voicemail provisioned on my line right now?”
- “Is visual voicemail enabled for my device model?”
This is different from just asking “Why is voicemail not working?”
Reset network / carrier settings
On many Android phones:- Settings → System → Reset options → Reset Wi‑Fi, mobile & Bluetooth (wording varies).
This often forces fresh voicemail configuration from the carrier.
Be ready to re‑enter Wi‑Fi passwords afterward.
I know @vrijheidsvogel already covered the more common stuff like long pressing 1 and inspecting the Phone app settings, which is useful, but in practice the SIM / carrier flag is what bites people right after a phone switch.
Brief note on “How To Check Voicemail On Android” type guides
A lot of generic “How To Check Voicemail On Android” tutorials online just repeat the same three tricks: long press 1, visual voicemail tab, and call your own number. Those help if voicemail is already correctly set up. They do nothing when the problem is carrier provisioning, muted notification channels, or a broken SIM profile.
About third‑party voicemail apps
If every carrier‑side check passes and you still hate the default interface, visual voicemail or a separate voicemail app is a reasonable move:
- Nicer interface and organization of messages
- Often better transcription than some carriers
- Easier to manage old messages, search, or export audio files
- Depends on data and app permissions
- Can break if the app stops being maintained or your OS updates
- Needs conditional call forwarding to be set, which some people find confusing
Even if you use a third‑party option, still verify your base carrier voicemail works at least once, so you know messages are not being swallowed at the network level.
If you do just two things:
- verify voicemail is actually provisioned on your line, and
- check the Phone app’s voicemail notification channels and Do Not Disturb,
you will usually uncover whether you truly “have no voicemail” or it is simply being silenced or hidden by Android’s settings.
