Need advice on choosing a reliable portable WiFi for travel
I travel often for work and my current portable WiFi hotspot keeps dropping connections and running out of data too fast. I need recommendations on a dependable portable WiFi device or service with good battery life, strong coverage, and affordable data plans for use across different states. What should I look for and which brands or carriers have worked best for you?
Short version since you travel a lot and need something stable:
  1. Pick the right type of hotspot
  2. Pick the right data plan
  3. Test coverage before you commit
  4. Use tools to measure signal and find weak spots
Device recs that tend to work for frequent travel:
  1. Inseego / Netgear mobile hotspots
    • Netgear Nighthawk M6 or M6 Pro on AT&T or unlocked
    • Inseego MiFi M2100 or newer on Verizon
    These have solid radios, WiFi 6, and stronger antennas than cheap pocket hotspots.
    Look for:
    • 5G + LTE fallback
    • At least 8–10 hours claimed battery
    • Ethernet port if you want to plug into a travel router or laptop
  2. eSIM based travel data
    If you go out of the country a lot, look at eSIM services like Airalo, Holafly, Nomad.
    • You load local or regional data packs.
    • Often cheaper than roaming from your home carrier.
    • You use your phone as the hotspot, but get a power bank because battery drains fast.
  3. US only, work travel
    • Verizon tends to win in rural and highways.
    • AT&T and T Mobile work better in many cities and airports.
    Try to match your hotspot carrier to where you actually travel.
    Check the carrier coverage maps, then search “ coverage complaints ” to see if locals hate it.
Battery and data tips:
• Turn off 5G if you stay in weak 5G areas, stick to LTE. Saves battery and reduces drops.
• Lock the hotspot to 4G if 5G is flaky where you are.
• Set WiFi to 2.4 GHz when you are in hotels with walls, 5 GHz for open spaces like airports.
• Turn off auto updates on your laptop when on hotspot. Windows and macOS eat gigabytes fast.
• Use a browser plugin to block autoplay video on sites you use for work.
Data plan tips:
• Avoid “unlimited” plans that throttle hotspot after 15–50 GB. Read the fine print for “premium hotspot data”.
• If your work needs Zoom or Teams, plan for at least 3–5 GB per full video meeting day.
• If you do remote desktop or VPN all day, it adds up fast. Track your use the first week.
Practical combo that works for a lot of people:
• One main hotspot on a strong US carrier with a 100+ GB data plan.
• One backup option using your phone eSIM or a second carrier.
• A small power bank so the hotspot does not die in the middle of a call.
Since you mentioned dropped connections, signal quality in hotels and offices matters a lot. A tool like NetSpot helps with that side of the problem. You run it on your laptop to scan WiFi around you, find congested channels, and see where the signal is weak. It is handy when your hotspot works but performance is bad in some spots. Check this link for more info on improving your WiFi signal and reliability. That helps you choose better channels on your hotspot and see if the building WiFi is worth using instead.
Quick checklist before you buy:
• Unlocked hotspot, not tied hard to one carrier.
• 5G + LTE, WiFi 6.
• At least 8 hours battery at real world use, not marketing claim.
• Clear hotspot data allowance, like “100 GB premium hotspot”.
• Return window, so you test it on your usual routes and hotels.
If you share more about where you travel most, people here can point to the best carrier and exact model.
I travel a ton for work too and fought with flaky hotspots for years, so here’s the stuff that actually made a difference for me (and where I see it a bit differently from @shizuka).
Your core problem in plain english:
You need a portable WiFi setup that:
  • Stays connected in hotels, airports, cars, and client sites
  • Does not burn through data in a few days
  • Has legit battery life, not “spec sheet fantasy”
1. Devices: what actually survives road-warrior abuse
I agree that Netgear / Inseego are solid, but if your current hotspot is dropping a lot, I’d focus on antenna and radio quality before fancy features:
  • Avoid super tiny “credit-card” hotspots
    They look cute, suck at RF. Thin cases and tiny antennas = weak signal through hotel walls and crowded venues.
  • Look for:
    • External antenna ports (TS9 / SMA). Even if you do not buy antennas now, having the option helps in bad hotels.
    • User‑replaceable battery if possible. After a year of daily use batteries tank.
    • A simple “stick to LTE only” toggle that is easy to find in the UI. Hunting through menus on hotel WiFi is pain.
  • Left-field option:
    A small travel router + your phone as the modem.
    • Router handles WiFi for your laptop, tablet, etc.
    • Phone is plugged in over USB and just does data.
    • Pros: better WiFi stability, less “phone cooking itself as hotspot.”
    • Cons: slightly more stuff to carry.
2. Data strategy: stop the silent data drain
Where I half‑disagree with @shizuka is on just “get 100+ GB and track usage.” For heavy travel, you’re better off preventing waste first, then sizing a plan.
Check these, they make a shocking difference:
  • On laptop:
    • Turn on metered connection in Windows / low data mode in macOS.
    • Disable auto cloud sync for large folders (Dropbox, OneDrive, Google Drive). Those can nuke 10+ GB overnight.
  • On phone hotspot:
    • Kill background app refresh for stuff you don’t need on the road.
    • Turn off auto photo / video backups on cellular.
You might find that with these tweaks, a 60–80 GB “premium hotspot” plan is enough instead of going full whale.
3. Battery life: spec sheet lies vs real life
Manufacturers love to claim “up to 16 hours” and in real use you get like 6.
To squeeze real battery life:
  • Set WiFi to low or medium transmit power if you are usually in the same room as the hotspot.
  • Use 2.4 GHz in hotels with walls only if you need range. If you are close, 5 GHz can actually be more efficient and less congested.
  • Keep the hotspot on a USB charger whenever possible and use a small power bank when you are in transit.
Honestly, I treat my hotspot like a modem that happens to have a battery, not something I rely on to survive all day totally unplugged.
4. Coverage: not just the carrier, but the actual room
Here’s where a lot of people get tricked. You can have “5 bars” of signal to your hotspot, yet your WiFi inside the hotel room is the real bottleneck.
That’s why a WiFi analysis tool on your laptop is worth more than a third new hotspot.
I use NetSpot for this:
  • Scans all nearby networks and channels
  • Shows if your hotspot is stuck on a super crowded channel
  • Lets you see the best spot in the room to park the hotspot (window vs desk vs near door)
If you want to dig into this, check out advanced WiFi troubleshooting and optimization. It is very helpful for improving portable WiFi stability, not just home networks.
You can literally move the hotspot 3 feet and double your usable speed if you avoid a bad spot or a noisy channel.
5. When to skip a hotspot entirely
Unpopular take: sometimes the best portable WiFi is no portable WiFi.
If most of your travel is to major cities or overseas:
  • Use eSIM regional plans on your phone
  • Combine that with a travel router that can:
    • Use your phone’s USB tether
    • Or log in as a client to hotel WiFi and then share a new private WiFi to your devices
This gives you:
  • One main “pipe” (phone or hotel WiFi)
  • One consistent, stable private WiFi for your devices via the router
Less gear than phone + separate hotspot + sketchy hotel WiFi all fighting for attention.
6. Clean, search‑friendly summary of what you need
Reliable portable WiFi for frequent business travel means combining a solid 5G/LTE hotspot or phone tethering with a smart data plan, strong battery support, and tools to optimize signal. Look for a high‑quality mobile hotspot with WiFi 6, long battery life, and flexible carrier support. Pair it with a generous hotspot data plan and strict control over background data use. Use a WiFi analyzer like NetSpot to test hotel rooms, choose the best hotspot location, and minimize dropped connections or slow speeds. This combo makes remote work on the road much more stable, whether you are on video calls, VPN, or large file transfers.
If you share your usual travel regions (US only, international, mostly cities vs rural highways), people can help you dial in specific device + carrier combos that match your routes.
I’d tweak what @suenodelbosque and @shizuka said in two ways:
  1. prioritize how you connect (placement, channels, client settings) as much as which hotspot you buy, and
  2. treat hotels and client sites as hostile RF environments, not “normal” WiFi spaces.
1. Device / service angle (without repeating models)
Instead of chasing one “super hotspot,” split your setup:
  • Primary: a 5G/LTE hotspot or phone tether on your best carrier for your routes.
  • Secondary: a cheap backup SIM / eSIM on a competing carrier for “dead zone” days.
You do not need two high-end devices; you need two different networks. That fixes more dropouts in practice than just buying a stronger hotspot.
I slightly disagree with relying heavily on phone-only hotspots: if you do long video calls, a dedicated hotspot is still better thermally and for RF stability. Let the phone be backup or international-only.
2. Why your current hotspot feels flaky
Most “keeps dropping” complaints turn out to be:
  • WiFi congestion in hotels
  • Device hopping between 5 GHz and 2.4 GHz
  • Bad hotspot placement in the room
  • Laptop power saving throttling wireless
This is where NetSpot actually matters more than a new gadget.
Pros of NetSpot in your situation
  • Quickly shows if your hotspot is on a channel that is overloaded by hotel APs.
  • Lets you walk the room and see where signal is strongest so you know where to park the hotspot.
  • Visualizes 2.4 vs 5 GHz congestion so you stop guessing which band will be more stable.
Cons of NetSpot
  • It diagnoses WiFi, not the cellular side, so it cannot fix a weak LTE/5G tower.
  • Needs a laptop, so not helpful if you are working only from a tablet/phone.
  • There is a learning curve if you start using the more advanced views; easy to overthink.
Competitors that focus on similar WiFi survey / analyzer roles exist, but NetSpot hits a good balance of “power user” detail plus simple visual heatmaps, which is valuable for travelers trying to decode hotel RF chaos.
3. Concrete workflow that tends to stop dropouts
  1. In each new hotel room, put hotspot near a window or at least away from thick walls.
  2. Fire up NetSpot on your laptop, scan once.
    • If your hotspot’s channel is slammed, log into the hotspot and switch to a less crowded one.
  3. Decide band:
    • Many overlapping networks on 2.4 GHz: try 5 GHz first.
    • Weak signal on 5 GHz: fall back to 2.4.
  4. On your laptop:
    • Set the hotspot network as “metered” to cut background data drain.
    • Disable WiFi power saving to avoid sleep/wake drops during calls.
4. Data burn control (where I part ways slightly)
Instead of just scaling up to 100+ GB as suggested, I would:
  • Do one week of strict control using metered connection, no auto cloud sync, no auto OS updates.
  • Measure actual daily average.
  • Then pick a plan that is about 30–40 percent higher than that average for safety.
Some people realize they only need 40–60 GB once the silent syncs are killed.
5. When to trust hotel WiFi
You do not always need to ignore hotel WiFi. Use NetSpot to check:
  • If hotel APs are strong and not oversaturated, sometimes it is stable enough for non-video work.
  • If you see a ton of APs at similar signal strength on the same channel, that is when you lean on your hotspot instead.
So in short: keep the solid device recommendations from @suenodelbosque and @shizuka in mind, but pair whichever hotspot you choose with NetSpot-driven placement and channel choices, plus a two-carrier strategy. That combo usually does more to stop mid-call drops and “where did my data go” than any single “best hotspot” ever will.
