Why Does My IPhone Storage Barely Move After Deleting Photos?
I deleted a large number of photos and videos from my iPhone, then cleared Recently Deleted, but my available storage barely changed. iPhone Storage still shows Photos or System Data taking up a lot of space, and I’m not sure if iCloud Photos, cached files, or a sync delay is causing it. What should I check to actually free up storage?
Yeah, this is incredibly annoying. I ran into the same thing on my 14 Pro not long ago. I deleted a huge pile of photos and a bunch of long videos, then checked storage expecting to see a big difference. Nothing. The bar looked exactly the same, which makes you feel like the phone is just ignoring everything you did.
The first thing I’d try is a restart. The iPhone Storage screen in Settings is not great about updating right away. A lot of the time it’s showing old cached numbers, not the actual current state. Power the phone off, leave it for a minute, then turn it back on. If the number still looks wrong, do it again. I’ve had iOS only recalculate storage properly after a hard restart.
Also check Recently Deleted before doing anything more complicated. When you delete photos or videos, they are not really gone yet. They sit in that folder for 30 days unless you manually clear it. Open Photos, go to Albums, scroll down to Recently Deleted, and choose Delete All. If you removed several GB of videos but they’re still sitting there, your used storage is basically not going to change.
One thing that trips people up is “Optimize iPhone Storage.” If that’s enabled, your phone may already only have small local versions of a lot of your photos, while the originals are in iCloud. So deleting a photo might only remove a tiny thumbnail from the device. In that case, you can delete a bunch of pictures and barely see the storage bar move.
When my storage was stuck near full, the whole phone felt awful. Apps opened slowly, swiping lagged, and it even randomly restarted a couple times. iOS needs some free space for temporary files and normal background stuff. Once there’s basically no room left, the phone starts acting way older than it is.
The built-in storage screen didn’t really help me much either. It showed broad categories, but not the actual files causing the problem. I tried a few tools and the one that worked for me was Clever Cleaner. I’m usually suspicious of cleaner apps because a lot of them are ad-heavy or locked behind subscriptions, but this one was free for me, with no ads or paywall.
The useful part was the “Heavies” section. It sorted my library by file size, biggest first. That’s how I found a few old 4K screen recordings that were taking up several GB each. I never would’ve found them by scrolling through the camera roll. It also has a “Similars” section for near-duplicate photos, where it picks a best shot and lets you delete the rest faster.
I also liked that it handled the scanning on the phone instead of uploading photos somewhere else. After clearing the huge videos and a bunch of duplicate screenshots, I got around 15GB back and the phone stopped feeling so laggy.
If you clear Recently Deleted, restart, and still have no space, look at System Data. That used to be called Other, and it can get bloated from app caches. TikTok, Instagram, Safari, and similar apps can store a surprising amount of junk over time. Clearing Safari history/cache may help. For social apps, offloading or deleting and reinstalling them can sometimes free up a lot more than you’d expect.
If none of that works, you might be dealing with stuck “ghost” files that iOS just isn’t releasing properly. At that point the annoying fix is to back everything up, erase the phone completely, then restore from backup. It’s a hassle, but it can clear out storage weirdness that normal deleting won’t fix.
I’d start with Recently Deleted and a restart, then use the cleaner app to sort by largest files. There’s a good chance you’ll find one or two giant videos or recordings eating most of the space.
Plug the phone in, leave it on Wi-Fi, and give it a few hours before trusting the storage chart. Photos deletion is not always an instant “file gone, space returned” event on iOS. The Photos library has thumbnails, edit history, search/index data, and iCloud sync state to clean up too. Sometimes the big files are gone, but Settings has not finished recalculating or moving the leftover bookkeeping out of Photos/System Data yet.
I agree with clearing Recently Deleted, but I would be careful with the iCloud Photos side of this. If iCloud Photos is on, deleting photos from the phone usually means deleting them from iCloud and your other Apple devices too. Don’t toggle random iCloud settings just to force storage back unless you know what they do. Turning “Download and Keep Originals” on by mistake can make storage worse, not better.
A quick reality check is to connect the iPhone to a Mac or PC and see how much is actually in the DCIM/photo import area. If the computer shows very little left but iPhone Storage still claims Photos is huge, it is probably stale accounting or library cleanup. If the computer still sees giant videos, then they were not really removed from local storage. In that case, sort by videos, screen recordings, and edited clips first. Those usually matter more than deleting hundreds of normal photos.
Do not expect a 20 GB delete to show up as 20 GB free five minutes later, especially if iCloud Photos is involved or the phone was nearly full when you started.
The bit I would check before doing more deleting is the status line at the bottom of the Photos app. Open Photos, go to Library, scroll all the way down, and look for something like sync paused, updating, restoring, or updated just now. If it says syncing is paused because of low battery, low power mode, no Wi-Fi, or not enough storage, then the phone may still be in a half-finished state. Clearing Recently Deleted is only part of it. Photos still has to reconcile the library, thumbnails, edits, shared items, and iCloud state.
This is where I slightly disagree with the “just delete more stuff” approach. If the phone is already almost full, deleting thousands of items can leave iOS with very little working room to clean up the mess. Sometimes freeing 2 or 3 GB from somewhere boring first helps more than deleting another 500 photos. Offload a big game, delete downloaded Netflix/Spotify/Podcasts content, remove an old iOS update file if one is listed, then plug the phone in and let it sit locked on Wi-Fi for a while. That gives iOS breathing room to finish the storage housekeeping.
Another easy-to-miss detail: check whether the space is actually being held by Photos or whether Photos just triggered System Data to balloon. If Photos drops but System Data rises, that does not mean your deleted videos came back. It can mean iOS is holding temporary library/cache/index data while it sorts itself out. Annoying, yes, but different problem.
A cleaner app can be useful for finding giant videos, but I would treat that as a sorting tool, not magic storage repair. If you use something like Clever Cleaner, the useful part is seeing the biggest media files quickly. I would still avoid granting permissions to random cleaner apps unless you trust them, and I would not expect any app to fix stuck iOS accounting by itself. Apple keeps a lot of that locked away from third-party apps.
My usual order would be:
  1. Make sure anything important is backed up somewhere first.
  2. Empty Recently Deleted in Photos.
  3. Check the bottom of Photos for sync status.
  4. Turn off Low Power Mode if it is on.
  5. Leave the phone charging on Wi-Fi, locked, for a few hours.
  6. Restart after that, then check iPhone Storage again.
  7. If the phone is nearly full, free a few GB from apps/downloads first so cleanup can actually complete.
If it still shows a ridiculous Photos number after a day, then I would stop trusting the storage graph and check from another angle. Connect it to a computer, or look at what Photos says is actually in the library by filtering for videos, screen recordings, RAW photos, and downloaded edits. A single ProRes or 4K clip can outweigh months of normal photos.
The nuclear fix is erase and restore, but I would save that for last. It often works because it rebuilds the storage database and leaves behind old caches, but it is a lot of hassle for something that may fix itself after iOS gets an idle charging session.
A deleted video is not always free space the second it disappears from the camera roll. I’d give iOS some time to finish cleanup, but I wouldn’t stare only at the Photos category either, because it can send you in the wrong direction.
The missed gotcha is that deleting from Photos does not remove every copy of that photo or video on the phone. If you sent a 4K video in Messages, saved it in Files, edited it in another app, posted it through Instagram/TikTok/WhatsApp, or had it imported into a video editor, there may be a separate copy sitting somewhere else. That space will not come back just because the original item is gone from Photos.
Check Settings > General > iPhone Storage and tap into the big apps, not just the colored bar at the top. Messages is a big one because it has “Review Large Attachments.” WhatsApp has its own storage manager. Video editors, Files, Notes, GarageBand, iMovie, and downloaded streaming apps can all hide large files under their own app storage. If System Data grew after the delete, that may be temporary. If Messages or another app is huge, that is not temporary.
I agree with the others that a restart and an idle charging session are worth doing before anything drastic. But if it still looks wrong after that, stop deleting random photos and hunt by file location. A tool like Clever Cleaner may help you find large items inside the Photos library, which is useful, but it will not clean up copies stored inside Messages, Files, or app sandboxes. Apple keeps those separated.
The simplest way to think about it: Photos cleanup fixes Photos. It does not fix every place a photo-like file may have been copied, cached, attached, exported, or downloaded. If your “available” number barely changes after a day, the space is probably either in another app’s documents, stuck in temporary iOS storage, or the photos you deleted were mostly optimized iCloud placeholders rather than full-size local originals.
