How To Clean Up IPad To Run Faster Without A Factory Reset?
My iPad has gotten really slow lately, and apps keep lagging, freezing, or taking forever to open. I want to speed up iPad performance and free up storage without doing a factory reset because I still need everything on it. What are the best ways to clean up an iPad, clear space, and improve speed safely?
If your iPad feels weirdly slow while the battery still says 100%, I’d look at a few boring but important things before touching reset.
Full battery does not mean full performance
I learned this the annoying way. Charge level and battery condition are not the same thing. An iPad might be topped off, but the battery itself might be worn enough to struggle when the system asks for more speed.
Check it here: Settings > Battery > Battery Health.
Look at Maximum Capacity. If it has dropped under 80%, iPadOS sometimes pulls performance down to avoid random shutdowns. So yes, a fully charged iPad still might feel sluggish.
Also, check for Low Power Mode. If the battery icon is yellow, the iPad is intentionally running slower. Turn it off if you want normal speed back.
Why video apps are the first place you notice lag
I usually narrow it down to two things.
First, Wi-Fi. Bad Wi-Fi often looks like device slowdown when it’s only the stream failing to keep up. Try the same app on another network. If the stutter disappears, the iPad was not the problem.
Second, storage. This one bites harder.
On iPadOS 16 and newer, iPads lean on something called Virtual Memory Swap. Storage gets used like extra memory during heavier jobs, including video playback. If your storage is packed, the system loses breathing room. Then video starts hitching, scrubbing gets choppy, and app switching feels off.
Why low storage drags down the whole iPad
Once storage gets to around 80% full, things tend to go downhill. Not in a dramatic way at first. More like keyboard delay, slow app swaps, weird pauses, little hangs.
iPadOS needs open space for cache files, swap, and background tasks. When you squeeze all of that out, the system starts tripping over itself.
Typing lags. Apps reopen slower. Video apps complain first, but the slowdown spreads everywhere.
  1. I opened the Heavies tab first. Biggest files were right at the top with exact sizes. Old screen recordings and giant videos were doing most of the damage, and I didn’t have to dig through the Photos app for half an hour.
  2. Then I checked Similars. It grouped near-duplicate photos and picked a Best Shot for each set. Burst junk and repeat tries went out fast. Kinda nice, tbh.
  3. Screenshots was the part that got me. Every screenshot showed its size before deletion. I had way more storage tied up there than I thought. Dumb mistake on my end.
  4. Everything stays on the device. Nothing gets sent off somewhere else.
After clearing about 10GB, the iPad felt better across the board. Not magic. Still, the lag dropped in video apps first, then the rest of the system started feeling less sticky.
Settings worth changing before you do anything drastic
  1. Turn off Background App Refresh. Go to Settings > General > Background App Refresh. I’d shut it off fully, or leave it on for only the apps you care about. Too many apps poking servers all day adds up.
  2. Restart the iPad. Simple fix, still works. Temporary memory gets cleared, hung processes die off, and things often smooth out. I try to do it once a week, give or take.
  3. Clear Safari data. Go to Settings > Safari > Clear History and Website Data. Safari slows down on its own when old browsing data piles up.
  4. Turn on Reduce Motion. Go to Settings > Accessibility > Motion, then enable Reduce Motion. Less animation means less graphics work. You notice it most on older models.
About iPadOS updates
I wouldn’t avoid updates only because you think they’ll slow the iPad. Sometimes people sit on old versions for months and end up with more bugs, worse stability, and no fixes.
Apple rolls performance and stability patches into updates pretty often. One thing though, right after a major update the iPad may feel slower for a while because it is reindexing stuff in the background. I’ve seen it take close to a day. If it feels off right after updating, wait 24 hours before calling it broken.
Skip the factory reset. Start with the stuff people miss.
  1. Offload apps you barely use. Go to Settings, General, iPad Storage. Tap big apps, choose Offload App. This keeps docs and data, removes the app itself. Better than deleting if you still need your stuff.
  2. Delete old Messages attachments. Settings, General, iPad Storage, Messages. Review Photos, Videos, GIFs, Stickers. This area gets bloated fast and most ppl never check it.
  3. Trim Downloads in Files. Open Files, Downloads, On My iPad, and iCloud Drive. Large ZIPs, PDFs, videos, and duplicate docs sit there forever.
  4. Clean Mail. If you use the Mail app with large attachments, remove old mail accounts and re-add them, or delete giant threads. Cached mail data grows over time.
  5. Turn off widgets you do not need. Too many home screen widgets keep pulling data. Same for live weather and news panels.
  6. Check app-specific junk. Netflix, YouTube, Spotify, podcast apps, editing apps. They store offline files and cache inside the app. Clear downloads from inside each app.
I partly disagree with @mikeappsreviewer on one thing. Background App Refresh is not always the main villain. On newer iPads, bloated app storage and bad app caches are usally the bigger issue.
If photos are the main problem, use Clever Cleaner. It helps remove duplicates, similar shots, screenshots, and large videos without wiping the iPad. This guide is decent too, watch how to clean iPad storage and speed it up.
Aim to keep 10 percent to 15 percent storage free. If your iPad is 64GB, try to leave 6GB to 10GB open. iPadOS runs smoother when it has room to work. That one change fixes a lot of lag tbh.
I’d actually add one thing neither @mikeappsreviewer nor @byteguru really stressed enough: find the one broken app.
Sometimes the whole iPad feels slow, but it’s really just 1 or 2 apps going feral in the background. Social apps, cloud drives, note apps with giant libraries, and editing apps are famous for this. Go to Settings > Battery and look at battery usage by app over the last 24 hours / 10 days. If one app is eating a stupid amount of background activity, delete it and reinstall it. That often clears corrupted cache without touching the rest of your stuff.
A few other things I’d try:
  • Disable automatic downloads for apps and updates if you have multiple Apple devices. Constant syncing can make older iPads feel kinda sluggish.
  • Check free RAM behavior manually. Open a bunch of apps, then close the worst offenders and test again. If one specific app causes the freezing, that’s your culprit.
  • Remove old VPNs or device profiles in Settings > General > VPN & Device Management. I’ve seen leftover profiles cause weird lag and network hiccups.
  • Reduce Spotlight indexing load. Settings > Siri & Search, then turn off Search for apps you never search for. Not a miracle fix, but on older iPads every little bit helps.
  • Review accessibility features. Some stuff like heavy zoom filters or motion effects can weirdly add overhead if a lot is enabled.
I kinda disagree with the idea that Background App Refresh is always worth obsessing over. On a lot of iPads, the bigger real-world issue is junk files, bloated media, and one misbehaving app.
If your storage is cluttered with similar photos, large vids, and screenshots, Clever Cleaner is probly the easiest shortcut before going nuclear. Also found a solid discussion here about cleaning up iPhone and iPad storage without ads or paywalls.
Also, check Analytics Data under Privacy & Security > Analytics & Improvements > Analytics Data. If you see the same app name crashing over and over, there’s your answer. That step gets ignored way too much tbh.
I’d check thermal throttling too, because that gets ignored a lot. If the iPad is warm during charging, gaming, video calls, or while restoring/syncing, iPadOS can slow everything down on purpose. Take the case off, stop charging for a bit, close the heavy app, and test performance again. A hot iPad often feels “storage slow” when it’s really heat slow.
Also, I don’t fully buy the idea that you should immediately start deleting tons of stuff. If lag showed up suddenly, I’d look for sync overload first:
  • Photos syncing a huge library
  • iCloud Drive uploading/downloading a lot
  • Notes reindexing attachments
  • Files app pulling large folders from cloud services
Open Settings and see whether iCloud sync is actively hammering the device. Sometimes waiting for that to finish helps more than any cleanup.
Another overlooked fix is browser tabs. Not just Safari history. If you keep absurd numbers of tabs open in Safari or Chrome, memory pressure gets ugly fast. Close them in batches.
One more: disable automatic app updates temporarily if the iPad is older. Background installs plus indexing can make it feel constantly busy.
On the photo side, Clever Cleaner is useful if your camera roll is the main mess.
  • fast for duplicates, screenshots, similar shots
  • easier than manually hunting through Photos
  • good for reclaiming space without wiping data
  • mainly helps media clutter, not every kind of slowdown
  • you still need to review results so you do not remove something important
  • won’t fix a buggy app, bad Wi-Fi, or battery wear
So yeah, @byteguru, @chasseurdetoiles, and @mikeappsreviewer covered the common storage angle well, but I’d add: check heat, syncing, and tab overload before assuming the whole iPad needs major cleanup.
