I run a small business and my spreadsheets are getting out of control. I’m spending way too much time tracking invoices, expenses, and basic reports manually, and I’m worried I’m making mistakes that could affect taxes and cash flow. Can anyone recommend reliable, affordable bookkeeping software for small businesses, and explain why you like it over others you’ve tried?
Spreadsheets start to fall apart once you want clean reports and tax-ready data, so you are on the right track.
Short version: pick one of these three and stop overthinking it.
- QuickBooks Online
Best if your accountant likes it or you plan to grow.
- Bank feeds, auto import of transactions
- Solid invoicing with reminders and online payments
- Strong reports: P&L, balance sheet, sales tax, cash flow
- Widely used, most bookkeepers know it
- Interface feels clunky for new users
- Pricing jumps fast when you add features or users
Who it fits
- You send invoices often
- You want to share access with a CPA or bookkeeper
- You want standard double entry accounting without fiddling in Excel
- Xero
Cleaner UX than QuickBooks for many people.
- Simple layout, less “busy” than QBO
- Good for multiple currencies
- Bank rules make categorizing fast
- Integrates with a lot of tools
- Less popular in the US than QuickBooks
- Fewer third party tutorials here compared to QBO
Who it fits
- You want cloud accounting, but find QBO annoying
- You like clean reports and automation
- Wave
Good if your budget is tight and you need basics.
- Core accounting is free
- Invoicing and basic reports
- Fine for freelancers and tiny shops
- Paid support features can add up
- Not as strong on advanced reporting
- Some accountants dislike working in it
Who it fits
- Solo or very small business
- Low transaction volume
- You want to stop using spreadsheets fast without a big bill
How to choose in under an hour
- Ask your tax pro what they prefer. If they say QuickBooks, use QuickBooks unless you hate it.
- List what you actually need:
- Invoicing with online payment
- Mileage tracking
- Inventory
- Payroll
- Multi currency
- Check pricing for those features, not only the base plan.
- Start a free trial of 2 tools on the same day.
- Connect your bank
- Enter 10 invoices
- Categorize 30 recent expenses
- Run a P&L report
Whichever feels less annoying after that wins.
Migration tips from spreadsheets
- Export your customer list and vendor list as CSV
- Import them into the new tool first
- Start clean from the first day of a new month
- For past data, enter one opening balance per account instead of retyping every old transaction
- Keep your old spreadsheets in a folder as an archive
Minimum setup to avoid tax pain
- Set up a separate business bank account and credit card
- Connect bank feeds into the tool
- Create income categories that match your main revenue streams
- Set expense categories that line up with IRS categories (your accountant can share a chart of accounts)
- Reconcile accounts monthly
If you want simple and cheap, go Wave.
If you want accountant friendly and standard, go QuickBooks Online.
If you want cleaner UX with strong features, go Xero.
Do not overoptimize. Pick one this week, move new transactions into it, and keep the spreadsheets read-only as backup. Your future tax season will hurt way less.
Spreadsheets as a “system” are like using a butter knife as a screwdriver. Technically works, until it really doesn’t.
I like what @sonhadordobosque laid out, but I’d tweak the decision logic a bit and add a few options he didn’t touch.
1. Before picking software, lock this in
If you don’t fix these, no app will save you:
- Separate business bank / credit card, always
- Decide on cash vs accrual for taxes (ask your tax pro once, not Reddit 20 times)
- Decide who will actually keep it updated: you, a VA, or a bookkeeper
Once that’s clear, then tools matter.
2. On QuickBooks / Xero / Wave
I agree they’re the “big three,” but:
QuickBooks Online
Great if you’re in the US and want to work nicely with most accountants.
Where I disagree slightly with the hype: if you’re a super tiny, low-volume business and hate accounting terms, QBO can feel like learning a cockpit. You’ll survive, but it’s not “simple.” -
Xero
Cleaner interface for a lot of folks.
If you think you might someday sell or expand internationally, Xero tends to shine more than QBO. Xero’s reporting customization is underrated for small biz too. -
Wave
Nice free-ish starting point, but if you think you’ll grow in the next 1–2 years, I’d honestly skip it. Migration from Wave to QBO/Xero is not fun, and you’ll probably end up paying someone to fix the mess. Cheap now, expensive later.
3. A couple of options that often get ignored
Depending on what kind of “small business” you are:
Sole prop / freelancer / consultant
Look at:- FreshBooks: Very invoice-focused, time tracking, nice for service businesses. Less intimidating than QBO.
- Zoho Books: Cheaper than QBO, solid feature set. Part of the whole Zoho suite if you like “one vendor for everything.”
Product, inventory, or ecommerce
If you sell on Shopify, Etsy, Amazon, etc, the accounting tool is half the story. The integration is the real boss fight.- QBO + a good connector app (A2X, Webgility, etc) is usually the safest path
- Xero also plays well with ecommerce, sometimes better outside the US
If you stock inventory, do NOT try to hack that with a spreadsheet plus Wave. That’s a tax nightmare in slow motion.
4. Instead of test-driving everything, here’s a faster fork in the road
Ask yourself:
“Do I care more about my own comfort or my accountant’s comfort?”
- Accountant comfort: QuickBooks Online
- Your comfort / less clutter: Xero or FreshBooks
“Will I still be tiny in 3 years?”
- Yes / likely: FreshBooks, Zoho, or maybe Wave if truly budget strapped
- No / maybe not: QBO or Xero from day one, skip the “free” detour
5. Minimal setup so your future self doesn’t scream at you in tax season
No long tutorial, just the parts people skip:
- Create income categories that match how you think: “Website design,” “Maintenance,” “Coaching” instead of one vague “Sales” bucket
- Map expense categories roughly to tax categories but keep it readable: “Software,” “Marketing,” “Contractors,” “Travel,” “Home office”
- Turn on bank feeds, then set up some rules so it auto-categorizes obvious stuff (Stripe fees, Shopify fees, utilities)
- Reconcile monthly, not “whenever I remember.” Use the first Friday of each month or something; put it in your calendar like a client appointment
6. If you want the bare-minimum decision from a stranger on the internet
- Service business, mostly invoices, US based, want accountant-friendly: QuickBooks Online Simple Start or Essentials
- Hate QBO’s look, like cleaner UI and okay with slightly fewer US tutorials: Xero
- Very small, mostly just want something better than Excel and you’re really cost-sensitive: Zoho Books before Wave
And honestly, the biggest win is not which app you pick. It’s the moment you stop using your main spreadsheet for live data and treat it as “old records only.”
Pick one tool, commit to it for at least a year, and let the spreadsheets retire instead of dragging them into yet another tax season.
