Need a reliable crypto wallet tracker recommendation
I’ve been buying and moving different cryptocurrencies across several wallets and exchanges, and it’s getting hard to keep track of my balances, fees, and transaction history in one place. I’m worried I might miss something important or miscalculate my holdings during tax season. Can anyone recommend a secure, accurate crypto wallet tracker or portfolio app that supports multiple chains and exchanges, and share what’s worked best for you?
I went through the same mess once I had 5 wallets, 3 exchanges, some DeFi, and no clue what my real balance was.
Stuff that worked well for me:
  1. CoinStats
    Good for: multi wallet + exchanges + DeFi
    • Connects to most major exchanges with API.
    • Reads wallet addresses on-chain for BTC, ETH, Solana etc.
    • Has decent fee tracking and PnL, including per coin.
    • UI is simple, mobile app is ok.
    Downside: free tier is limited. If you have a lot of wallets it starts nagging. Still, good starter.
  2. CoinTracking
    Good for: detailed tax and history
    • Upload CSVs from exchanges and link wallets via xpubs or addresses.
    • Strong tax reports, FIFO/LIFO accounting, realized / unrealized PnL.
    • Good for spotting missing trades and fee totals.
    Downside: setup is annoying. You need to clean duplicate trades, dust, old airdrops. Once done, it is solid.
  3. CoinTracker.io
    Good for: “set and forget” approach
    • Connects via API and addresses.
    • Basic PnL and tax.
    • Good auto classification of transfers between your own wallets so your PnL does not get ruined.
    Downside: not great with obscure chains and weird DeFi stuff.
  4. DeBank or Zapper (if you do DeFi)
    • Best for EVM chains like Ethereum, Arbitrum, Polygon.
    • Shows tokens, LP positions, lending, staking.
    • Good to see if you left $50 in some old pool.
    Downside: does not help much for centralized exchanges or Bitcoin.
  5. Zerion
    • Nice for tracking EVM wallets in one place.
    • Good mobile app, push alerts for transfers.
    • Cleaner than Zapper for a simple view of assets.
Practical setup that keeps my sanity:
  1. Pick one “source of truth”
    I use CoinTracking for full history and tax. You might pick CoinStats or CoinTracker if you care less about tax detail.
  2. Centralize API keys
    • Create read-only API keys for all exchanges.
    • Disable withdrawal perms.
    • Label each key in a password manager.
    • Feed those keys into your tracker.
  3. List all wallets in a simple sheet
    • One row per wallet: chain, address, where you use it.
    • Paste every address into your tracker.
    • Mark which ones are “hot”, “cold”, “old”.
    This helps you avoid missing a random old address with funds.
  4. Clean your history once
    • In CoinTracking or CoinTracker, fix “Deposit” / “Withdrawal” pairs so internal transfers are not taxed as trades.
    • Mark airdrops and rewards properly.
    • Tag lost coins or dust so they do not distort PnL.
  5. Set a routine
    • Weekly: open your main tracker, scan total balance and large moves.
    • Monthly: export or save a backup report with holdings and PnL. This helps if a site or exchange dies later.
If you want simple and quick, start with:
• CoinStats for overall view.
• DeBank or Zapper for DeFi only.
If you care about tax and full history, start with CoinTracking, accept one annoying weekend of setup, then enjoy autopilot after that.
Whatever app you go with, keep:
• API keys read-only.
• Seed phrases never entered into any tracking app.
• CSV exports stored locally, so you keep your record if the app disappears.
I’m with @vrijheidsvogel on most of that, but I’d tweak the stack a bit, especially if you care about not getting locked into one paid app later.
What’s worked for me:
1. Rotki (self‑hosted, privacy focused)
If you’re even slightly paranoid or hate subscriptions:
  • Runs locally, you keep your data.
  • Tracks CEX + chains + some DeFi.
  • Strong on history and PnL, decent for fees.
    Downside: UI is kinda clunky and setup is not “5 minutes and done.” But once configured, it’s stupidly reliable and no one can rug you by shutting down a cloud service.
2. Kubera (if you want “life portfolio”, not just crypto)
Not a pure crypto tracker, more like “net worth dashboard” where you can:
  • Add wallets, exchanges, plus bank accounts, stocks, even random stuff like your car or NFTs as manual assets.
  • Nice for seeing “what am I actually worth” instead of staring at just coins.
    Fees and tax detail are weaker though, so I’d treat it as overview only.
3. Simple “cold storage sheet” as backup
This is where I disagree a bit with relying too hard on any app, including CoinStats / CoinTracker etc. They can mess up or die.
Keep a tiny local spreadsheet:
  • One tab = list of all wallets & CEX accounts, labels, networks.
  • Another tab = occasional “snapshot” of balances (once a month or quarter).
    If every tracker fails, you still know where everything lives and roughly what you had.
4. How to avoid missing random dust & airdrops
  • For EVM chains, instead of just DeBank / Zapper / Zerion, also occasionally plug your addresses into:
    • block explorers’ token tabs (Etherscan, Arbiscan, etc.)
    • NFT section too, some trackers skip obscure NFTs that might have value.
  • For BTC & UTXO chains, I use a block explorer watchlist to ping me if something moves. Tracker apps are “ok” here, but explorers are more reliable.
5. Fees & PnL sanity check
No app is perfect at fees, especially when you bridge, swap via DEX, or farm in weird DeFi pools. Twice a year I do:
  • Export trades from main CEXs in CSV.
  • Quick manual check:
    • Sum of deposits – withdrawals – current holdings ≈ total realized PnL + fees.
      It won’t be exact, but if the gap is huge, I know my tracker is missing something.
If you want minimal headache right now:
  • Pick one main tracker to be your “live view” (CoinStats / CoinTracker / Rotki, whichever feels right).
  • Pair it with:
    • A basic spreadsheet that lists all wallets and CEX accounts.
    • A DeFi dashboard for EVM (Zerion or DeBank or Zapper is fine, don’t overthink it).
The key is not the specific app, it’s having:
  1. One “master list” of addresses & accounts.
  2. One “daily view” tracker.
  3. One “backup record” outside any SaaS.
Once that’s in place, you’re very unlikely to lose track of anything, even if some app nerfs its free tier or shuts down.
Short version: you don’t need more apps, you need one “brain” app plus a different way of organizing things.
I mostly agree with @jeff and @vrijheidsvogel on the tools they listed, but I solve the problem slightly differently:
1. Pick a role for each tool, not “one app to rule them all”
Instead of hunting for a single perfect crypto wallet tracker, decide:
  • 1 app = live portfolio brain
  • 1 app = tax & deep history
  • 1 layer = offline backup & sanity checks
Trying to make CoinStats, CoinTracking, CoinTracker, Rotki or similar do everything is why stuff gets messy. Even the best tracker gets confused with internal transfers, bridges, fee tokens and weird DeFi.
2. About the product title ' as a “tracker”
Since you mentioned it, think of ' like this:
Pros for using ' in the stack
  • Can act as a single place to view balances across multiple wallets
  • Usually decent for high level PnL and daily “what is my total worth” checks
  • Easier UX than heavy tax/report tools, so you actually look at it regularly
  • Often has alerts or notifications when balances move, which helps catch mistakes quickly
Cons / limitations
  • Not ideal as your only source of truth for tax or multi‑year history
  • Can struggle with niche chains, complex DeFi, NFTs, or custom fees
  • If it is SaaS and paid, you are dependent on their pricing and uptime
  • Needs to be combined with CSV/API exports from exchanges if you care about audit‑grade records
So I would use ' as the “daily dashboard” layer, not as your final archive of everything that ever happened.
3. Where I slightly disagree with the others
  1. You do not need to connect every single thing at once
Jeff’s idea of plugging all APIs and wallets in immediately is efficient, but for people already overwhelmed it creates chaos.
Instead:
  • Start with only your active exchange accounts and your 1–2 main hot wallets
  • Get that clean, fix transfer tagging and fees
  • Then add old / cold wallets gradually
You avoid staring at a broken PnL for a week.
  1. You should accept some manual work forever
Both posts lean toward “set it up once and autopilot.” In practice, tracking crypto will always need a small manual workaround:
  • Exotic airdrops
  • LP unstakes where the platform mislabels cost basis
  • Bridges that show as deposits / withdrawals instead of transfers
If you mentally budget 1 or 2 hours every quarter to fix these oddities, you will never be surprised later.
4. Concrete setup that complements their stacks
Use:
  • @jeff’s picks like CoinStats / CoinTracking
  • @vrijheidsvogel’s privacy angle with something like Rotki
  • ' as your easy‑view dashboard if it fits your workflow
Then layer in this extra structure to avoid losing track:
A. “Hierarchy” of wallets
Instead of one big flat list:
  • Tier 1: Active trading & DeFi wallets (connected to your main tracker, and to ')
  • Tier 2: Medium term cold-ish wallets (connected read‑only, checked monthly)
  • Tier 3: Deep cold storage (kept in your spreadsheet only, checked a few times a year)
Not everything needs real‑time tracking. This keeps noise low and fees / spam tokens from cluttering your view.
B. One manual “fee ledger” for weird stuff
Whenever you do something weird that you know a tracker will choke on:
  • Big bridge transactions
  • Complicated farming / LP migrations
  • OTC deals or peer to peer trades
Just jot it into a tiny text file or sheet: date, wallet, what happened, rough value. When your tracker looks off, that file explains 80% of the difference.
5. How to avoid missing something important
Instead of depending purely on any tracker:
  1. Once per quarter, do a “sweep”:
    • Open your master sheet of wallets & exchanges
    • For each, use the chain’s block explorer or exchange account page to confirm there is no stray balance
    • Compare total vs what ' or your main tracker shows
  2. If totals differ meaningfully, chase the largest discrepancy first.
    Often you will discover:
    • An old L2 address with a token you forgot
    • An exchange delisting that converted one asset to another
    • A mislabeled internal transfer
  3. Export updated CSVs for the tax/history tool whenever you do a sweep.
    This keeps your history close to reality without daily micromanagement.
6. How I would actually start, step by step
  1. Choose one “brain” app
    • If you favor UI and simplicity: ' or CoinStats type app
    • If you favor tax depth: CoinTracking or CoinTracker
  2. Only connect:
    • Main exchange accounts
    • 1 main EVM wallet
    • 1 main BTC or non‑EVM wallet
  3. Clean that data:
    • Fix internal transfers
    • Tag obvious airdrops / rewards
    • Check fees on a few large trades manually
  4. Once it looks sane, add the rest slowly over a few weeks.
This way you never feel like your whole history is broken.
Bottom line: @jeff and @vrijheidsvogel already gave you a great tool menu. The missing piece is deciding what each tool is for and not demanding perfection from a single crypto wallet tracker. Let ' or a similar app be the front‑end dashboard, keep one serious history/tax backend, and back it all with a simple offline record. That combination is what actually prevents missed coins and ugly surprises later.
