Just got Starlink delivered and I’m confused about the best way to set it up for a stable, fast home internet connection. The quick start guide feels too basic, and I’m not sure about dish placement, cable routing, and router settings for wifi coverage. Can anyone walk me through the correct Starlink installation steps and share any tips to avoid common setup problems?
Short version first. Get it high. Give it clear sky. Protect the cable. Use your own router if you want more control.
Longer, step by step.
Check your coverage and obstructions
Download the Starlink app.
Use the “Check for obstructions” tool.
Walk around your roof and yard and point your phone roughly where the dish would go.
You want 0 percent obstructions for best performance.
Some people live fine with 2 to 3 percent, but you start seeing short drops.
Trees on the south side of your house hurt the most in the northern hemisphere. -
Best dish placement
Priority order.
- Roof peak or high gable.
- Second story wall mount.
- Pole mount in yard.
- Ground mount only if your sky is wide open with no trees or buildings near.
Roof peak is usually fastest and most stable.
Avoid chimneys, they block signal and add heat and soot.
If you do a wall mount, angle it so the dish points to the open sky arc the app shows.
Leave at least a few feet away from tall walls or roof lines so nothing clips the view.
- Mounting hardware choices
Common options from Starlink store.
Roof mount. Simple, for shingles.
Pivot mount. Good for gable ends and some siding.
Pipe adapter. Good if you already have a satellite TV pole or mast.
If wind is strong in your area, aim for a solid pole mount in concrete, 2 inch steel pipe, at least 2 feet in the ground with concrete.
Use lag bolts into rafters or studs.
Do not only screw into thin siding or sheathing.
Use roofing sealant around holes. Avoid leaks.
Double check alignment with the app obstruction test after mount.
- Cable routing
The Starlink cable is delicate at the connectors.
Do not crush, staple through, or sharply bend it.
Min bend radius about a soda can size or bigger.
Options.
Through a vent.
Through an existing satellite cable penetration.
Through a new hole near the Starlink router location.
If you drill a new hole.
Go slightly downward from indoors to outdoors so water flows out.
Use a drip loop outside. Small U shape before the cable enters the wall.
Seal with silicone.
Avoid running parallel and close to power lines for long distances.
Use UV rated clips outside so wind does not flap it.
Do not pinch the cable in window frames or doors. That kills it fast.
- Router placement and WiFi
The standard Starlink router is ok, not amazing.
Place it near the center of the house, above floor level, not hidden in a metal rack.
Avoid putting it in a closet or behind big appliances.
If your house is over about 1800 to 2000 square feet, WiFi will start to fall off.
Common setups.
- Use Starlink router only, accept some weak spots.
- Bypass Starlink router and use your own WiFi 6 router.
- Use Starlink router plus mesh system in AP mode.
To use your own router, put Starlink in bypass mode and add an Ethernet adapter.
Then connect your router WAN port to that adapter.
This gives more stable WiFi, better coverage, and features like parental controls and better QoS.
- Stability and speed tips
Starlink speeds jump around.
You might see 40 to 250 Mbps down, depending on time of day and congestion.
Higher priority factors.
Clear sky.
Short cable run.
Newer dish model.
Up to 150 foot cable is standard, but shorter runs lose slightly less signal.
Do not expect fiber level consistency.
For streaming and gaming, it still works fine if obstructions stay at or near zero.
If you game, use Ethernet from your router to your PC or console.
WiFi adds extra jitter.
Power and surge protection
Use a good surge protector or UPS between your wall outlet and the router.
Avoid cheap power strips with minimal protection.
Starlink gear is not thrilled with brownouts or spikes.
If you get frequent outages, a small UPS keeps the router and dish online for a bit. -
Weather and maintenance
Snow. Dish has a heater. Still keep it above snow level or where falling snow does not bury it.
Ice. Avoid placement where roof ice slides straight down onto the dish.
Wind. Make sure all mounts are tight once a year.
Check cable for UV damage or chew marks if you have squirrels. -
Common mistakes to avoid
Mounting low in the yard near trees because it is “easier”.
Stapling or crushing the cable under a window.
Putting router behind a TV or in a metal cabinet.
Ignoring the obstruction check and assuming it is fine. -
Quick checklist
Obstruction scan shows 0 to 2 percent.
Dish at or near roof height, clear south sky.
Cable has no sharp bends, no crush points, sealed wall entry.
Router central in house, not hidden.
If house is big, plan mesh or your own better router.
If you post your house type, roof style, and trees direction, people can give more precise layout ideas.
If @kakeru gave you the “how,” here’s more of the “how to live with it” side of Starlink without rehashing the same checklist.
- Dish placement tradeoffs people don’t mention
Everyone screams “roof peak or bust,” but that’s not always ideal:
- Future access: You will need to get to that dish someday (firmware weirdness, cable swap, snow, a bird that decides it’s prime real estate). If climbing your roof is a circus act, consider a tall pole or second-story wall where you can still reach it from a ladder.
- Lightning & grounding: If you’re in a lightning-prone area, super high + isolated is not automatically “best.” Look at existing grounded masts (old DirecTV pole, etc.) and consider tying into that setup. Starlink gear isn’t cheap.
- Wind & flex: Super tall skinny poles flex. A slightly lower but rock-solid mount can be more stable than some 20-foot noodle in the wind.
Personally, I’d take: very good sky + safe access + solid mount over theoretical perfect sky that you can’t easily service.
- Cable routing with future-proofing in mind
Everyone worries about not crushing the cable (correct), but also think about:
- Replacement path: Assume the cable dies in 2–3 years or critters eat it. Can you pull a new one the same route without tearing walls apart? Running it through a short conduit where it enters the house makes that way easier.
- Plan for Ethernet now: If you’re drilling anyway, consider running a cheap Cat6 at the same time from where the router will be to where you’d ideally place a future main router / switch. Costs almost nothing now, super annoying later.
- Label both ends: Sounds dumb, but once you have a few cables popping through the same hole you will absolutely forget which is which.
- Router and WiFi: don’t overtrust the stock unit
I’ll slightly disagree with the “Starlink router is ok” sentiment. It’s… fine in a small, open house. In a typical wood-framed multi-room place, it’s usually mediocre. Instead of just dropping it in the “center,” think like this:
- Where do you actually use bandwidth? Office, TV room, kids’ gaming area. Prioritize those rooms, not the geometric center of your floor plan.
- Try one hop: If you do mesh, avoid three-node daisy chains with wireless backhaul; you’ll tank speeds. One main + one well-placed mesh node on Ethernet backhaul is miles better.
- Starlink bypass mode: If you care about stability, QoS, good WiFi, and not babysitting the network, a decent third-party WiFi 6 router is almost always worth it. Especially if you work from home or game.
- Real-world speeds & expectations
Numbers people don’t usually say out loud:
- Peak: You might see 150–250 Mbps when it’s quiet.
- Busy hours: 30–80 Mbps is not unusual in congested cells.
- Latency: 30–60 ms on average, sometimes random spikes. Not fiber, but playable.
How to keep it “feels fast” even when Starlink is being moody: - Hardwire anything important: TV, gaming PC, work laptop dock. WiFi is where a lot of lag/jitter is secretly coming from.
- Avoid double NAT if you can: If you use your own router, definitely use bypass mode so you don’t have Starlink router + your router both doing NAT. Helps with gaming, remote work, VPNs.
- Background hogs: Cloud backups and game updates will absolutely clobber Starlink. Enable some sort of QoS or schedule big downloads overnight.
- Power & reliability mindset
Instead of just “plug it into a surge strip”:
- Use a small UPS if you care about meetings / calls. Even a 500–750 VA unit will keep dish + router alive long enough to ride out short flickers that would otherwise drop your call.
- If your power is dirty or browns out, Starlink behaves weirdly: random disconnects, weird reboots. If you see that, power quality might be the real culprit, not satellites.
- Weather and “real life” stuff
- Snow and rain fade: Starlink is decent in bad weather, but heavy wet snow sticking to the dish can still cause dropouts despite the heater. If your climate is snowy, don’t mount in a spot that’s impossible to brush off with a broom from a ladder.
- Roof slides: Ignore this at your peril. If you have a metal roof or steep pitch, sheets of snow/ice can absolutely smash a dish. Mount to the side of the main slide zone, not directly under it.
- Animals: If you have squirrels, mice, or bored raccoons, putting the cable exposed along a fence or low roof edge is basically advertising “free chew toy.” Conduit or at least some protective loom in reachable areas is worth it.
- Quick “what to actually do today” plan
Since you’re overloaded with info already, here’s a simple approach that complements what @kakeru said:
- Use the app to pick the highest location you can safely access later, with mostly open southern sky and minimal future tree growth risk.
- Mount securely into real structure, not siding, and avoid the direct snow/ice slide path.
- Run the cable in a way you can replace later: gentle bends, maybe short conduit at entry, no window pinch, labeled inside.
- Start with the stock router somewhere near your main usage area, not shoved in a closet. Test for a week.
- If WiFi coverage or features annoy you, add Ethernet adapter + your own router in bypass mode and retire the Starlink router to the box.
If you want more targeted ideas, toss in: approximate house size, number of floors, main rooms you care about (office / TV / kids gaming), and where your best ladder-accessible exterior wall or roof edge is. That’s usually enough to sketch a solid setup plan.
