For those who’ve tried it, did anything stand out — either in a good or unexpected way?
Mountain Duck Review
Managing multiple cloud storage providers often feels like a digital juggling act. Mountain Duck aims to solve this by bridging the gap between your remote servers and your local desktop. Whether you are on Windows or macOS, this tool allows you to mount cloud storage ranging from Amazon S3 and Backblaze B2 to Dropbox directly as a local drive.
The Experience
The standout feature of Mountain Duck is how it transforms remote storage into something that acts and feels like a locally attached hard drive. This approach offers several massive perks:
- Virtually Unlimited Space: Your device’s physical storage no longer limits you; if you have 10TB in the cloud, you essentially have 10TB on your laptop.
- Hardware Independence: Since your data lives in the cloud, a lost or broken laptop isn’t a catastrophe. Your files remain safe and accessible from any other device.
- Simplified Sharing: Working across multiple devices or sharing large files with a team becomes significantly more intuitive.
Security and Integration
Mountain Duck doesn’t just move files; it protects them. By integrating Cryptomator technology, users can create “zero-knowledge” encrypted containers. This is a game-changer for anyone using providers that don’t offer built-in end-to-end encryption, ensuring your sensitive data remains private even from the cloud provider itself.
Key Features at a Glance
- Broad Support: Works with AWS S3, Google Drive, Backblaze B2, Dropbox, and more.
- Protocol Versatility: Supports WebDAV, FTP, FTPS, and SFTP (SSH).
- Direct Modification: Edit files directly in the cloud without manual downloading/uploading.
- Offline Flexibility: Smart caching allows you to make specific files available offline.
- Affordable Pricing: A very reasonable $39 one-off fee per user, avoiding the “subscription fatigue” of modern software.
The Catch: Performance and Complexity
While Mountain Duck is powerful, it isn’t perfect. Users should be aware that:
- Speed: It can be sluggish when dealing with massive directories or high file counts.
- Management: Setting up and monitoring the caching system can be a bit confusing for new users and requires a watchful eye to ensure you don’t run out of actual local space.
If Mountain Duck doesn’t quite fit your workflow, CloudMounter is a stellar alternative that excels in cross-platform simplicity and user-friendly encryption.
Why Choose CloudMounter?
Like Mountain Duck, CloudMounter allows you to mount services like Dropbox, Microsoft OneDrive, Google Drive, and MEGA directly into your Mac’s Finder or Windows Explorer.
- Native Feel: It focuses heavily on being a “low-profile” app that makes your cloud accounts feel like part of the OS.
- One-Click Encryption: It features a built-in FTP client capable of encrypting files before they ever leave your machine.
- Robust Offline Mode: Their offline mode is particularly strong, allowing you to work on files without an internet connection and automatically syncing the changes once you’re back online.
If you are looking for an app with a slightly more modern interface and a focus on easy “set-and-forget” synchronization, CloudMounter is the way to go.
After weighing the features, usability, and pricing of both applications, the choice comes down to your specific technical needs versus your desire for simplicity.
What surprised you is normal for Mountain Duck.
It is a mounted remote filesystem, not a full sync client. Finder shows it like a local drive, but most actions still depend on API calls, cache state, and your network. So three things feel weird fast.
Speed.
Browsing lots of small files is slowest. One 5 GB file often feels fine. A folder with 20,000 tiny files feels bad. Each list, preview, rename, and metadata check hits the remote side. Finder makes this worse with thumbnails and hidden file checks. -
Sync behavior.
Mountain Duck is closer to on-demand access than constant mirror sync. If you edit a file, it usually uploads after save or when the app sees the change. That delay is what trips people up. If you expected Dropbox-style instant status badges everywhere, yep, it feels off. -
Finder folder weirdness.
Some cloud providers do not behave like HFS or APFS. Case sensitivity, package files, temp files, file locking, extended attributes, and sort order get odd. Finder assumes local disk behavior. Remote storage does not always match. That mismatch is the issue, not you.
I slightly disagree with @mikeappsreviewer on one part. Offline cache is helpful, but it also causes half the confusion. People think cached means synced forever. It doens’t.
If you want mounted cloud storage with fewer quirks, CloudMounter tends to feel simpler in daily use. Less fiddly. Better fit if your goal is “show up in Finder and stop being weird.”
What surprised you is basically the gap between “mounted drive” and “real local disk.”
Mountain Duck looks native in Finder, but Finder is kinda lying to you a little. It’s a remote filesystem adapter. So when you open folders, preview files, or move stuff around, Finder is often waiting on network replies, provider APIs, and local cache decisions. That’s why it can feel randomly fast one minute and weirdly sticky the next.
A small disagreement with @viajeroceleste: it’s not just that Mountain Duck isn’t a sync client. Even as a mount tool, some of the jank comes from Finder itself being nosy as hell. It asks for thumbnails, metadata, package contents, hidden files, etc. That makes cloud folders behave worse than they “should,” esp with lots of tiny files.
A few normal gotchas:
- Big files often feel OK because it’s mostly straight throughput.
- Folders full of tiny files feel terrible because every file becomes overhead.
- Moves/renames may not act like local instant operations depending on the backend.
- Some apps save temp files in odd ways, and remote storage doesn’t always like that.
- “Available offline” or cached does not always mean “fully synced the way Dropbox does it.”
Also, provider matters a lot. S3-ish storage, Dropbox, WebDAV, Google Drive, all have diffrent quirks. So if one folder acts bizarre, it may be the backend, not Mountain Duck alone.
@mikeappsreviewer is right that Mountain Duck is great when you want flexibility. But if your main goal is less Finder weirdness and a more predictable day-to-day setup, CloudMounter is honestly worth a look. It tends to feel simpler for basic “mount cloud storage on Mac like a local drive” use, with less fiddling. Not magic, just less surprsing.
The part that usually surprises people is not “Mountain Duck is broken,” it’s that macOS treats a mounted remote volume like a disk even when the backend absolutely is not disk-like.
I mostly agree with @viajeroceleste and @himmelsjager, but I’d push one point a bit further than @mikeappsreviewer did: some weirdness is not just cache confusion or Finder being nosy. A lot of it is app behavior. Some Mac apps save by writing temp files, swapping file handles, adding metadata, then renaming. On APFS that is normal. On cloud storage, that can turn into lag, duplicate temp files, or failed saves.
What feels “off” is usually one of these:
- directory listings are remote operations, not instant local reads
- Quick Look and thumbnails trigger extra traffic
- rename/move can be server-side on one backend, but copy-delete on another
- file timestamps and locks may not map cleanly
- offline availability is closer to cached access than true bidirectional sync semantics
That last one is the biggest mental trap. If you came in expecting Dropbox behavior, Mountain Duck will feel inconsistent even when it’s acting exactly as designed.
One thing I slightly disagree on with the others: giant files are not always fine. They are fine only when your connection is stable and the app you use writes sequentially. Video editors, photo apps, and some office tools can hammer remote filesystems in ugly ways.
If your goal is flexibility, Mountain Duck still makes sense. If your goal is “make Finder less weird,” CloudMounter is worth a look.
CloudMounter pros:
- simpler day-to-day mounting
- usually feels more predictable in Finder
- good for basic multi-cloud access
- encryption features are easier to live with
CloudMounter cons:
- less of a power-user tool in some workflows
- backend quirks still exist because cloud APIs are still cloud APIs
- not a replacement for a real sync client when you need airtight local mirroring
So yeah, what surprised you is probably the gap between mounted access, sync semantics, and actual local filesystem behavior. That gap is the whole story.
