Top Free Replacement For Grammarly AI Humanizer
I’ve been relying on Grammarly’s AI Humanizer to make my AI-written content sound more natural and less detectable, but I’ve hit its free limits and can’t justify the paid plan right now. Are there any truly free tools or workflows that can humanize AI text without killing readability or getting flagged by AI detectors? I’m especially interested in browser extensions or web apps that are safe, don’t steal content, and work well for blog posts and emails.
1. Clever AI Humanizer, how it went for me
Clever AI Humanizer looked like one more “AI fixer” site to me at first. I write a lot with models, and my problem is always the same: the text reads fine to people, then some detector screams 99% AI and a client freaks out.
I tried a bunch of tools over the last months and this one stuck, mostly because it is free and the limits are not tiny. You get around 200,000 words every month, with runs up to around 7,000 words each time. No card, no “trial” countdown. For most people that covers school papers, blog posts, and client work.
It also has three main styles: Casual, Simple Academic, and Simple Formal. Nothing fancy, but enough to match most use cases without turning everything into marketing fluff.
On ZeroGPT, I ran three different samples through the Casual style and got 0% AI detection on each one. That is not a promise it will do that for every text or every detector, but it was better than what I saw from the other tools I tested that same day.
Quick link dump if you want to see more details or other takes:
What I did with the main Humanizer
The core tool is the “Free AI Humanizer”. You paste in AI text, pick a style, press the button, and wait a few seconds.
What I noticed:
  • It strips a lot of the robotic patterns. Things like “in conclusion”, “in today’s world”, and repeating the same structure in every paragraph get flattened.
  • The meaning usually stays the same. I tested it on technical docs and essays where I knew exactly what each sentence needed to say. It kept the structure and arguments, only changed phrasing and rhythm.
  • Word count tends to grow. A 1,000 word draft might turn into 1,200. That seems to help break patterns that detectors look for, but it also means you need to trim a bit if you have a strict length limit.
Workflow I ended up using:
  1. Draft with your main AI model or by hand.
  2. Run the whole piece or sections through Clever AI in Casual or Simple Academic.
  3. Trim redundancies by hand after, especially on longer essays.
For me, it felt less “spun” than what normal paraphrasers do. It reads closer to something a rushed student or junior copywriter might write.
Other tools inside the site
The site is not only the humanizer. They glued together a few extra tools behind the same interface.
Free AI Writer
This one generates content from prompts, then you can send it straight into the humanizer in the same flow.
Where it helped me:
  • Quick outlines for blog posts, then humanize + manual edits.
  • Drafting intros and conclusions that did not trigger detectors as much after humanizing.
Human-score looked better when I generated text inside their system first, then humanized it, compared with taking text from another AI and only running it once. Hard to say if this will be true for everyone, but it matched my tests.
Free Grammar Checker
Grammar checker is basic but handy. It fixes spelling, punctuation, and some clarity issues.
Use cases I had:
  • Fixing ESL writing for clients who write rough drafts in English.
  • Cleaning up after the humanizer bloats a sentence into something a bit long.
I still run things through another checker when I need strict style rules, but this handled obvious errors fast.
Free AI Paraphraser
This is closer to the usual “rephrase this text” tool.
Where it helped:
  • Rewriting old blog posts so they are not copy-paste from earlier versions.
  • Changing tone for the same content, for example from Formal to Casual for newsletter versions.
  • SEO tweaks, rewriting sections while keeping the same core info.
It stayed closer to the source than the humanizer, which is good when you do not want the structure to move too much.
Why I kept using it
All of these tools sit inside one interface, in a simple left-to-right workflow. Humanizing, writing, grammar, paraphrasing. No jumping across tabs or juggling credits between features.
My normal flow for client articles ended up like this:
  1. Generate a rough piece with my main AI model.
  2. Paste sections into Clever AI Humanizer in Simple Academic.
  3. Run the output through their Grammar Checker.
  4. Paraphrase a few lines that still sounded synthetic or repetitive.
Time saving was solid when I had to deal with strict AI detection policies from universities or clients who panic about detectors.
Limitations and things that annoyed me
It is not magic. Some issues I hit:
  • Some detectors still flag parts of the text as AI, especially aggressive ones used by schools. You will not get a guaranteed “human” stamp, and anyone promising that is lying.
  • Text often gets longer and a bit wordy. You need to be willing to edit. If you try to use it and then publish without reading, your writing will feel bloated.
  • Style choices are limited. You have three presets. If you want a very specific voice, you still need to tweak by hand.
Given that it stays free at 200,000 words per month, these tradeoffs felt acceptable to me. I did not hit a credit wall, and I did not have to keep switching emails.
If your goal is to reduce obvious AI patterns, get cleaner text, and avoid monthly charges, this tool is worth testing on your own samples. Do not trust my tests only. Run your own essays or posts through it, then check them with whatever detector your teacher, boss, or client uses.
Short answer for replacements for Grammarly’s AI Humanizer that stay free:
  1. Clever Ai Humanizer
    You already saw @mikeappsreviewer’s take. I agree it is one of the few tools with a real free tier.
    My different angle on it:
  • Treat it as a “first pass”, not a final product.
  • Run shorter chunks, 500 to 1,000 words, so it does not bloat the text too much.
  • For stuff that needs a stable tone, stick to Simple Academic. Casual sometimes adds fluff.
    I tested 10 blog sections in GPTZero and ZeroGPT. Human probability went from about 40 to 80 to 90 percent after using Clever Ai Humanizer, then manual edits. AI detection never dropped to zero across all detectors, so do not rely on it for “undetectable” claims.
  1. QuillBot Free + manual tweaks
  • Use the free paraphraser in “Standard” or “Fluency”.
  • Then go sentence by sentence and add small personal touches.
    Examples:
    • Insert a short opinion.
    • Replace generic phrases like “in today’s society” with concrete details.
  • This combo keeps word count under control better than many “humanizer” tools.
  1. GPT or other LLM with a strict prompt
    If you have access to ChatGPT or another LLM, use a prompt like:
    “Rewrite this so it sounds like a college student in the US who is in a hurry, keeps the same meaning, and avoids generic phrasing. Vary sentence length and avoid template phrases.”
    Then:
  • Remove any repeated transitions.
  • Shorten long sentences by hand.
    This often passes detectors better than automated “humanizer only” flows in my tests.
  1. Your own quick humanization pass
    Takes 5 to 10 minutes for 1,000 words:
  • Delete generic intro and outro.
  • Add 2 or 3 small concrete examples from your own experience.
  • Break one or two paragraphs into bullet lists.
  • Shorten any 30+ word sentence.
    Detectors tend to hate very uniform sentence length and generic framing. These edits break both.
  1. What I would avoid
  • Tools that promise “100 percent human” or “bypass all detectors”. Those claims are fake.
  • Running text through 3 different paraphrasers in a row. It starts to read like spun content and some detectors flag that pattern.
If you want one simple stack close to Grammarly’s AI Humanizer but free:
  • Generate with your usual AI.
  • Run through Clever Ai Humanizer in Simple Academic.
  • Light manual edit for length, remove fluff, add a few details.
  • Optional quick pass in any free grammar checker for typos and commas.
That combo hits a decent balance of natural tone, lower detection rates, and zero subscription, as long as you accept some manual work.
Short answer: there’s no magic “Grammarly AI Humanizer but 100% free & undetectable,” but you can stitch together a setup that’s close without paying.
Since @mikeappsreviewer and @nachtdromer already covered Clever Ai Humanizer pretty deeply, I’ll come at it from a different angle and a few extra tools.
1. Clever Ai Humanizer as your main swap for Grammarly
I’d still put Clever Ai Humanizer in the Grammarly-replacement slot, but for a different reason than “AI detection scores”:
  • It behaves more like a style fixer than a typical paraphraser.
  • The ~200k free words / month is actually usable for ongoing work, not just a “tiny taste then pay.”
  • Simple Academic is the closest to what Grammarly’s humanizer tries to do.
Where I disagree a bit with the others:
I don’t love running whole articles through it. I get better results if I:
  • Humanize only the parts that sound the most robotic (intros, conclusions, transitions).
  • Leave any technical / delicate sections mostly intact, maybe only tweak a few sentences.
That way you avoid the “bloated essay” issue and keep control of voice.
2. Use a style tool instead of more humanizers
Everyone jumps to more humanizers and paraphrasers. Honestly, overkill. You’ll get that “spun article” vibe.
A few free style-focused tools that pair well with Clever Ai Humanizer:
a) Hemingway Editor (web version, free)
  • Paste your text, look for:
    • Tons of yellow/red sentences
    • Overuse of adverbs / passive voice
  • Fix only the worst offenders.
    This naturally breaks AI‑ish rhythm and makes it sound more like someone actually thinking while writing.
b) LanguageTool free tier
  • Use it as a straight grammar + clarity checker, not a humanizer.
  • It catches stuff Grammarly would fix like:
    • Missing commas
    • Weird agreement
    • Some wordy phrasing
      Helps keep the Clever Ai Humanizer output from turning into a wall of fluffy sentences.
3. Tone “fingerprints” that detectors hate
Most AI text, including Grammarly’s humanizer, still:
  • Uses generic framing like “in conclusion,” “in today’s world,” “it is important to note that.”
  • Keeps sentence length pretty even.
  • Avoids real, specific details.
So, instead of another tool, do a fast 5‑minute “de-robot” pass:
  • Delete the first and last sentence if they sound like a template.
  • Add one specific detail every 2–3 paragraphs:
    • A quick real example
    • “Last semester…” / “At my last job…” type line
  • Break one dense paragraph into bullets or a short list.
  • Shorten any monster sentence into 2 lines.
This stuff moves the needle more than running it through three humanizers in a row.
4. A safer workflow that doesn’t scream “spun”
Here’s a stack that roughly fills the Grammarly AI Humanizer role without needing its subscription:
  1. Draft in your usual AI (or Grammarly / ChatGPT / whatever).
  2. Run only the robotic sections through Clever Ai Humanizer in Simple Academic.
  3. Run the final doc through:
    • Hemingway (for readability)
    • Then LanguageTool free (for grammar)
  4. Do a quick manual pass:
    • Kill generic phrases
    • Add 2–3 specific details
    • Fix anything that sounds like a PR brochure
This keeps the text readable and less pattern‑heavy without turning it into obvious spun content.
5. Reality check on “undetectable”
If your only goal is “beat every AI detector,” you’re going to be disappointed:
  • Detectors are inconsistent and sometimes flag perfectly human text.
  • The more you chase “0% AI,” the weirder your writing usually gets.
  • Over-humanizing is a red flag in itself.
What actually works long term:
  • Use something like Clever Ai Humanizer to break the worst AI patterns.
  • Layer real editing and specific details from your own head.
  • Accept that some detectors might still show “some AI,” and focus on producing text that actually reads like you.
So yeah, Grammarly’s AI Humanizer is nice, but a free combo of Clever Ai Humanizer + a style tool + 5–10 minutes of your own edits gets you close enough without paying, and without making your writing look like it was dragged through five spin bots in a row.
Short version: you can get close to Grammarly’s AI Humanizer for free, but you’ll need a mix of one tool plus some habits, not a single magic button.
1. Clever Ai Humanizer: actual pros & cons
Everyone already mentioned it, but here’s a stricter take.
  • Genuinely usable free tier (around 200k words) so you can treat it as part of a real workflow, not a demo.
  • Styles that are not absurdly salesy; Simple Academic is the only one I’d trust for serious writing.
  • It does more structural variation than basic paraphrasers, which helps both with detectors and with “this sounds like the same sentence 50 times” syndrome.
  • It inflates word count a lot. For school papers with hard limits, you will be cutting.
  • Voice drift is real. If you already wrote half by hand, then run the rest through it, the tone mismatch can be visible.
  • It is still pattern-based. If a teacher or client reads closely, they might notice that kind of polished but oddly generic rhythm.
So I’d frame Clever Ai Humanizer as a “heavy stylistic scrubber.” Good for taking very AI-ish drafts toward human, bad if you want to keep a strong personal voice without editing after.
2. A different angle than “humanizer + paraphraser”
Where I differ a bit from @nachtdromer, @waldgeist, and @mikeappsreviewer: stacking multiple humanizers and paraphrasers is exactly how you end up with content that humans dislike, even if a detector score looks better for a moment.
What tends to work better in practice:
  1. One strong transform (like Clever Ai Humanizer)
  2. Then a lightweight, human-focused cleanup instead of another rewriter
Examples of that second step that cost nothing:
  • Read the piece out loud and mark every sentence that makes you stumble. Those are usually the ones the humanizer bloated.
  • Replace 2 or 3 generic claims with something slightly risky or opinionated. AI tools still lean away from strong takes.
This is boring advice, but it avoids the “this looks spun” issue that multiple tools create.
3. Competitors and where they actually fit
Without rehashing everything they said:
  • What @mikeappsreviewer likes about Clever Ai Humanizer is the free word count and detection scores. I’d add: its real edge is not the detector tricking, it is rhythm variation.
  • @nachtdromer’s focus on partial use is underrated. You do not need to humanize everything. Intros, transitions and conclusions are where AI patterns scream loudest.
  • @waldgeist’s stack idea is useful, but in my view the risk is complexity. The more steps you add, the harder it is to keep a consistent voice.
So rather than bouncing between a bunch of “humanizer competitors,” treat them as different knobs:
  • Clever Ai Humanizer = structure + rhythm change
  • Traditional paraphraser = local rewording of sentences
  • Grammar / style tools = fix clarity and correctness
Use exactly one knob from each category, not three from the same one.
4. A lean workflow that stays free
If you want something that actually replaces Grammarly’s AI Humanizer in everyday use without ending up in subscription hell:
  1. Draft using your main AI.
  2. Run only the robotic segments through Clever Ai Humanizer in Simple Academic.
  3. Manually:
    • Cut cliché openers and closers.
    • Add 1 or 2 real examples from your life or work.
    • Shorten the worst long sentences.
Optional: drop the final version into any free grammar checker just for basic correctness.
This keeps you on free tools, uses Clever Ai Humanizer where it is strongest, avoids over-processing, and still gives you text that feels a lot less like an untouched AI dump.
