I’m trying to make changes to a PDF on my Mac, like correcting text, adding notes, and signing forms, but Preview feels really limited and confusing. I’m not sure if I should use built‑in tools or download another app. What’s the easiest and safest way to fully edit a PDF on macOS without messing up the formatting?
Preview is fine for notes and signatures, but not for real text editing. Here is the breakdown.
- Use Preview for quick stuff
Open PDF in Preview, then:
- Correct text: you cannot edit existing text directly. You fake it.
- Tools > Annotate > Rectangle. Draw a white box over the wrong text.
- Tools > Annotate > Text. Type the correct text on top.
- Adjust font with View > Show Markup Toolbar, then the “A” button.
- Add notes:
- Tools > Annotate > Note. Click where you want the sticky.
- Or use Text annotation for inline comments.
- Sign forms:
- Click the signature icon in the Markup Toolbar.
- Create signature with Trackpad or Camera.
- Click to place, drag corners to resize.
- Fill forms:
- If it is a fillable form, click fields and type.
- If not, use Text boxes on top of blank spots.
- Use Apple’s Free “Preview + Shortcuts” trick if you edit often
If you keep doing the white-box trick:
- Create a white rectangle and a text box once.
- Then Copy and Paste them where needed in the same file.
- Gets faster after a while, but it is still a hack.
- Use free third party for real text edits
If you need to edit existing text like a Word file, Preview will fight you.
Good free options:
- LibreOffice Draw
- Open LibreOffice, choose Draw, then open the PDF.
- Click text you want to fix and type.
- Export as PDF again.
- Works best on simple PDFs, not on heavy scanned ones.
- PDF Expert trial
- Has clean text edit, highlight, notes, signatures.
- Paid after trial. Good if you do this daily.
- For scanned PDFs or photos of documents
Your PDF might be a set of images, not text.
- On macOS Sonoma or newer, open in Preview.
- Use Live Text. Select text in the image, copy, paste into Pages or Word.
- Or use online OCR sites, then bring the text into a word processor, edit, export to PDF.
- Simple setups by use case
- You fill and sign forms sometimes
- Stick with Preview. Use Text boxes and Sign tool.
- You need to correct small typos sometimes
- Preview white-box trick or LibreOffice Draw.
- You edit PDFs every day for work
- Pay for a proper editor like PDF Expert or Adobe Acrobat. Free tools waste time at that point.
If Preview feels confusing:
- Turn on the Markup Toolbar from the toolbar button with the little pen tip.
- Hover over each icon to see its name.
- The important ones are Text, Shapes, Highlight, Note, and Signature.
That is about as smooth as it gets on a Mac without going into paid pro software.
Preview is limited, but I wouldn’t write it off completely. I partly disagree with @caminantenocturno on the “white box” trick as a real solution: it works in a pinch, but it’s messy, breaks if the layout changes, and can look janky when printed.
Here’s how I’d split it up without repeating all their steps:
1. Decide what kind of “editing” you actually need
Just filling & signing forms
Stick with Preview. It’s built in, private, and more than enough for:- Typing in form fields
- Dropping in a saved signature
- Quick highlighting / underlining
If you hate the toolbar clutter:
- In Preview, go to
View > Customize Toolbarand remove everything except Markup, Sign, Text, Highlight. Makes it way less confusing.
Commenting & reviewing PDFs (like a coworker sent you a draft)
Instead of faking edits with white boxes, treat the PDF like a shared doc:- Use highlights + notes only, and tell the other person “edits are in comments.”
That way you are not pretending the PDF is fully revised when it’s actually covered in patches.
2. When you really need to change the text
If you must actually change what’s inside the PDF, Preview is the wrong tool. Personally, I think the time you spend fighting it is worth more than installing a better app.
Different routes:
You rarely do this
- Use LibreOffice Draw like @caminantenocturno said, or
- Convert the PDF to another format:
- Open in Google Docs (File > Open > Upload)
- Let it convert to a Google Doc, fix the text, then export back to PDF
Layout might shift, but for simple docs it’s faster than hacking it in Preview.
You do this every week or daily
At this point, free hacks are a false economy.- PDF Expert, Adobe Acrobat, Nitro PDF Pro for Mac are the usual suspects.
- Acrobat is heavier but has the most reliable text editing and OCR.
- PDF Expert is nicer to use, in my opinion, if you just want “click text, type, done.”
3. For scanned PDFs / photos
Here I diverge from the “copy text out, edit elsewhere” approach a bit:
- On macOS with Live Text:
- Use it to verify what’s written, but not as your main editing step.
If the doc is important or official, I’d:
- Run it through proper OCR (Adobe Acrobat, PDFpen/Nitro, or an online OCR tool).
- Get a searchable PDF.
- Then edit in a proper PDF editor or export to Word/Pages.
Relying only on Live Text + copy/paste is asking for little hidden recognition errors that you only notice after sending it to someone important.
4. Simple decision tree
Need to fill/sign a form occasionally
→ Preview, cleaned-up toolbar, done. -
Need to mark up / suggest edits, not actually change the final PDF
→ Preview comments & highlights, or send a note “see annotations only.” -
Need to properly edit text in layout
→ LibreOffice Draw or Google Docs conversion for rare use.
→ Dedicated editor (PDF Expert / Acrobat / Nitro) if this is part of your job.
So: built in tools are fine for signing and notes. If you’re trying to treat a PDF like a Word file on a regular basis, don’t torture yourself with Preview and the white rectangle trick. Just bite the bullet and use an actual PDF editor.
Skip the toolbar gymnastics for a second and think about workflow instead of tools.
Where I disagree slightly with @caminantenocturno is on trying to bend “generic editors” like LibreOffice Draw or Google Docs into full-on PDF editors. They’re great escape hatches, but if you keep doing this, you’re basically rebuilding a broken process every time.
Here’s how I’d approach it from a more practical angle:
1. Make Preview less awful (but accept its ceiling)
You already know it feels limited; that is not just you.
Use Preview for what it’s truly good at:
- Quickly opening random PDFs
- Basic markup: highlight, underline, strike-through
- Filling existing form fields
- Dropping in signatures
Two tricks that are underrated and do not involve the white-box hack:
Precision with text boxes
When you add a text box, useView > Show Rulersand align things visually. It still won’t be “real” editing, but it at least avoids chaos. -
Use “Export as PDF” often
After a round of edits or annotations, export a new PDF instead of repeatedly saving over the same one. Cuts down corruption and random weirdness.
But once you need:
- Fonts to match exactly
- Text to reflow properly
- Tables to remain aligned
Preview is not the answer.
2. Pick a “middle ground” tool instead of jumping straight to a heavy editor
Rather than going immediately to full Acrobat, consider a lighter dedicated PDF editor as your “daily driver.”
You mentioned being unsure about installing another app. If you decide to, look for something that:
- Opens quickly
- Lets you click text and type
- Handles simple OCR if you deal with scans
The title you mentioned, How To Edit A Pdf On Mac, actually works better as a mental checklist than just a search term. Ask of any tool:
- Can I correct text directly on the page?
- Can I annotate comfortably?
- Can I sign and reuse signatures?
- Can I handle occasional scanned documents?
Use that checklist when comparing apps in the store.
Pros for sticking close to that “How To Edit A Pdf On Mac” mindset instead of random tools:
- You stay focused on core use cases instead of shiny extra features
- You can swap between different apps without relearning the basics
- Easier to find help, since most guides and tutorials map to those same tasks
- You may overlook niche features like advanced forms or automation
- Power users might outgrow this minimal setup pretty fast
In short, it keeps you from drowning in options, but it is not for super advanced workflows.
3. Stop trying to make PDFs behave like Word files
Where I strongly agree with @caminantenocturno: using rectangles to “erase” text is a trap. Where I diverge is that I’d also be cautious about round-tripping PDFs through Google Docs or similar if layout matters at all.
Use conversion only when:
- Layout really does not matter much, or
- You intend to rebuild the layout anyway
If the PDF is a flyer, invoice, contract, or formatted report, I would:
- Use a real PDF editor when you can.
- If you must convert, export it to a Word or Pages file, fix it properly there, and then accept that you are recreating the PDF, not “editing” the old one.
4. Scanned PDFs: choose between “good enough” and “actually correct”
Instead of only Live Text:
- For something informal (a recipe, notes, old article), Live Text + copy/paste to Notes or Pages is fine.
- For anything important: use OCR in a proper editor, then keep the original scan for reference and treat the OCR version as a separate “working” document.
Trying to keep one single file that is both the scan and perfectly edited text is where people lose hours debugging fonts, invisible layers, and broken text boxes.
5. Concrete setups that actually work
Depending on how often you do this:
Occasional user
- Preview for forms, signing, quick highlights
- One light editor for the rare deep edit
- OCR only when strictly needed
Frequent editor (weekly or more)
- Dedicated PDF editor as your main app
- Preview as a fast viewer / backup annotator
- Clear rule: PDF editor for real text changes, Preview only for reading and comments
So yes, keep using Preview, but only inside a clear “lane”: read, annotate, sign, minor tweaks. The moment you catch yourself fighting layout or faking edits with drawing tools, that is the sign you should hand the file off to a proper PDF editor instead of trying yet another hack.
