I accidentally deleted important videos from my GoPro before backing them up, and I’m trying to find out if recovery is still possible. The footage was from a trip I can’t recreate, so I really need help with the best way to recover deleted GoPro videos from the SD card without making things worse.
I’ve been there. You get home, plug in the GoPro, and the clips you cared about are gone. It feels bad fast. Still, if the videos were deleted or the card got formatted, recovery is often possible. The first moves matter a lot.
Do the simple stuff first
The main thing, stop using the SD card right now.
Don’t shoot more footage on it. Don’t format it again. Don’t run random repair tools. When files get deleted, the video data often stays on the card for a while. What kills recovery is new data writing over the old stuff.
I’d check these before touching recovery software:
- Look at your GoPro cloud account if you pay for it and had Auto Upload turned on.
- Check Trash or any Recently Deleted area.
- Put the card back in the camera and see if the GoPro offers a repair prompt.
- Try a different card reader, USB port, or another computer.
- See whether the card shows up in Disk Management on Windows or Disk Utility on macOS.
If the card never appears, keeps dropping connection, or looks physically damaged, I’d stop messing with it. At that point, a recovery shop makes more sense. Physical failure is a different mess than deleting files by mistake.
Software usually comes next
If the problem is deletion, formatting, or file system damage, I’d start with software.
A lot of people assume video recovery works like photo recovery. It doesn’t, not from action cams. GoPro footage is often stored in chunks spread across the card. Once the file system breaks, the software has to piece those chunks back together in the right order. Some tools find an MP4 name, sure, then you open it and it stutters, cuts off, or won’t play at all. I’ve seen tht happen.
If I were doing this today, I’d use Disk Drill.
The reason is its Advanced Camera Recovery mode. It was built for camera footage and traces back to the old GoProRecovery and CnW Recovery tools people used for GoPro clips for years. The newer version keeps building on those methods and is aimed at fragmented video from GoPros, drones, dash cams, and similar devices.
The steps are straightforward:
- Take the SD card out of the GoPro.
- Connect it straight to your computer with a card reader.
- Open Disk Drill.
- Select the SD card.
- Pick Advanced Camera Recovery.
- Run the scan.
- Preview the videos it finds.
- Save recovered files to a different drive.
The preview part matters. I like being able to check whether a clip opens before saving it out. It saves time and tells you early if the footage looks intact. If the card throws read errors or feels unstable, make a byte-to-byte backup first, then scan the backup instead of hammering the original card.
On a Mac, it’s about the same process. Reader, card, Disk Drill, scan, preview, recover to another location. Nothing fancy.
When I’d skip software and go to a lab
Software is fine for a lot of logical problems. It’s not the right move for every case.
I’d look at a professional recovery service if:
- The SD card has physical damage.
- No computer detects it at all.
- It keeps disconnecting during a scan.
- The card gets hot for no clear reason.
- The footage matters enough tht you don’t want trial and error.
Past that point, trying more tools on your own sometimes makes the situation worse.
If this was a simple delete or format, your odds are usually better than you’d think. GoPro loss from those cases is often recoverable, especially if the card hasn’t seen much use since the files vanished.
