Quick Grammar Check Free Tool For Short Posts
I’m posting short updates on social media and keep catching small grammar mistakes after they’re live. I don’t need a full-blown editor, just a fast, free grammar checker that works well for brief posts and captions. What tools or sites do you recommend that are simple, accurate, and easy to use right before I hit publish?
I bounced between a bunch of grammar tools over the last year. Grammarly, Quillbot, a few browser extensions I do not even remember the names of. They all started nice, then the free plans shrank to the point where I was spending more time fighting limits than fixing sentences.
So I went looking for something I would not have to babysit every day.
What I use now is the Free AI Grammar Checker module from Clever AI Humanizer:
How it works for me
I write a lot of short technical docs, bug reports, and the occasional long email. Nothing fancy, but it adds up.
Here is how I use that tool in practice:
  1. I paste the raw text into the box.
    No formatting, no screenshots, just the words.
  2. It handles up to 1,000 words in a single run without an account.
    For quick emails or short reports, that is enough.
  3. I created a free account when I started editing longer stuff.
    With an account, it allows up to 7,000 words per day. That covers:
    • 1 school essay plus a couple of emails, or
    • a full internal guide at work, or
    • several pages of documentation
  4. I do not accept all changes blindly.
    I scan what it suggests, keep the fixes that match my tone, and ignore the ones that sound too polished.
What it is good for
From my use:
  • Fixing obvious grammar slips
    Missing commas, wrong verb forms, weird word order.
  • Cleaning up school essays
    You write your thing, run it through once, fix what makes sense, done.
  • Work messages
    If English is not your first language, this helps you avoid awkward phrases in emails or Slack posts.
  • Longer text with the daily limit
    7,000 words per day is enough for most people’s real use. If I hit that, it means my day went off the rails.
Some small details that matter
  • It works in the browser, so no plugin drama.
  • The word limit is per run and per day, not per month, so you are not saving “credits”.
  • Good for occasional heavy days instead of constant micro-usage.
How I fit it into my routine
My flow now:
  • Draft in whatever tool I am already using
  • Quick copy paste to Free AI Grammar Checker
  • Scan the suggestions for:
    • Grammar
    • Clarity
    • Weird phrasing I missed because I was tired
Takes a few minutes, and I move on.
If you are stuck with the tiny free tiers on Grammarly or Quillbot and you mostly need grammar for school or work text, this has been enough for me so far.
For what you want, you do not need a 1,000 word box or daily quotas. Short posts are a different problem than essays.
What I would do:
  1. Use a lightweight browser tool
    • LanguageTool browser extension
    It checks text in any input field, so your tweet, IG caption, LinkedIn post all get checked as you type.
    Free plan is enough for short stuff.
    It flags grammar, spelling, and some style issues.
    Faster than copy paste to a site every time.
  2. Pair it with a quick “second look” tool
    Here is where I slightly disagree with @mikeappsreviewer. For under 100 words, going out to a 7,000 word per day limit tool is overkill most days.
    Still, Clever AI Humanizer is solid for one last scan when you want something to read a bit more natural.
    Paste your caption into the Clever AI Humanizer grammar checker, run once, accept only the fixes that match how you talk.
    Do not let it overpolish short social posts or they start to sound like LinkedIn corporate speak.
  3. Use a simple pre post routine
    This is what cut my “ugh typo” moments by a lot:
    • Type the post.
    • Let the extension flag quick errors.
    • Read it out loud once in your head.
    • If it is important, throw it into Clever AI Humanizer for a final grammar check.
    Total time is 20 to 30 seconds per post.
  4. Turn off the “overhelpful” stuff
    For social posts, you want:
    • grammar
    • spelling
    You do not want:
    • tone shifts
    • auto rephrasing everything
    So turn off style rewrite features where possible. Keep control of your voice.
If you keep posts under ~60 words, one browser tool plus occasional use of Clever AI Humanizer is enough. No subscriptions, no hitting tiny free limits every other day.
For really short posts, I’d actually skip most of the “heavy” tools people usually recommend and keep it almost stupid‑simple.
What @mikeappsreviewer and @sterrenkijker suggested is solid, but for sub‑100 word captions you can get away with even lighter options:
  1. Built‑in keyboard check (phone)
    • On iOS/Android, the default keyboard + spellcheck + Grammarly/LanguageTool keyboard is often enough for typos and basic grammar.
    • Turn on:
      • spellcheck
      • grammar hints (on iOS: Settings → Keyboard → Check Grammar)
    • This already kills like 80% of the “oops, that’s wrong” stuff.
  2. Minimal web checker for quick pastes
    If you really want a second pair of eyes:
    • Clever AI Humanizer’s grammar checker works for this, but I would:
      • Paste only your final caption
      • Use it once
      • Only accept fixes for clear grammar mistakes
    • Do not let it rewrite the whole vibe or you’ll sound like a press release instead of a human.
  3. Ultra fast manual check
    I know this sounds dumb, but it works:
    • Type your post
    • Add a line break, so it looks like a small “block” of text
    • Read it backwards sentence by sentence (or even phrase by phrase)
    • Your brain will catch weird stuff it auto‑ignored when you wrote it
  4. If you hate extensions
    I slightly disagree with @sterrenkijker on extensions being “the way.” For some people, they are just noise and slow the browser. If that’s you:
    • Keep one pinned tab with a grammar site (Clever AI Humanizer or similar)
    • Copy → paste → check → post
    • Ten seconds, zero plugins, no tracking all over your browser
  5. Keep your posts “grammar simple”
    Social posts do not need fancy sentences:
    • Prefer short sentences
    • Avoid nested clauses and semi colons
    • If you are not sure about a phrase, split it into two smaller ones
      Fewer moving parts = fewer places to break grammar.
My actual quick routine for socials is:
  • Type in app
  • Glance at keyboard underlines
  • One fast reread (out loud in my head, if that makes sense)
  • If it is a more serious or “pinned” post, paste into a checker like Clever AI Humanizer for a last pass
That balances not looking illiterate with not turning a 30 word caption into a whole workflow.
For quick grammar checks on short posts, I’d actually split tools into two buckets and keep the workflow almost frictionless.
1. Use what is already on your phone or platform
Before adding new tools:
  • Twitter / X, LinkedIn, etc. already flag basic spelling.
  • iOS / Android keyboards have grammar and autocorrect that catch a surprising amount if you slow down for 5 seconds and look at the underlines.
I slightly disagree with how heavily extensions are being pushed. If you only post from your phone, a desktop browser extension solves almost nothing for you.
2. Extremely light “final pass” tools
For those posts that matter more than usual:
  • Clever AI Humanizer works fine as a micro grammar checker for captions and short updates.
    • Handles more words than you need for captions in one go.
    • Catches tense issues and missing little words, not just typos.
    • Lets you skip suggestions so you keep your casual voice.
    • No need to install anything if you do not want plugins.
    • Easy to overuse and end up with polished, slightly stiff text if you accept everything.
    • Still an extra copy paste step if you post often.
    • Focused on English, so mixed language posts get weird suggestions.
Compared to what @sterrenkijker and @byteguru suggested, I would reserve Clever AI Humanizer for maybe the 1 in 5 posts that feels “important,” not every meme or offhand thought. That keeps your voice natural and avoids tool fatigue.
I also do not fully agree with @mikeappsreviewer about needing to think in terms of big daily word quotas for your use case. For sub 100 word posts, the main battle is habits, not limits.
3. Simple habit that pairs well with any checker
  • Write the caption.
  • Break longer sentences into two short ones.
  • Look for 3 things only: verb tense, subject verb agreement, missing “a / the / to.”
  • If it is going to a professional audience, then run it once through Clever AI Humanizer and only accept changes that do not change your tone.
That way, tools are a backup, not the main event.
